Front heat shutoff - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Front heat shutoff (/showthread.php?tid=8311) |
Front heat shutoff - williamcharrison - 07-20-2009 05:27 The cockpit in our bird is roasting unless I shut off heater water flow at the engine. There is a solenoid valve in line near the front center of the coach which I disassembled and cleaned. I ordered 2 Sporlan valve repair kits but this valve has a piston at least twice the size of the Sporlan. I would have assumed that this valve was energized to operate (normally closed) and I can't get access to the leads going into the solenoid. What are my options? Chuck Harrison Akron, Ohio 90 SP36 |
