Murphy and the Gremlins - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Murphy and the Gremlins (/showthread.php?tid=8290) |
Murphy and the Gremlins - Kurt Horvath - 07-11-2009 16:05 Murphy has shown up and he brought a bag full of gremlins with him this time. Dash air went out, got that fixed burnt wire on the resistor. Selector switch for the water pumps is acting up, Anyone know where to get one of these, it's a bit odd, all the connections are soldered on. The Kenwood speakers finally blew out, I like it loud when I'm driving, I ordered a pair of Infinity Reference 9623i 6x9 speakers. The electroluminescent dash went out a few weeks ago. I have tested the connections the headlight switch which powers the dimmer for the EL, checked the dimmer and installed new inverters. I was told that there is an in-line 5 amp fuse ,but If there is one I can't find it. Still no blue lights it's a ground problem, I think, any ideas? Today I went out and fired up the coach for a little outing and she won't air up, I moved her out of the barn 2 days ago and She did something I've never heard before a loud series of thumping sounds before it fired up, I thought it was the starter, It's not, I started her from the rear key position and the thumping is coming from the area of the air compressor. it did it several times, now 2 days latter it won't do it, she fires up normally. Today she started normally, started to air up normally, then it just quite and now she won't air up at all, Brakes are fully charged but the suspension will not air up. At high idle no low air alarm, let her idle normally and the alarm goes off, I started the auxiliary air compressor and listened for air leaks, I can't find any, but then again I can't hear all that well, could be from listening to the stereo at full blast . So obviously there is a problem. Any ideas on how to trouble shoot these gremlins???? Kurt Horvath 95 PT 42 10AC Murphy and the Gremlins - Gregory OConnor - 07-11-2009 17:35 maybe it only seems like a coincidence that the speakers blew and the alarm sounded. I blew my speakers and Tim started to comment on my driving. fixed the speakers and he stopped. the compressor is gear driven, check the sump? Check the bolt torque on the compressor also.the fuel pump I think stacks off of the compressor???? It may be that you passed some of your airfilter thru the compressor???? I would look at the airfilter and the output of the compressor. if it starved for air there is usualy oil sucked thru the valve seats of the compressor that ended up in the output line. On my 94 the inverter is the size of a brick there are two unitd in the bay with the genset fan. the dimmer I believe gates 12 volts to the inverter not from the inverter. you can test for voltage at the dimmer and after the dimmer. I have run the el light with 120 volts inplace of the inverter to test the el lights. after the inverter I believe you end up with 120 volts and major htz but i am not sure. Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath" > > Murphy has shown up and he brought a bag full of gremlins with him this time. > > Dash air went out, got that fixed burnt wire on the resistor. > > Selector switch for the water pumps is acting up, Anyone know where to get one of these, it's a bit odd, all the connections are soldered on. > > The Kenwood speakers finally blew out, I like it loud when I'm driving, I ordered a pair of Infinity Reference 9623i 6x9 speakers. > > The electroluminescent dash went out a few weeks ago. I have tested the connections the headlight switch which powers the dimmer for the EL, checked the dimmer and installed new inverters. I was told that there is an in-line 5 amp fuse ,but If there is one I can't find it. Still no blue lights it's a ground problem, I think, any ideas? > > Today I went out and fired up the coach for a little outing and she won't air up, I moved her out of the barn 2 days ago and She did something I've never heard before a loud series of thumping sounds before it fired up, I thought it was the starter, It's not, I started her from the rear key position and the thumping is coming from the area of the air compressor. it did it several times, now 2 days latter it won't do it, she fires up normally. Today she started normally, started to air up normally, then it just quite and now she won't air up at all, Brakes are fully charged but the suspension will not air up. At high idle no low air alarm, let her idle normally and the alarm goes off, I started the auxiliary air compressor and listened for air leaks, I can't find any, but then again I can't hear all that well, could be from listening to the stereo at full blast . So obviously there is a problem. Any ideas on how to trouble shoot these gremlins???? > > Kurt Horvath > 95 PT 42 > 10AC > Murphy and the Gremlins - Fred Bellows - 07-12-2009 02:42 "Kurt Horvath" > > Murphy has shown up and he brought a bag full of gremlins with him this time. ..... > The Kenwood speakers finally blew out, I like it loud when I'm driving, I ordered a pair of Infinity Reference 9623i 6x9 speakers. <!