Fuses - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fuses (/showthread.php?tid=7951) |
Fuses - ejohna2000 - 04-13-2009 03:25 In the compartment that houses the Readyline and the 2 chargers, mounted on the swing down door there are 2 glass fuses, anyone know what they are for. Also mounted on the door is a relay & two solinoids. Elmer in Sebring, FL 86 PT 38 Fuses - Wayne Kotila - 04-13-2009 09:48 Elmer, on my 1985 PT40 one of those glass fuses is for the engine compartment lights and the other one is for the electric clutch on the air conditioning comp. on the engine.
Wayne
1985 PT40
From: ejohna2000 To: WanderlodgeForum@yahoogroups.com Sent: Monday, April 13, 2009 10:25:17 AM Subject: [WanderlodgeForum] Fuses In the compartment that houses the Readyline and the 2 chargers, mounted on the swing down door there are 2 glass fuses, anyone know what they are for. Also mounted on the door is a relay & two solinoids. Elmer in Sebring, FL 86 PT 38 Fuses - Jay Darst - 04-13-2009 15:55 On my 1985 PT40... 1.) one fuse is for the cruise control 2.) one fuse is for the A/C clutch relay #1-The fuse for the cruise control gets replaced every spring on my Bird. For some reason, the cruise works intermittently in the spring time. I have learned over the years that by simply replacing the fuse, the cruise works great. The fuse is not open(blown). Must be really low amperage thru there. #2-There were 2 50amp continuous duty relay's that provided power to the Redi-Line. There is also a relay that provides voltage to the A/C clutch. Not sure cuz I can't remember(5 years ago), I think I put the A/C Bosch relay in there to keep the voltage good to that clutch. (I have upgraded chasis a/c to R134 and made several improvements to that system at that time) JDarst 85PT40 91Prevost40XL Royale for sale Sullivan, IL --- In WanderlodgeForum@yahoogroups.com, Wayne Kotila > > Elmer, on my 1985 PT40 one of those glass fuses is for the engine compartment lights and the other one is for the electric clutch on the air conditioning comp. on the engine. > Wayne > 1985 PT40 > > > > > ________________________________ > From: ejohna2000 > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, April 13, 2009 10:25:17 AM > Subject: [WanderlodgeForum] Fuses > > > > > > In the compartment that houses the Readyline and the 2 chargers, mounted on the swing down door there are 2 glass fuses, anyone know what they are for. Also mounted on the door is a relay & two solinoids. > Elmer in Sebring, FL 86 PT 38 > Fuses - ejohna2000 - 04-14-2009 00:50 Thanks for all the replies & help. After reading the posts I checked mine and found one fuse was the a/c clutch and the other the cruise. Elmer 86 PT 38 |
