Fwd: Street-side slobber tube leaking oil and coolant - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fwd: Street-side slobber tube leaking oil and coolant (/showthread.php?tid=8017) |
Fwd: Street-side slobber tube leaking oil and coolant - Ernest Ekberg - 05-04-2009 09:34 --- In DetroitDiesel@yahoogroups.com, "trudylundgren" Hello there, We have a 1985 Bluebird Wanderlodge PT-40 with a Detroit Diesel 2-stoke 6V92 330hp. We have oil and coolant leaking from the street-side slobber tube. The oil and coolant are not mixed, as the mixture is not white like mayonnaise as yet. The oil on the dipstick is normal. We arrived here in Las Vegas to work for the month of May this past Sunday. I noticed this leak yesterday morning. Ernie said it sounds like a bad head gasket. We welcome your thoughts and advice. Thank you... Take care, Lisa --- End forwarded message --- Fwd: Street-side slobber tube leaking oil and coolant - ronmarabito2002 - 05-04-2009 12:48 It could be sleeve seals also. Have it looked at now because you might lose your engine if you dump the coolant while on the road. I did last September and the coolant was coming from the slobber tubes, which is a drain for the air box. It is telling you that coolant is not where it is supposed to be. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > --- In DetroitDiesel@yahoogroups.com, "trudylundgren" > > > Hello there, > > > > We have a 1985 Bluebird Wanderlodge PT-40 with a Detroit Diesel 2-stoke 6V92 330hp. > > We have oil and coolant leaking from the street-side slobber tube. The oil and coolant are not mixed, as the mixture is not white like mayonnaise as yet. The oil on the dipstick is normal. > > We arrived here in Las Vegas to work for the month of May this past Sunday. I noticed this leak yesterday morning. Ernie said it sounds like a bad head gasket. > > We welcome your thoughts and advice. > > Thank you... > > Take care, > Lisa > > --- End forwarded message --- > |
