A/T Switch - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: A/T Switch (/showthread.php?tid=8001) |
A/T Switch - maureyroad - 04-27-2009 14:04 Open circuit to start or closed? Dan Williams, 81RB33, Jackson, MS A/T Switch - timvasqz - 04-27-2009 17:03 powers a relay--- In WanderlodgeForum@yahoogroups.com, "maureyroad" wrote: > > Open circuit to start or closed? > > Dan Williams, 81RB33, Jackson, MS > A/T Switch - Dan - 04-28-2009 02:22 does the relay prevent starting or allow starting?
A/T Switch - Ralph L. Fullenwider - 04-28-2009 02:38 Dan: The switch in the closed position picks a relay and allows starting. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 09:22 AM 4/28/2009 -0500, you wrote: does the Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma |
A/T Switch - amweatherly@... - 04-28-2009 02:44 - The AT switch on my '85 PT36 is in line with the lead going from the start position on the key switch to the starter solenoid. Depressing the left side of that switch closes the ckt. and allows contact to the starting soleniod. Depressing the right side opens that ckt. Art Weatherly Riverside Ca. '85 PT36 -- In WanderlodgeForum@yahoogroups.com, "Dan" > > does the relay prevent starting or allow starting? > ----- Original Message ----- > From: timvasqz > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, April 28, 2009 12:03 AM > Subject: [WanderlodgeForum] Re: A/T Switch > > > > > > powers a relay--- In WanderlodgeForum@yahoogroups.com, "maureyroad" > > > > Open circuit to start or closed? > > > > Dan Williams, 81RB33, Jackson, MS > > > > > > > > > ------------------------------------------------------------------------------ > > > > No virus found in this incoming message. > Checked by AVG - http://www.avg.com > Version: 8.5.287 / Virus Database: 270.12.5/2083 - Release Date: 04/27/09 18:00:00 > A/T Switch - Ryan Wright - 04-28-2009 04:47 What's the switch for? Why would one need to use it? -Ryan (always wondered about that one) '86 PT-40 8V92 On Tue, Apr 28, 2009 at 7:38 AM, Ralph L. Fullenwider > > > Dan: > > The switch in the closed position picks a relay and allows starting. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > A/T Switch - Pete Masterson - 04-28-2009 06:57 The A/T switch is the "Anti-Theft" switch. It kills most of the 12 v circuits, including the starting circuit. It's helpful in storage to reduce the phantom load (but it doesn't completely cut off that load). Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Apr 28, 2009, at 9:47 AM, Ryan Wright wrote:
A/T Switch - Dan - 04-28-2009 14:04 Thanks Art, and thanks to everyone who responded. My A/Ttoggle switch broke off and I have to replace it.
A/T Switch - timvasqz - 04-28-2009 17:10 It looks like it powers a coil by adding the ground thru the switch??? http://f1.grp.yahoofs.com/v1/0N73SWKlj-ecm4EFdbZ_ubpAsVG-tHYT9lBgFnBvSikYWHmj1yLZMw3x1oEUgdnfBtNa1WqNrEYwfwPk-QC-Rk85CSzoesw/1991_%20to_1994_pt_diagrams/94_Elect_Sys.pdf if you look right of dead center, you will see the electromag coil and see ground connected to the other side of the at switch. this is a 94 however. looks like open ground drops the coil so if the switch burnt and is making grount 100% of the time it could be the solenoid??? Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Dan" > > Thanks Art, and thanks to everyone who responded. My A/T toggle switch broke off and I have to replace it. > > Dan Williams, 81RB33, Jackson, MS > ----- Original Message ----- > From: amweatherly@... > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, April 28, 2009 9:44 AM > Subject: [WanderlodgeForum] Re: A/T Switch > > > > > > - > > The AT switch on my '85 PT36 is in line with the lead going from the start position on the key switch to the starter solenoid. Depressing the left side of that switch closes the ckt. and allows contact to > the starting soleniod. Depressing the right side opens that ckt. > > Art Weatherly > Riverside Ca. > '85 PT36 > > -- In WanderlodgeForum@yahoogroups.com, "Dan" danusa@ wrote: > > > > does the relay prevent starting or allow starting? > > ----- Original Message ----- > > From: timvasqz > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, April 28, 2009 12:03 AM > > Subject: [WanderlodgeForum] Re: A/T Switch > > > > > > > > > > > > powers a relay--- In WanderlodgeForum@yahoogroups.com, "maureyroad" > > > > > > Open circuit to start or closed? > > > > > > Dan Williams, 81RB33, Jackson, MS > > > > > > > > > > > > > > > > > ---------------------------------------------------------- > > > > > > > > No virus found in this incoming message. > > Checked by AVG - http://www.avg.com > > Version: 8.5.287 / Virus Database: 270.12.5/2083 - Release Date: 04/27/09 18:00:00 > > > > > > > > > ------------------------------------------------------------------------------ > > > > No virus found in this incoming message. > Checked by AVG - http://www.avg.com > Version: 8.5.287 / Virus Database: 270.12.6/2084 - Release Date: 04/28/09 06:15:00 > |
