Batteries follow up - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Batteries follow up (/showthread.php?tid=8623) |
Batteries follow up - mariopatti1 - 11-14-2009 15:37 Hi all FYI after all the info recieved from the forum I cleaned all the battery post , filled each cell turned everything off including the switch under the dash board . I moved the bus a little to recieve more direct sun for the solar panel . Left the bus with 12.3v on the panel. Came back two days later 12.5v on the panel.I think I'm good to go . Will see when I get back in Dec. Mario 1985FC35 on the way to Marthas Vineyard Batteries follow up - Fred Hulse - 11-14-2009 15:45 Mario
Have a safe trip and enjoy the East Coast.
We hope you can come to Q this January.We are looking forward to visiting again.
Fred & Jeanne Hulse & Girls
Morristown Arizona 1997 Wanderlodge WLWB41 Batteries follow up - Ernie Ekberg - 11-15-2009 02:01
Batteries follow up - mariopatti1 - 12-03-2009 18:42 Hi All Back from cloudy rainy North East to a sunny SOCAL . A last follow up on the batteries . Found the batteries at 13 volts . Very happy . Mario 1985FC35 --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > Hi all > FYI after all the info recieved from the forum I cleaned all the battery post , filled each cell turned everything off including the switch under the dash board . I moved the bus a little to recieve more direct sun for the solar panel . Left the bus with 12.3v on the panel. > Came back two days later 12.5v on the panel.I think I'm good to go . > Will see when I get back in Dec. > Mario 1985FC35 on the way to Marthas Vineyard > Batteries follow up - sfedeli3 - 12-03-2009 20:30 Mario- glad that you are home safe. Hope to see you at Q. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > Hi All > Back from cloudy rainy North East to a sunny SOCAL . > A last follow up on the batteries . Found the batteries at 13 volts . > Very happy . > Mario 1985FC35 > > --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > > > Hi all > > FYI after all the info recieved from the forum I cleaned all the battery post , filled each cell turned everything off including the switch under the dash board . I moved the bus a little to recieve more direct sun for the solar panel . Left the bus with 12.3v on the panel. > > Came back two days later 12.5v on the panel.I think I'm good to go . > > Will see when I get back in Dec. > > Mario 1985FC35 on the way to Marthas Vineyard > > > |
