Need Video Control Center - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Need Video Control Center (/showthread.php?tid=7954) |
Need Video Control Center - Jack and Liz Pearce - 04-13-2009 09:51 Howdy. I need to replace the Video Control Center in our 1993 WL. The box is old and the switches are electrically noisy. Anyone know where I can get one of those control centers? Has anyone rebuilt theirs? If so, please let me know how you did it, where did you get the parts, etc? I uploaded a photo of this control center to our Photos section. Couldn't figure out how to attach it to this message. TIA, Jack Pearce Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 D'Hanis, TX Buena Vista, CO Need Video Control Center - Fred Hulse - 04-14-2009 14:01 Jack & Liz
There are several mfg. that make your video control box.
Below is one.
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Need Video Control Center - Jack and Liz Pearce - 04-14-2009 14:56 --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Jack & Liz > There are several mfg. that make your video control box. > Below is one. > > http://winegard.com/mobile/switch.php > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > ============================================== Thanks for the info. Regards, Jack 1993 WLWB D'hanis, TX Need Video Control Center - timvasqz - 04-14-2009 15:30 I have one that I took out but I am sure it is as degraded as the one you intend to replace. With modern appliances you should not need the gateway box.they will render many of the multifunction remotes useless. I would bet if you follow the Direct tv reciever's 'how to wire' set up you will have everything you need without using the gateway selector box. also if direct tv is your sat provider, you can order a radio control reciever where you will not need line of sight to the direct tv box and you can use the remote outside to control the bay tv even with the coach door closed. Radio Shack has those box's for less tha $20. Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > > > Jack & Liz > > There are several mfg. that make your video control box. > > Below is one. > > > > http://winegard.com/mobile/switch.php > > Fred & Jeanne Hulse > > Morristown Arizona > > 1997 Wanderlodge WLWB41 > > > ============================================== > Thanks for the info. > > Regards, > Jack > 1993 WLWB > D'hanis, TX > Need Video Control Center - Jack and Liz Pearce - 04-18-2009 11:07 --- In WanderlodgeForum@yahoogroups.com, "timvasqz" > > I have one that I took out but I am sure it is as degraded as the one you intend to replace. With modern appliances you should not need the gateway box.they will render many of the multifunction remotes useless. I would bet if you follow the Direct tv reciever's 'how to wire' set up you will have everything you need without using the gateway selector box. also if direct tv is your sat provider, you can order a radio control reciever where you will not need line of sight to the direct tv box and you can use the remote outside to control the bay tv even with the coach door closed. Radio Shack has those box's for less tha $20. > Greg of Tim&Greg > 94ptca We use our video control center to control seven inputs to two outputs. We have a TV in the bedroom and a TV in the living room. I need to able to control roof antenna, satellite one, satellite two, cable one, cable two, DVR and video tape independently, for the two TVs. Regarding the Dish TV receiver's "how to wire" set up -- I found that a little inadequate. Jack Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 D'Hanis, TX Buena Vista, CO Need Video Control Center - timvasqz - 04-19-2009 10:26 --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > > Satellite1 and Satellite2 if these are roofmount1 and portable2, you may need a switch prior to the Direct-Dish receiver for a choice there ( I dont uderstand why I was told not to have both hooked up or a dead end path?) for all the other inputs, no swith is needed I have a set of sony dvd/vcr players for each tv which makes the required RF control usable. the tv antenna can be hooked up to both sets without a need to disconnect the other or disconnect while not in use. the best way to set it up is to diagram a flow chart. it may well be that you will need to input several items thru the dvr or vcr prior to the direct/dish converter input. older tv's have few inputs. what you see is often what input on the link to the monitor has power and signal. Greg 94ptca > We use our video control center to control seven inputs to two outputs. > We have a TV in the bedroom and a TV in the living room. I need to able > to control roof antenna, satellite one, satellite two, cable one, cable > two, DVR and video tape independently, for the two TVs. Regarding the > Dish TV receiver's "how to wire" set up -- I found that a little > inadequate. > > Jack > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > D'Hanis, TX > Buena Vista, CO > |