--[if gte mso 9]> Kurt, your speaker blowing out may be due to having a bad amp/loose power connection on your amp/or not having a large enough or clean enough amp. If you are running your speakers off of the tiny, "I.C. chip" amp built into your radio/deck, and not using an external, "discreet" amplifier, it will blow speakers regularly, and most importantly, not sound anywhere nearly as good as it could with an external amp. There are some full explanations of these issues on my website: www.subsolutions.com under the "audio basics" and the "self install" sections, including this excerpt: â¦.Most speakers will handle more power than you think. What they can't handle is distortion. Distortion is what an amplifier puts out when it isn't big enough to play as loud as you would like it to. It's that extra, fuzzy sound over the top of your music when you reach the limit. All amplifiers distort when you turn them up past their maximum output limit. Your amp tries to amplify the small signal from your deck without altering its smooth shape. Your amp has a "voltage rail" limit of how big it can do that before it chops off the top and bottom of the sine wave, causing distortion-which will damage your speakers. To summarize, if your stereo is not loud enough, or if you've blown a speaker from distortion (which isn't covered under any warranty) and had to get another one, buy a bigger ampâ¦. So check these before you hook up your new speakers. `Important to understand, you can use the best speakers in the world, and they'll still blow from distortion (inversely, you can use fairly inexpensive speakers and achieve quite high performance, using a "clean" (low distortion) amp). \/\/\â¦Fred __________________ Fred & Wendy Bellows Queen Creek, AZ (so.east Phx) '90 SP36 "Maunder Maximum" photos of coach and upgrades current location Murphy and the Gremlins - Curt Sprenger - 07-12-2009 02:50 Fred, GREAT POST, THANKS......I just went through this installing a new receiver and new speakers in the patio cover ceiling. àCurt Sprenger On Sun, Jul 12, 2009 at 7:42 AM, Fred Bellows <"nytexcel@yahoo.com"> wrote:
Murphy and the Gremlins - Kurt Horvath - 07-12-2009 03:41 Thanks Fred, The surround on the speakers just turned to dust, with a few pieces hanging on hear and there, created quite a mess when I took the grills off, the system has a Kenwood 75W amp. that should handle these speakers. Looked at the web site very nice, I would invest in a better stereo system but with my failing hearing it's probably a waste of $'s at this point. Thanks for the info. Kurt Horvath 95 PT 42 10AC --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote: > > Fred, GREAT POST, THANKS......I just went through this installing a new > receiver and new speakers in the patio cover ceiling. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > *Read all about Southwest Bluebirds and Friends (SWBB) at > http://www.SOUTHWEST-BLUEBIRDS.ORG ...Then Join us. > "Host of the Annual Bluebird Quartzsite Rally" * > > > On Sun, Jul 12, 2009 at 7:42 AM, Fred Bellows > > > > > > > "Kurt Horvath" > > > > > > Murphy has shown up and he brought a bag full of gremlins with him this > > time. > > ..... > > > The Kenwood speakers finally blew out, I like it loud when I'm driving, I > > ordered a pair of Infinity Reference 9623i 6x9 speakers. > > > > Kurt, your speaker blowing out may be due to having a bad amp/loose power > > connection on your amp/or not having a large enough or clean enough amp. If > > you are running your speakers off of the tiny, "I.C. chip" amp built into > > your radio/deck, and not using an external, "discreet" amplifier, it will > > blow speakers regularly, and most importantly, not sound anywhere nearly as > > good as it could with an external amp. There are some full explanations of > > these issues on my website: http://www.subsolutions.com under the "audio basics" > > and the "self install" sections, including this excerpt: > > > > > > > > ââ¬Â¦.Most speakers will handle more power than you think. What they can't > > handle is distortion. Distortion is what an amplifier puts out when it isn't > > big enough to play as loud as you would like it to. It's that extra, fuzzy > > sound over the top of your music when you reach the limit. All amplifiers > > distort when you turn them up past their maximum output limit. Your amp > > tries to amplify the small signal from your deck without altering its smooth > > shape. Your amp has a "voltage rail" limit of how big it can do that before > > it chops off the top and bottom of the sine wave, causing distortion-which > > will damage your speakers. > > To summarize, if your stereo is not loud enough, or if you've blown a > > speaker from distortion (which isn't covered under any warranty) and had to > > get another one, buy a bigger ampââ¬Â¦. > > > > > > > > So check these before you hook up your new speakers. `Important to > > understand, you can use the best speakers in the world, and they'll still > > blow from distortion (inversely, you can use fairly inexpensive speakers and > > achieve quite high performance, using a "clean" (low distortion) amp). > > > > > > > > > > > > \/\/\ââ¬Â¦Fred > > __________________ > > *Fred & Wendy Bellows* > > Queen Creek, AZ (*so.east Phx*) > > '90 SP36 > > *"Maunder Maximum"* > > photos of coach and upgrades<http://picasaweb.google.com/Bluebirdzoom/MaunderMaximum> > > *current location <http://www.bbirdmaps.com/user1.cfm?user=125%20> * > > > > > > > |
