Trans Cooling fans - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Trans Cooling fans (/showthread.php?tid=8646) |
Trans Cooling fans - mcmike1952 - 11-21-2009 06:08 On my 96 42' Wanderlodge there is a cooler mounted on the drivers side of the coach forward of the radiator. There are two electric cooling fans mounted to it. They appear to be controlled by a thermostat. Neither fan runs. Can someone tell me where the fuse is located for this circuit. Thanks, Mike McMahan 96 42' Wanderlodge Trans Cooling fans - Fred Hulse - 11-21-2009 06:39 Mike
The fuses are in the box where your rear start panel is
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Trans Cooling fans - mcmike1952 - 11-21-2009 13:56 Thanks Fred. I'll look tomorrow. Mike --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Mike > The fuses are in the box where your rear start panel is > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > Trans Cooling fans - Wayne Kotila - 11-21-2009 17:20 Mike: in that same box that Fred mentioned with the fuse for the hydraulic system cooling fans, there is a relay for the fans. I think the temp. switch that controls them is mounted to the bottom of the big blue hydraulic resevoir. One of my fans was bad and I just replaced it today.
Wayne
96WBPT42
From: mcmike1952 <mmcmahan@...> To: WanderlodgeForum@yahoogroups.com Sent: Sat, November 21, 2009 12:08:40 PM Subject: [WanderlodgeForum] Trans Cooling fans On my 96 42' Wanderlodge there is a cooler mounted on the drivers side of the coach forward of the radiator. There are two electric cooling fans mounted to it. They appear to be controlled by a thermostat. Neither fan runs. Can someone tell me where the fuse is located for this circuit. Thanks, Mike McMahan 96 42' Wanderlodge |
