How can I start a DD Series 60 if I run out of fuel? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: How can I start a DD Series 60 if I run out of fuel? (/showthread.php?tid=8569) Pages: 1 2 |
How can I start a DD Series 60 if I run out of fuel? - Eric - 10-30-2009 17:41 I have not run this bird out of fuel. I have been known to run the tank pretty low though. What steps are necessary to restart the DD Series 60 engine in the event that I should run it out of fuel? Is this when I should use the ether injection system??? Eric Perplies 96' 42' WBWL How can I start a DD Series 60 if I run out of fuel? - Bernard Haag - 10-31-2009 02:41
How can I start a DD Series 60 if I run out of fuel? - gregory O - 10-31-2009 04:01 on many diesels the fuel is used to cool the injectors. on the 3208 the fuel tank will get warm as the engine runs. the fuel that gets pumped to the injector pump but doesn't get injected, passes the injectors on its way back to the tank. On many 1990+ engines the fuel is used also to cool the computer. If the tank is let to run too low, there is less fuel to deal with the calories so the ability to adequately dissipate reduced. The tank will get hot to the touch. I cooked a computer in a 92 N-14 during the $6.00 fuel price period while buying fuel like a commodity . my cooked computer was a result not the problem. It is good to always learn the cause. On my 92N-14 the engineered tank that 'Ford Truck' ( now 'Sterling truck' installed sent a low fuel signal light and buzzer to the cab. Ipreviously replaced the OEM tanks with a cool looking aluminum 200 gal set and never considered hooking up what I thought was a simple "get some fuel" idiot light and alarm. Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, Bernard Haag <bhaagrealtor@...> wrote: > > you need ot take your fuel filters off and refill them, if you completely ran out, if it just started to sput and spirt then fill fuel tank and try to restart but be careful on the time you keep your starter inguaged. Another way is to take WD-40 and spray into Air Cleaner and let her run on that until she picks up prime... > > --- On Fri, 10/30/09, Eric > > > From: Eric fuel? > To: WanderlodgeForum@yahoogroups.com > Date: Friday, October 30, 2009, 11:41 PM > > > > > > > I have not run this bird out of fuel. I have been known to run the tank pretty low though. What steps are necessary to restart the DD Series 60 engine in the event that I should run it out of fuel? Is this when I should use the ether injection system??? > > Eric Perplies > 96' 42' WBWL > How can I start a DD Series 60 if I run out of fuel? - ronmarabito2002 - 10-31-2009 04:33 Greg: The man asked a simple question. Give him a simple answer, not a seminar about why it happened. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "gregory O" > > on many diesels the fuel is used to cool the injectors. on the 3208 the fuel tank will get warm as the engine runs. the fuel that gets pumped to the injector pump but doesn't get injected, passes the injectors on its way back to the tank. > > On many 1990+ engines the fuel is used also to cool the computer. If the tank is let to run too low, there is less fuel to deal with the calories so the ability to adequately dissipate reduced. The tank will get hot to the touch. I cooked a computer in a 92 N-14 during the $6.00 fuel price period while buying fuel like a commodity . > > my cooked computer was a result not the problem. It is good to always learn the cause. On my 92N-14 the engineered tank that 'Ford Truck' ( now 'Sterling truck' installed sent a low fuel signal light and buzzer to the cab. Ipreviously replaced the OEM tanks with a cool looking aluminum 200 gal set and never considered hooking up what I thought was a simple "get some fuel" idiot light and alarm. > > Greg > 94ptca > > > > --- In WanderlodgeForum@yahoogroups.com, Bernard Haag <bhaagrealtor@> wrote: > > > > you need ot take your fuel filters off and refill them, if you completely ran out, if it just started to sput and spirt then fill fuel tank and try to restart but be careful on the time you keep your starter inguaged. Another way is to take WD-40 and spray into Air Cleaner and let her run on that until she picks up prime... > > > > --- On Fri, 10/30/09, Eric > > > > > > From: Eric fuel? > > To: WanderlodgeForum@yahoogroups.com > > Date: Friday, October 30, 2009, 11:41 PM > > > > > > > > > > > > > > I have not run this bird out of fuel. I have been known to run the tank pretty low though. What steps are necessary to restart the DD Series 60 engine in the event that I should run it out of fuel? Is this when I should use the ether injection system??? > > > > Eric Perplies > > 96' 42' WBWL > > > How can I start a DD Series 60 if I run out of fuel? - David Brady - 10-31-2009 04:35 If you're gonna inject ether, make sure the starter is cranking the engine before you do. If not, the ether can lock up the engine. David Brady '02 LXi, NC -----Original Message----- How can I start a DD Series 60 if I run out of fuel? - gregory O - 10-31-2009 04:56 1.refuel 2.prime 3.purge 4.turn key Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002" wrote: > > Greg: The man asked a simple question. Give him a simple answer, not a seminar about why it happened. