Batteries & Charging Circuit 87 FC - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Batteries & Charging Circuit 87 FC (/showthread.php?tid=7886) |
Batteries & Charging Circuit 87 FC - Curt Sprenger - 04-11-2009 04:10 Uploading PDF to WanderlodgeForum/Messanges/Post/Attachements Curt Sprenger |
Batteries & Charging Circuit 87 FC - timvasqz - 04-11-2009 05:38 Curt one way to help index them is to start a thread with the full year and the model in the subject line then "files only" IE " 1987 FC Files ONLY " inthe description area you can make a statement about the attached files more descript than the files section filename reveal. in a message search of " 1987 files " or "FC Files" the thread should be revealed and all the postings of different member shared and posted pdf's and files will show up in the diary of the thread. one question, are you using rich-text editor to post file up loads to a message? Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Uploading PDF to WanderlodgeForum/Messanges/Post/Attachements > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > *Read all about Southwest Bluebirds and Friends (SWBB) at > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > "Host of the Annual Bluebird Quartzsite Rally" * > Batteries & Charging Circuit 87 FC - Curt Sprenger - 04-11-2009 08:04 Greg, Thanks, Good thought for sure. A schematic might indicate 1987, I have found that some schematics cover the next model year, two or three, or more.ÃÂ ÃÂ The Yahoo Attachment section has no organization at this time. There is no Description area to fill in. At least none that I have found. The Subject in the email is what becomes the Title or Description in the Attachment section.ÃÂ ÃÂ ÃÂ I'm using Gmail email service to move the PDFs to Yahoo Attachments.ÃÂ ÃÂ Curt Sprenger On Sat, Apr 11, 2009 at 10:38 AM, timvasqz <"Petrover1@aol.com"> wrote:
