| Perkins Gen-set - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Perkins Gen-set (/showthread.php?tid=8426) Pages:  1 2  |
| Perkins Gen-set - dru penland - 09-08-2009 05:18 Hellos All! Just got back fro a mini trip and lost one leg of my generator. When I fired it up and transferred from shore to gen, the Perkins took a little dip in rpm and I lost the curb side power. I didn't find any circuit breakers tripped and the volt meter on the info panel shows no voltage on that one side. Are there other protections that could have tripped or am I into major repairs? Thanks! Dru and Debora Corpus Christi, TX 1983 FC 35 RB Steady Gittin' It! Perkins Gen-set - Ralph Fullenwider - 09-08-2009 06:07 Dru: Have you checked the breakers located in the gen set compartment on the curb side wall? Re sent those, then if no power, remove the cover and check voltage on both sides of bother breakers to be sure it is not a faulty breaker. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 10:18 AM 9/8/2009 -0700, you wrote: Hellos All! Perkins Gen-set - dru penland - 09-08-2009 06:52 Thank you so much, Ralph! I can't wait for the clock to 4 so I can go check it out. I felt sick when this happened to me. I just felt $$$ coming out of my pocket. It appears from the wiring schematic that the fan motor for the generator radiator is 220v. It's running like it always has. If it's truly 220v then I should have full power on the back side of these breakers you are referring to? That would be so FANTASTIC! Thanks again, Dru and Debora Corpus Christi, TX 1983 FC 35 RB Steady Gittin' It! From: Ralph Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, September 8, 2009 1:07:52 PM Subject: Re: [WanderlodgeForum] Perkins Gen-set Dru: Have you checked the breakers located in the gen set compartment on the curb side wall? Re sent those, then if no power, remove the cover and check voltage on both sides of bother breakers to be sure it is not a faulty breaker. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 10:18 AM 9/8/2009 -0700, you wrote: Hellos All! Perkins Gen-set - Bernard Haag - 09-08-2009 06:59 can anyone inform me on how to run the two power converters or where can I have them serviced? thanks..Bernie From: Ralph Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, September 8, 2009 12:07:52 PM Subject: Re: [WanderlodgeForum] Perkins Gen-set Dru: Have you checked the breakers located in the gen set compartment on the curb side wall? Re sent those, then if no power, remove the cover and check voltage on both sides of bother breakers to be sure it is not a faulty breaker. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 10:18 AM 9/8/2009 -0700, you wrote: Hellos All! Perkins Gen-set - Ralph Fullenwider - 09-08-2009 07:00 Oh, and reset the lower left GFI breaker in the main panel in the closet, if it is leg 2. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 11:52 AM 9/8/2009 -0700, you wrote: Thank you so much, Ralph! I can't Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma |
| Perkins Gen-set - Ralph Fullenwider - 09-08-2009 08:28 Hi Bernie: We will need a little more info on your Coach, like year, FC/PT/BMC then we need to define "converter" do you mean the battery chargers or the inverters? Are they Trace Heart 2000, 2500 and so forth. Take a look at my signature line, this give where I am located, give or take, the type of Coach and year, the info helps to help you. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 11:59 AM 9/8/2009 -0700, you wrote: >can anyone inform me on how to run the two power converters or where can I >have them serviced? thanks..Bernie > > Perkins Gen-set - Bernard Haag - 09-09-2009 00:50 thanks for the quick response, I will get that for you, she is in the shop today.... From: Ralph Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, September 8, 2009 2:28:27 PM Subject: Re: [WanderlodgeForum] Perkins Gen-set Hi Bernie: We will need a little more info on your Coach, like year, FC/PT/BMC then we need to define "converter" do you mean the battery chargers or the inverters? Are they Trace Heart 2000, 2500 and so forth. Take a look at my signature line, this give where I am located, give or take, the type of Coach and year, the info helps to help you. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 11:59 AM 9/8/2009 -0700, you wrote: >can anyone inform me on how to run the two power converters or where can I >have them serviced? thanks..Bernie > > Perkins Gen-set - dru penland - 09-10-2009 01:04 THANK YOU, THANK YOU, THANK YOU!!! It's the breaker in the generator house.It won't close the circuit. Looks a little toasty, as well.  