Running/Driving Lights came on while hooked up to shore power - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Running/Driving Lights came on while hooked up to shore power (/showthread.php?tid=8593) |
Running/Driving Lights came on while hooked up to shore power - luckyron1 - 11-07-2009 03:48 We came home to the smell of burnt electrical inside of the coach and then I noticed that the ground in front of the coach was illuminated. The Running/Driving lights were on. The dash switch was in the off position. I located the fuse in the outside panel, pulled it and they went off. Put it back in and they went back on. I fooled with the dash switch and it seems to work ok. Have the fuse out for now and the smell of burnt electrical is gone. ?????? San Antonio until Christmas Running/Driving Lights came on while hooked up to shore power - Ralph Fullenwider - 11-07-2009 04:42 Hi Ron: That circuit is controlled by a relay and the switch controls the coil of that relay allowing the VDC to pass to the lights. So if the switch is good, (use a meter to know for sure on ohms scale) then the relay is picked up. Now then if the switch is in fact open/off then the wiring smell may be the circuit is made by melted and shorted wire. This makes me wonder what else maybe having a problem in there. The relay is located on the large print in your black case. Start from there Safe travels, Ralph & Charolette Fullenwider '84 FC 35 "Ruff Diamond" Duncan, Oklahoma At 03:48 PM 11/7/2009 +0000, you wrote: >We came home to the smell of burnt electrical inside of the coach and then >I noticed that the ground in front of the coach was illuminated. The >Running/Driving lights were on. The dash switch was in the off >position. I located the fuse in the outside panel, pulled it and they >went off. Put it back in and they went back on. I fooled with the dash >switch and it seems to work ok. Have the fuse out for now and the smell >of burnt electrical is gone. > >?????? > >San Antonio until Christmas > > Running/Driving Lights came on while hooked up to shore power - GARY MINKER - 11-15-2009 03:05
