remodel - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: remodel (/showthread.php?tid=8245) |
remodel - patty_austin - 06-23-2009 11:49 Is anyone out there familiar with what is under the bed in the rear. I want to remove the standard bed that came with the bluebird and replace it with a smaller bed that would be bolted to the floor. Ultimately I need it to be a flat surface and want to know if this is possible to achieve. It is an 88 wanderlodge. Thanks in advance for any guinine knowledge on the issue. Patty remodel - mariopatti1 - 06-23-2009 17:22 Patty Be a little more specific What model BB ? Year ? Mario 1985 fc 35 --- In WanderlodgeForum@yahoogroups.com, "patty_austin" > > Is anyone out there familiar with what is under the bed in the rear. I want to remove the standard bed that came with the bluebird and replace it with a smaller bed that would be bolted to the floor. Ultimately I need it to be a flat surface and want to know if this is possible to achieve. It is an 88 wanderlodge. Thanks in advance for any guinine knowledge on the issue. Patty > remodel - Bob Lawrence - 06-24-2009 01:21 Do you have a walkaround bed or is it a bed that goes from side to side (Drivers side to pass. side)? Bob Lawrence 84 PT36 Ft. DeSoto, Fla Is anyone out there familiar with what is under the bed in the rear. I want to remove the standard bed that came with the bluebird and replace it with a smaller bed that would be bolted to the floor. Ultimately I need it to be a flat surface and want to know if this is possible to achieve. It is an 88 wanderlodge. Thanks in advance for any guinine knowledge on the issue. Patty > remodel - mbulriss - 06-24-2009 07:34 Assuming it is a forward facing island queen bed, there should be a 116 gallon water tank, a water pump and filter, and an access hatch to the top of the engine, so finding a new place for the fresh water system would be a challenge. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "patty_austin" > > Is anyone out there familiar with what is under the bed in the rear. I want to remove the standard bed that came with the bluebird and replace it with a smaller bed that would be bolted to the floor. Ultimately I need it to be a flat surface and want to know if this is possible to achieve. It is an 88 wanderlodge. Thanks in advance for any guinine knowledge on the issue. Patty > |
