Height of a 1995 42' bird - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Height of a 1995 42' bird (/showthread.php?tid=8153) |
Height of a 1995 42' bird - Bob & Carol Howald` - 05-16-2009 01:14 Goodmorning all----Need the height of a 95 bird with the suspension aired up. (top of ac) Also, with with the suspension dumped can you still pull forward without tire rub. Thanks, Bob birdless in Illinois Height of a 1995 42' bird - ronmarabito2002 - 05-16-2009 04:03 Should be about 12'-6" when aired up. You can move forward with suspension down, but you can't turn. R.E. (ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" wrote: > > Goodmorning all----Need the height of a 95 bird with the suspension aired up. (top of ac) Also, with with the suspension dumped can you still pull forward without tire rub. Thanks, Bob birdless in Illinois > Height of a 1995 42' bird - Pete Masterson - 05-16-2009 05:34 Be careful of non-stock items on the roof. I have a satellite TV antenna dome -- sticks way above the ACs, usually the highest item. Puts me juuuust under 13'. Dealer I bought it from said the coach cleared 12-6 with the suspension down (how they got it in the door to their shop). Moving with the suspension dumped requires going super-slow in a straight line.
Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On May 16, 2009, at 9:03 AM, ronmarabito2002 wrote:
Height of a 1995 42' bird - Jack and Liz Pearce - 05-18-2009 13:41 --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > Goodmorning all----Need the height of a 95 bird with the suspension aired up. (top of ac) Also, with with the suspension dumped can you still pull forward without tire rub. Thanks, Bob birdless in Illinois ------------------------------------------------------------------------------------------------ HMMMM. With suspension dumped, how are the brakes affected? Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 D'Hanis, TX Buena Vista, CO Height of a 1995 42' bird - Ernest Ekberg - 05-18-2009 23:17 Cornelius, NC > > > --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > > > > Goodmorning all----Need the height of a 95 bird with the suspension > aired up. (top of ac) Also, with with the suspension dumped can you > still pull forward without tire rub. Thanks, Bob birdless in Illinois > ------------------------------------------------------------------------\ > ------------------------ > > HMMMM. With suspension dumped, how are the brakes affected? > > Liz > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > D'Hanis, TX > Buena Vista, CO > Height of a 1995 42' bird - jcmace59 - 05-20-2009 06:38 Bob, As Ernie ahs stated, you can pull STRAIGHT forward, but you can not turn if the suspension is dumped. My 96 is 12'8 or 9" to the top of the a/c's with the suspension up. But the antennas stick up more than that. I typically use 13' as my go/no go point. John --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > currently in Cornelius, NC > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > > > > > > > Goodmorning all----Need the height of a 95 bird with the suspension > > aired up. (top of ac) Also, with with the suspension dumped can you > > still pull forward without tire rub. Thanks, Bob birdless in Illinois > > ------------------------------------------------------------------------\ > > ------------------------ > > > > HMMMM. With suspension dumped, how are the brakes affected? > > > > Liz > > Regards, > > Jack and Liz Pearce > > Fulltiming in a 1993 Wanderlodge WB40 > > D'Hanis, TX > > Buena Vista, CO > > > Height of a 1995 42' bird - Eric Perplies - 05-21-2009 08:38 My 96' is 12' 5" to the top of the air conditioners when aired up. I used a board with a level on it and measured to the ground. (I needed 5 hands to measure that.) Eric Perplies 96 42' WBWL |