Your too good and too kind with your knowledge.Thanks again!Dru and Debora Corpus Christi, TX 1983 FC 35 RB Steady Gittin' It! From: Ralph Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, September 8, 2009 2:00:20 PM Subject: Re: [WanderlodgeForum] Perkins Gen-set Oh, and reset the lower left GFI breaker in the main panel in the closet, if it is leg 2. Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 11:52 AM 9/8/2009 -0700, you wrote: Thank you so much, Ralph! I can't wait for the clock to 4 so I can go check it out. I felt sick when this happened to me. I just felt $$$ coming out of my pocket. It appears from the wiring schematic that the fan motor for the generator radiator is 220v. It's running like it always has. If it's truly 220v then I should have full power on the back side of these breakers you are referring to? That would be so FANTASTIC! Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma Perkins Gen-set - gregoryoconnor - 09-10-2009 05:04 a blown fuse and circuit breaker are usually the result of a problem and not the problem. I once viewed a consumer watchdog news sting where a woman car owner went into a auto repair shop for 'windshield wiper not turning on repair'. several shops replaced the news team installed bad fuse and sent her on her way. One shop spent a methodical 3/4 hour trying to figure why the fuses blew respecting the customers safety in probable traffic during a downpour which is the test period for repair. I felt the shops in error were those only replacing the fuse and not researching or finding the problem. One issue I know very little about is lost neutral and the return of ac current thru the other leg????????? A heat cooked breaker can be the genset ambient environment or the tripping damage of the breaker doing its job One other issue is the bonding of a genset made ac within a motorhome. I can only assume that it is to be onboard bonded unlike onboard bonding or shorepower ac. Just flipping a switch and repowering 50 amps without finding the problem can cause 49 amp of hurt when a repeat of the event that caused the trip shows different result. I test my swimmingpool light with a tennisball. It's difficult to get a dog to turn on the toaster in my bus so I would look for the true problem and not the quick fix. Greg ofTim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, dru penland > > THANK YOU, THANK YOU, THANK YOU!!! > > It's the breaker in the generator house. It won't close the circuit. Looks a little toasty, as well. > > Your too good and too kind with your knowledge. Thanks again! > Dru and Debora > Corpus Christi, TX > 1983 FC 35 RB > Steady Gittin' It! > > > > > ________________________________ > From: Ralph Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, September 8, 2009 2:00:20 PM > Subject: Re: [WanderlodgeForum] Perkins Gen-set > > > Oh, and reset the lower left GFI breaker in the main panel in the closet, if it is leg 2. > > Safe travels, > > Ralph & Charolette Fullenwider > '84 FC 35 "Ruff Diamond" > Duncan, Oklahoma > > At 11:52 AM 9/8/2009 -0700, you wrote: > > > > Thank you so much, Ralph! I can't wait for the clock to 4 so I can go check it out. I felt sick when this happened to me. I just felt $$$ coming out of my pocket. It appears from the wiring schematic that the fan motor for the generator radiator is 220v. It's running like it always has. If it's truly 220v then I should have full power on the back side of these breakers you are referring to? That would be so FANTASTIC! > > > >Thanks again, > > > >Dru and Debora > >Corpus Christi, TX > >1983 FC 35 RB > >Steady Gittin' It! > > > > > > > > > >Dru: > > > >Have you checked the breakers located in the gen set compartment on the curb side wall? Re sent those, then if no power, remove the cover and check voltage on both sides of bother breakers to be sure it is not a faulty breaker. > > > > Safe travels, > > > >Ralph & Charolette Fullenwider > >'84 FC 35 "Ruff Diamond" > >Duncan, Oklahoma > > > >At 10:18 AM 9/8/2009 -0700, you wrote: > > > > > > > >Hellos All! > >> > >>Just got back fro a mini trip and lost one leg of my generator. When I fired it up and transferred from shore to gen, the Perkins took a little dip in rpm and I lost the curb side power. I didn't find any circuit breakers tripped and the volt meter on the info panel shows no voltage on that one side. Are there other protections that could have tripped or am I into major repairs? > >> > >> > >>Thanks! > >> > >>Dru and Debora > >>Corpus Christi, TX > >>1983 FC 35 RB > >>Steady Gittin' It! > >> > >> > >> > > > > > Safe travels, > > Ralph & Charolette Fullenwider > '84 FC 35 "Ruff Diamond" > Duncan, Oklahoma > Perkins Gen-set - freewill2008 - 09-10-2009 06:03 I totally agree with Greg about being sure there is not an overload in the bus causing the tripped breaker - but it is worth noting that AC breakers can run a bit hot even when the electrical load is within the rating. As a result, the breaker can "break down" after 26 years and should probably be replaced. The same is true of the breakers in the panel of your RV or your house. They don't last forever. Finally, a breaker is designed to support a continuous load that is 80% of the rating, so a 50 amp breaker should only be loaded to 40 amps, etc. