79 Parts - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 79 Parts (/showthread.php?tid=7878) |
79 Parts - Wilhelmus Schreurs - 04-10-2009 10:54 Somewhere on this forum or on the Wanderlodgeownersgroup I read that the Mack truck mounts are used for our motor mounts. Not sure where I saw that. Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada All new Yahoo! Mail - Get a sneak peak at messages with a handy reading pane. 79 Parts - John - 04-10-2009 12:22 Bill, I'll let you guess, but I'm not telling where you saw that information, but here is the contents of the post; NEW MOTOR MOUNTS INSTALLED Here is what Randy and his helper Glenn finally did to get the new rear motor mount biscuits installed.....first I'm sure that there was a reason why my ears were burning, but after cutting out one of the old biscuits that had deformed and spread out somewhat, I made the trip down to Raneys Truck parts in Ocala, FL. and Gregg the parts man matched the old rubber biscuit up with one for a Mack truck engine, that is a little smaller in diameter and had to be trimmed a little, (I will let Randy describe what he did there) but after installing it into the mount itself and letting the weight of the engine compress it, the biscuit popped right into the hole that it was supposed to fit into. The part number for the rubber biscuit is ISOLATOR KCM 20QL324M. http://www.pbase.com/image/105532460 The new mounts also raised the exhaust pipes up off of the front suspension frame work, so this should also quiet things down even more, now I may have to stop every so often and get out to listen to make sure the engine is still running There were some folks that were at RATS that thought that they heard some piston slap when my 'Bird was sitting in the drive idling, that turned out to be the Horton air clutch fan that is very noisy and rattles when the engine is at idle, according to the people at Horton this is normal and you can hear the trucks at the truck stop during the summer that are sitting with the air conditioner running, make the same noise. When the Horton fan is turned off, it sounds just like any other Cat 3208NA according to Randy. __________________ JOHN FINN FORUM MODERATOR 1982 FC35RB BLUEBIRD WANDERLODGE "FINN'S INN EXPRESS" HOPKINS, SOUTH CAROLINA VISIT THE FINN'S INN EXPRESS REMODELING ADVENTURE AND TECH. TIPS http://www.pbase.com/image/24977457 I'M SO SLOW ON THE HILLS,THAT I GET TO SMELL THE FLOWERS AS I GO BY.....AND WATCH THEM GROW TOO!! Visit the WILD HARE RACING website at; http://www.pbase.com/iamflagman/image/86213456 REMEMBER 9/11 ==================================================================== --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs wrote: > > Somewhere on this forum or on the Wanderlodgeownersgroup I read that the Mack truck mounts are used for our motor mounts. Not sure where I saw that. > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > __________________________________________________________________ > Looking for the perfect gift? Give the gift of Flickr! > > http://www.flickr.com/gift/ > |
