FUEL SOLENOID ON 8KW GENERATOR IN 87FC - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FUEL SOLENOID ON 8KW GENERATOR IN 87FC (/showthread.php?tid=8461) |
FUEL SOLENOID ON 8KW GENERATOR IN 87FC - sc310c - 09-26-2009 08:35 DOES ANYONE KNOW WHERE TO FIND ONE ITS THE SHUTOFF ONE. MINE TAKES 40 AMPPS TO KEEP IT ENGAGED TKS BOB MALONEY IN KY STILL FIGHTING FOR POWER FUEL SOLENOID ON 8KW GENERATOR IN 87FC - gregory O - 09-26-2009 10:25 BOB, Check the stroke of the arm. amp draw is a sign that somthing is making it hard to open. could be other linkage issues or somthing. I would just match it up at Napa. the newer diesels have two relays. one that pulls the solenoid in and one holds it in. in the past when I used a newer stype I connect both + lines to the 'hot when open + ignition line' GREGOFTIMANDGREG ($PTCA --- In WanderlodgeForum@yahoogroups.com, "sc310c" <sc310c@...> wrote: > > DOES ANYONE KNOW WHERE TO FIND ONE ITS THE SHUTOFF ONE. MINE TAKES 40 AMPPS TO KEEP IT ENGAGED > TKS BOB MALONEY IN KY STILL FIGHTING FOR POWER > FUEL SOLENOID ON 8KW GENERATOR IN 87FC - richardgideon - 09-27-2009 04:24 Bob: You probably will have to buy the "Stopping Solenoid" from Cummins since they own Onan. Part number is 0307-2546. Price around $200 bucks. Here is the link from buying the part. https://quickserve.cummins.com/genuineparts/0307-2546.html Dick Gideon 1989 FC35 Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "sc310c" <sc310c@...> wrote: > > DOES ANYONE KNOW WHERE TO FIND ONE ITS THE SHUTOFF ONE. MINE TAKES 40 AMPPS TO KEEP IT ENGAGED > TKS BOB MALONEY IN KY STILL FIGHTING FOR POWER > |
