front air conditioner troubleshooting - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: front air conditioner troubleshooting (/showthread.php?tid=8191) |
front air conditioner troubleshooting - Dorn Hetzel - 05-30-2009 08:16 I am trying to diagnose a non-functional front AC (the engine driven one). The system does not seem to have any significant leaks, as it will hold a vacuum when pumped down. A local shop helped me add the conversion connectors so we could connect the system to their diagnostic equipment. After holding a vacuum on the system for 30 minutes, we added some refrigerant and started up. There is a very small amount of cooling generated, but high-side pressure builds very high, up to 500 lbs, which leads me to guess that there is a blockage somewhere on the high side before the expansion valve. So, we pumped the refrigerant back out and I took the bird home and I am setting up to pump air through the various lines to see if and where the flow is restricted. I am trying to remove the high side line at the compressor, and there are some clamps on hose, which I have loosened and pulled back, but the hose still won't come off the barb fitting. I am wondering if I am going to have to sacrifice that last couple inches of the hose and cut it off, or if there is a better way? Here is a link to a picture of the compressor and hose and with retracted clamps. Any suggestions? http://www.hetzel.org/2009-05-30-01-bb-02.jpg Regards, Dorn Hetzel 77FC35 Hogansville, GA front air conditioner troubleshooting - Curt Sprenger - 05-30-2009 09:40 Cut the hose, remove the hose fitting, install a nipple and pipe coupler, install the hose fitting. Curt Sprenger On Sat, May 30, 2009 at 1:16 PM, Dorn Hetzel <"dorn@hetzel.org"> wrote:
front air conditioner troubleshooting - ronmarabito2002 - 05-30-2009 09:58 Take some channel lock pliers and try to rotate the hose on the fitting. If that doesn't turn it loose and you have sufiecient hose, then cut it off and move along. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, Dorn Hetzel > > I am trying to diagnose a non-functional front AC (the engine driven one). > > The system does not seem to have any significant leaks, as it will > hold a vacuum when pumped down. > > A local shop helped me add the conversion connectors so we could > connect the system to their diagnostic equipment. > > After holding a vacuum on the system for 30 minutes, we added some > refrigerant and started up. > > There is a very small amount of cooling generated, but high-side > pressure builds very high, up to 500 lbs, which leads me to guess that > there is a blockage somewhere on the high side before the expansion > valve. > > So, we pumped the refrigerant back out and I took the bird home and I > am setting up to pump air through the various lines to see if and > where the flow is restricted. > > I am trying to remove the high side line at the compressor, and there > are some clamps on hose, which I have loosened and pulled back, but > the hose still won't come off the barb fitting. > > I am wondering if I am going to have to sacrifice that last couple > inches of the hose and cut it off, or if there is a better way? > > Here is a link to a picture of the compressor and hose and with > retracted clamps. Any suggestions? > > http://www.hetzel.org/2009-05-30-01-bb-02.jpg > > Regards, > > Dorn Hetzel > 77FC35 > Hogansville, GA > front air conditioner troubleshooting - timvasqz - 05-30-2009 10:59 If you can cut a 1/2 inch section off of the end of the hose while it is on the barb, sometimes you can push the hose on farther and free it up. prob is if it is too brittle to come off the barb you may have found the restriction to be a compromised old hose. If the motor run ac project gets too expensive, a large inverter hooked to the foremost 110 ac may just be the ticket. Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, Dorn Hetzel > > I am trying to diagnose a non-functional front AC (the engine driven one). > > The system does not seem to have any significant leaks, as it will > hold a vacuum when pumped down. > > A local shop helped me add the conversion connectors so we could > connect the system to their diagnostic equipment. > > After holding a vacuum on the system for 30 minutes, we added some > refrigerant and started up. > > There is a very small amount of cooling generated, but high-side > pressure builds very high, up to 500 lbs, which leads me to guess that > there is a blockage somewhere on the high side before the expansion > valve. > > So, we pumped the refrigerant back out and I took the bird home and I > am setting up to pump air through the various lines to see if and > where the flow is restricted. > > I am trying to remove the high side line at the compressor, and there > are some clamps on hose, which I have loosened and pulled back, but > the hose still won't come off the barb fitting. > > I am wondering if I am going to have to sacrifice that last couple > inches of the hose and cut it off, or if there is a better way? > > Here is a link to a picture of the compressor and hose and with > retracted clamps. Any suggestions? > > http://www.hetzel.org/2009-05-30-01-bb-02.jpg > > Regards, > > Dorn Hetzel > 77FC35 > Hogansville, GA > |
