| Air Leaks - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Leaks (/showthread.php?tid=8406) |
| Air Leaks - dspithaler - 08-29-2009 13:14 Hi Guys I was chasing down some small air leaks & found some in my push on plastic fittings & a pipe fitting at my steps. I found a 1/4" copper tube dropping down in front of my battery box front street side. It is not connected to any thing & there is nothing there to connect it to. It is leaking enough air that it drains my auxiliary tank over night. Does any one know where this tube go's to? I though it went to my park brake to release the air but when I released the brake the air didn't exit there. Don Spithaler 89 SP 36' Butler, PA Air Leaks - gregoryoconnor - 08-29-2009 16:31 maybe it is an exhaust and the ram it exhaust or the valve is leaking. if you plug it up the steps may not retract?????? that may narrow your search Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "dspithaler" > > Hi Guys > I was chasing down some small air leaks & found some in my push on plastic fittings & a pipe fitting at my steps. I found a 1/4" copper tube dropping down in front of my battery box front street side. It is not connected to any thing & there is nothing there to connect it to. It is leaking enough air that it drains my auxiliary tank over night. Does any one know where this tube go's to? I though it went to my park brake to release the air but when I released the brake the air didn't exit there. > Don Spithaler > 89 SP 36' > Butler, PA > Air Leaks - Jerry Collum - 08-30-2009 00:49  The front air conditioner condensation tube on my rig comes out near the same location. Maybe???  jco2
 Air Leaks - Donald Spithaler - 08-30-2009 12:12 I plugged it up with a fitting & everything is working. My park brake works & my service brakes work. I just can't find where it goes to.       Don Spitrhaler 89 SP 36' Butler, PA                                                             Aug 30, 2009 at 8:49 AM, Jerry Collum <"jcollum@panaband.com"> wrote:
