Fan hitting something - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fan hitting something (/showthread.php?tid=8513) |
Fan hitting something - hearthandhome20 - 10-13-2009 06:59 having an issue with the engine fan, we have recently changed all the belts due to age and since we had a couple of instances where the fan appears to hit something, we cannont locate what it is hitting, there are just nicks in the fan blades and are loud noise when this happens. It does not happen during idle, has anyone had this issue if so what to do. Fan hitting something - Ernie Ekberg - 10-13-2009 07:12
Fan hitting something - Ken Sann - 10-13-2009 07:14 Motor-mounts?
If they are failing, they can allow the torque to lift one side of the engine relative to the coach.
Ken Sann wannabe in SoCal
On Tue, Oct 13, 2009 at 11:59 AM, hearthandhome20 <"hearthandhome20@yahoo.com"> wrote:
Fan hitting something - gregory O - 10-13-2009 13:17 good call Ken --- In WanderlodgeForum@yahoogroups.com, Ken Sann > > Motor-mounts? > If they are failing, they can allow the torque to lift one side of the > engine relative to the coach. > > > Ken Sann > wannabe in SoCal > > > On Tue, Oct 13, 2009 at 11:59 AM, hearthandhome20 > > > > > > > having an issue with the engine fan, we have recently changed all the belts > > due to age and since we had a couple of instances where the fan appears to > > hit something, we cannont locate what it is hitting, there are just nicks in > > the fan blades and are loud noise when this happens. It does not happen > > during idle, has anyone had this issue if so what to do. > > > > > > > Fan hitting something - gregory O - 10-13-2009 13:23 you can check motormounts by jacking up the engine one side than the other (not by the pan). biggest reason they go bad is ;they stay saturated with oil from a leak or ;someone is a pressure washer fanatic. Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "gregory O" > > good call Ken > > --- In WanderlodgeForum@yahoogroups.com, Ken Sann > > > > Motor-mounts? > > If they are failing, they can allow the torque to lift one side of the > > engine relative to the coach. > > > > > > Ken Sann > > wannabe in SoCal > > > > > > On Tue, Oct 13, 2009 at 11:59 AM, hearthandhome20 > > > > > > > > > > > having an issue with the engine fan, we have recently changed all the belts > > > due to age and since we had a couple of instances where the fan appears to > > > hit something, we cannont locate what it is hitting, there are just nicks in > > > the fan blades and are loud noise when this happens. It does not happen > > > during idle, has anyone had this issue if so what to do. > > > > > > > > > > > > |