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "gregoryoconnor" > > a blown fuse and circuit breaker are usually the result of a problem and not the problem. > > I once viewed a consumer watchdog news sting where a woman car owner went into a auto repair shop for 'windshield wiper not turning on repair'. several shops replaced the news team installed bad fuse and sent her on her way. One shop spent a methodical 3/4 hour trying to figure why the fuses blew respecting the customers safety in probable traffic during a downpour which is the test period for repair. I felt the shops in error were those only replacing the fuse and not researching or finding the problem. > > One issue I know very little about is lost neutral and the return of ac current thru the other leg????????? A heat cooked breaker can be the genset ambient environment or the tripping damage of the breaker doing its job > > One other issue is the bonding of a genset made ac within a motorhome. I can only assume that it is to be onboard bonded unlike onboard bonding or shorepower ac. > > Just flipping a switch and repowering 50 amps without finding the problem can cause 49 amp of hurt when a repeat of the event that caused the trip shows different result. > > I test my swimmingpool light with a tennisball. It's > difficult to get a dog to turn on the toaster in my bus so I would look for the true problem and not the quick fix. > > Greg ofTim&Greg > 94ptca > > > --- In WanderlodgeForum@yahoogroups.com, dru penland > > > > THANK YOU, THANK YOU, THANK YOU!!! > > > > It's the breaker in the generator house. It won't close the circuit. Looks a little toasty, as well. > > > > Your too good and too kind with your knowledge. Thanks again! > > Dru and Debora > > Corpus Christi, TX > > 1983 FC 35 RB > > Steady Gittin' It! > > > > > > > > > > ________________________________ > > From: Ralph Fullenwider > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, September 8, 2009 2:00:20 PM > > Subject: Re: [WanderlodgeForum] Perkins Gen-set > > > > > > Oh, and reset the lower left GFI breaker in the main panel in the closet, if it is leg 2. > > > > Safe travels, > > > > Ralph & Charolette Fullenwider > > '84 FC 35 "Ruff Diamond" > > Duncan, Oklahoma > > > > At 11:52 AM 9/8/2009 -0700, you wrote: > > > > > > > > Thank you so much, Ralph! I can't wait for the clock to 4 so I can go check it out. I felt sick when this happened to me. I just felt $$$ coming out of my pocket. It appears from the wiring schematic that the fan motor for the generator radiator is 220v. It's running like it always has. If it's truly 220v then I should have full power on the back side of these breakers you are referring to? That would be so FANTASTIC! > > > > > >Thanks again, > > > > > >Dru and Debora > > >Corpus Christi, TX > > >1983 FC 35 RB > > >Steady Gittin' It! > > > > > > > > > > > > > > >Dru: > > > > > >Have you checked the breakers located in the gen set compartment on the curb side wall? Re sent those, then if no power, remove the cover and check voltage on both sides of bother breakers to be sure it is not a faulty breaker. > > > > > > Safe travels, > > > > > >Ralph & Charolette Fullenwider > > >'84 FC 35 "Ruff Diamond" > > >Duncan, Oklahoma > > > > > >At 10:18 AM 9/8/2009 -0700, you wrote: > > > > > > > > > > > >Hellos All! > > >> > > >>Just got back fro a mini trip and lost one leg of my generator. When I fired it up and transferred from shore to gen, the Perkins took a little dip in rpm and I lost the curb side power. I didn't find any circuit breakers tripped and the volt meter on the info panel shows no voltage on that one side. Are there other protections that could have tripped or am I into major repairs? > > >> > > >> > > >>Thanks! > > >> > > >>Dru and Debora > > >>Corpus Christi, TX > > >>1983 FC 35 RB > > >>Steady Gittin' It! > > >> > > >> > > >> > > > > > > > > Safe travels, > > > > Ralph & Charolette Fullenwider > > '84 FC 35 "Ruff Diamond" > > Duncan, Oklahoma > > > |
