Rear Parking Lights - They Work - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Rear Parking Lights - They Work (/showthread.php?tid=8504) |
Rear Parking Lights - They Work - Curt Sprenger - 10-10-2009 03:40 Thank you to everyone who responded! Went out to the bus, put the key in the ignition and turned to ON, pushed "R" on the trans. pad, set the Rear Parking switch to ON (LED came on) , walked to the back of the bus, found the Rear Parking and the Reverse lights shining bright. I'll add to my to-do-list to change the Rear Parking lights to also light up without having the ignition and trans R in the loop. Probable putÃÂ the switch in the battery charger compartment. I'll need to remember to turn them off! Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Rear Parking Lights - They Work - TimV - 10-10-2009 03:59 they might also be wired in to turn on with the security lights so test that function and the repercussions of a mod. Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Thank you to everyone who responded! > > Went out to the bus, put the key in the ignition and turned to ON, pushed > "R" on the trans. pad, set the Rear Parking switch to ON (LED came on) , > walked to the back of the bus, found the Rear Parking and the Reverse lights > shining bright. > > I'll add to my to-do-list to change the Rear Parking lights to also light up > without having the ignition and trans R in the loop. Probable put the > switch in the battery charger compartment. I'll need to remember to turn > them off! > > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > Rear Parking Lights - They Work - Eric - 10-10-2009 08:21 Curt, When you find out how to turn your rear parking lights on without having the key on and the bus in reverse please let us know. This would be a useful improvement. Although accidentally keeping them on when running down the road might be a bit irritating to the driver behind you. Eric Perplies 96 42 WBWL Rear Parking Lights - They Work - sfedeli3 - 10-10-2009 09:56 Eric and Curt, When I first got the coach, mine did not work- even in reverse- so I rewired the switch with 12V+ from another source. This way, I can turn them on while going forward or in reverse or even when I'm parked and need to hitch up the towed. I think that BB wired the dash switch to only have 12V+ when the shifter was in reverse. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Eric" > > > Curt, > > When you find out how to turn your rear parking lights on without having the key on and the bus in reverse please let us know. This would be a useful improvement. Although accidentally keeping them on when running down the road might be a bit irritating to the driver behind you. > > Eric Perplies > 96 42 WBWL > Rear Parking Lights - They Work - Curt Sprenger - 10-10-2009 12:41 Shane, Thanks. I'd like those lights to work from the dash switch but not the transmission. I'll do the checking/testing prior to implementing a final solution. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Sat, Oct 10, 2009 at 2:56 PM, sfedeli3 <"sfedeli3@comcast.net"> wrote:
Rear Parking Lights - They Work - Ernie Ekberg - 10-10-2009 14:17 i think shane wanted those to work when some moron came up from behind with his high beams on. ernie la mesa, ca eastbound tomorrow ---------- Sent from AT&T's Wireless network using Mobile Email ------Original Message------ From: sfedeli3 <sfedeli3@...> To: Date: Sat, Oct 10, 2009 09:56 PM Subject: [WanderlodgeForum] Re: Rear Parking Lights - They Work Eric and Curt, When I first got the coach, mine did not work- even in reverse- so I rewired the switch with 12V+ from another source. This way, I can turn them on while going forward or in reverse or even when I'm parked and need to hitch up the towed. I think that BB wired the dash switch to only have 12V+ when the shifter was in reverse. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Eric" > > > Curt, > > When you find out how to turn your rear parking lights on without having the key on and the bus in reverse please let us know. This would be a useful improvement. Although accidentally keeping them on when running down the road might be a bit irritating to the driver behind you. > > Eric Perplies > 96 42 WBWL > Rear Parking Lights - They Work - sfedeli3 - 10-10-2009 21:05 Abso-freakin'-lutely!!! --- In WanderlodgeForum@yahoogroups.com, "Ernie Ekberg" > > i think shane wanted those to work when some moron came up from behind with his high beams on. > ernie la mesa, ca eastbound tomorrow > > ---------- > Sent from AT&T's Wireless network using Mobile Email > > ------Original Message------ > From: sfedeli3 <sfedeli3@...> > To: > Date: Sat, Oct 10, 2009 09:56 PM > Subject: [WanderlodgeForum] Re: Rear Parking Lights - They Work > > Eric and Curt, > > When I first got the coach, mine did not work- even in reverse- so I rewired the switch with 12V+ from another source. This way, I can turn them on while going forward or in reverse or even when I'm parked and need to hitch up the towed. I think that BB wired the dash switch to only have 12V+ when the shifter was in reverse. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, "Eric" > > > > > > Curt, > > > > When you find out how to turn your rear parking lights on without having the key on and the bus in reverse please let us know. This would be a useful improvement. Although accidentally keeping them on when running down the road might be a bit irritating to the driver behind you. > > > > Eric Perplies > > 96 42 WBWL > > > |
