Cabinet Hinge - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Cabinet Hinge (/showthread.php?tid=8648) |
Cabinet Hinge - contrail Bob - 11-21-2009 12:15 I have a broken hinge on one of my kitchen cabinet's. Is this hinge avilable at home-depot or lowe's? or?...It's the standard wanderlodge hinge that's adjustable. Thanks Bob&Carol 99LX Bunker Hill, Il. Cabinet Hinge - Wallace Craig - 11-21-2009 15:09
Cabinet Hinge - Fred Hulse - 11-21-2009 15:44 I have seen those hinges at Hardware stores quite often.
Supply should be easy.
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Cabinet Hinge - morey - 11-21-2009 16:16 This is a Blum hinge, it will clip on & off the airplane wing plate. Do not mremove the plate, just unclip the door from the plates on the cabinet. Then unscrew the hinge from the door and install the new one. This should be the hinge: http://www.cabinetmakerssupply.com/clip_107_deg_hinge_cabinet_cliptop_and_clip_1\ 07_deg_opening_angle_3280_prd1.htm Cabinet Hinge - morey - 11-21-2009 16:19 --- In WanderlodgeForum@yahoogroups.com, "morey" > > > > This is a Blum hinge, it will clip on & off the airplane wing plate. Do not mremove the plate, just unclip the door from the plates on the cabinet. Then unscrew the hinge from the door and install the new one. > > This should be the hinge: > > http://www.cabinetmakerssupply.com/clip_107_deg_hinge_cabinet_cliptop_and_clip_1\ 07_deg_opening_angle_3280_prd1.htm > Sorry, MoreyZ 99LXi41 Cumming, GA |
