Perkins Injector Pump Leaking (WARNING) - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Perkins Injector Pump Leaking (WARNING) (/showthread.php?tid=8464) |
Perkins Injector Pump Leaking (WARNING) - lcondosta - 09-27-2009 11:50 I had a bad diesel fuel smell in the gen set bay.This is the second time I had this problem and I tought I had corrected it but I was wrong.I found that the fuel shut off lever shaft was leaking. I removed the top injector pump cover replaced the two o rings on the fuel shut off shaft and the other fuel shaft and base gasket.This has corrected the problem. .I blead the injector pump and fuel lines and the engine was missing.I had this problem before and again the air filter was the problem. Now runs great. IAm posting this as a WARNING because I saw a Bluebird at our local Diesel shop that the gen set caught on fire and burnt the front end of the coach the owners escaped out the bedroom windows. Lee Condosta 85 PT 40 Holden Beach N.C Perkins Injector Pump Leaking (WARNING) - Ernie Ekberg - 09-27-2009 11:57 Lee thanks for the remnder. Mine was leaking and Bim and I pulled it and a shop in Billings relieved me of 500 bucks but no leak. Ernie in Ca installing wood and carpet. I make house calls ---------- Sent from AT&T's Wireless network using Mobile Email ------Original Message------ From: lcondosta To: Date: Sun, Sep 27, 2009 11:50 PM Subject: [WanderlodgeForum] Perkins Injector Pump Leaking (WARNING) I had a bad diesel fuel smell in the gen set bay.This is the second time I had this problem and I tought I had corrected it but I was wrong.I found that the fuel shut off lever shaft was leaking. I removed the top injector pump cover replaced the two o rings on the fuel shut off shaft and the other fuel shaft and base gasket.This has corrected the problem. .I blead the injector pump and fuel lines and the engine was missing.I had this problem before and again the air filter was the problem. Now runs great. IAm posting this as a WARNING because I saw a Bluebird at our local Diesel shop that the gen set caught on fire and burnt the front end of the coach the owners escaped out the bedroom windows. Lee Condosta 85 PT 40 Holden Beach N.C Perkins Injector Pump Leaking (WARNING) - sfedeli3 - 09-27-2009 22:15 Lee- can you share part numbers? Or were these "off the shelf" Buna o-rings? Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "lcondosta" > > I had a bad diesel fuel smell in the gen set bay.This is the second time I had this problem and I tought I had corrected it but I was wrong.I found that the fuel shut off lever shaft was leaking. I removed the top injector pump cover replaced the two o rings on the fuel shut off shaft and the other fuel shaft and base gasket.This has corrected the problem. .I blead the injector pump and fuel lines and the engine was missing.I had this problem before and again the air filter was the problem. Now runs great. IAm posting this as a WARNING because I saw a Bluebird at our local Diesel shop that the gen set caught on fire and burnt the front end of the coach the owners escaped out the bedroom windows. Lee Condosta 85 PT 40 Holden Beach N.C > Perkins Injector Pump Leaking (WARNING) - GARY MINKER - 10-01-2009 00:46