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > > --- In WanderlodgeForum@yahoogroups.com, "gregory O" > > > > on many diesels the fuel is used to cool the injectors. on the 3208 the fuel tank will get warm as the engine runs. the fuel that gets pumped to the injector pump but doesn't get injected, passes the injectors on its way back to the tank. > > > > On many 1990+ engines the fuel is used also to cool the computer. If the tank is let to run too low, there is less fuel to deal with the calories so the ability to adequately dissipate reduced. The tank will get hot to the touch. I cooked a computer in a 92 N-14 during the $6.00 fuel price period while buying fuel like a commodity . > > > > my cooked computer was a result not the problem. It is good to always learn the cause. On my 92N-14 the engineered tank that 'Ford Truck' ( now 'Sterling truck' installed sent a low fuel signal light and buzzer to the cab. Ipreviously replaced the OEM tanks with a cool looking aluminum 200 gal set and never considered hooking up what I thought was a simple "get some fuel" idiot light and alarm. > > > > Greg > > 94ptca > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, Bernard Haag <bhaagrealtor@> wrote: > > > > > > you need ot take your fuel filters off and refill them, if you completely ran out, if it just started to sput and spirt then fill fuel tank and try to restart but be careful on the time you keep your starter inguaged. Another way is to take WD-40 and spray into Air Cleaner and let her run on that until she picks up prime... > > > > > > --- On Fri, 10/30/09, Eric > > > > > > > > > From: Eric fuel? > > > To: WanderlodgeForum@yahoogroups.com > > > Date: Friday, October 30, 2009, 11:41 PM > > > > > > > > > > > > > > > > > > > > > I have not run this bird out of fuel. I have been known to run the tank pretty low though. What steps are necessary to restart the DD Series 60 engine in the event that I should run it out of fuel? Is this when I should use the ether injection system??? > > > > > > Eric Perplies > > > 96' 42' WBWL > > > > > > How can I start a DD Series 60 if I run out of fuel? - freewill2008 - 10-31-2009 05:31 Greg - Thanks for that great titbit of information. I feel better about hauling all that fuel around instead of "running on empty". Bob Griesel '84 FC31 WLII, 3208 of course. --- In WanderlodgeForum@yahoogroups.com, "gregory O" > > on many diesels the fuel is used to cool the injectors. on the 3208 the fuel tank will get warm as the engine runs. the fuel that gets pumped to the injector pump but doesn't get injected, passes the injectors on its way back to the tank. > > On many 1990+ engines the fuel is used also to cool the computer. If the tank is let to run too low, there is less fuel to deal with the calories so the ability to adequately dissipate reduced. The tank will get hot to the touch. I cooked a computer in a 92 N-14 during the $6.00 fuel price period while buying fuel like a commodity . > > my cooked computer was a result not the problem. It is good to always learn the cause. On my 92N-14 the engineered tank that 'Ford Truck' ( now 'Sterling truck' installed sent a low fuel signal light and buzzer to the cab. Ipreviously replaced the OEM tanks with a cool looking aluminum 200 gal set and never considered hooking up what I thought was a simple "get some fuel" idiot light and alarm. > > Greg > 94ptca > > > > --- In WanderlodgeForum@yahoogroups.com, Bernard Haag <bhaagrealtor@> wrote: > > > > you need ot take your fuel filters off and refill them, if you completely ran out, if it just started to sput and spirt then fill fuel tank and try to restart but be careful on the time you keep your starter inguaged. Another way is to take WD-40 and spray into Air Cleaner and let her run on that until she picks up prime... > > > > --- On Fri, 10/30/09, Eric > > > > > > From: Eric fuel? > > To: WanderlodgeForum@yahoogroups.com > > Date: Friday, October 30, 2009, 11:41 PM > > > > > > > > > > > > > > I have not run this bird out of fuel. I have been known to run the tank pretty low though. What steps are necessary to restart the DD Series 60 engine in the event that I should run it out of fuel? Is this when I should use the ether injection system??? > > > > Eric Perplies > > 96' 42' WBWL > > > How can I start a DD Series 60 if I run out of fuel? - Ron Thompson - 10-31-2009 05:49
How can I start a DD Series 60 if I run out of fuel? - David Brady - 10-31-2009 06:19 One of the many parameters I can monitor with my VMSpc is fuel temperature. I pump it in and it's at a cool 80 deg. I ascend of few hills out west and it gets hot: 125 to 150 deg F. I wasn't aware that my DDEC IV is cooled by fuel. I'll have to investigate this... Fascinating info. David Brady '02 LXi, NC -----Original Message----- How can I start a DD Series 60 if I run out of fuel? - Rob Robinson - 10-31-2009 06:39 I didn't know about that low fuel signal. Learn something new everyday. 2009/10/31 gregory O <"greg@rainbowrv.com">
-- Rob, Sue and Joey Robinson 94 WLWB |
