Black Water tank - 1984 FC35SB - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Black Water tank - 1984 FC35SB (/showthread.php?tid=8662) |
Black Water tank - 1984 FC35SB - hippieforever3 - 11-27-2009 10:52 ANY info on the BW tank would be appreciated. P/N - equivalent, true dimensions (sans foam) , etc It looks like I'm going to have to get one ordered and installed. Any leads on the above will make my wait time shorter. Regards, GPSGary __________________ GPSGary 1984FC35SB Black Water tank - 1984 FC35SB - hippieforever3 - 11-27-2009 11:31 I believe I found the BB P/N - 1122704 Can anyone help with any additional info useful in finding one or a reasonable replacement? Regards, __________________ GPSGary 1984FC35SB > Black Water tank - 1984 FC35SB - hippieforever3 - 11-30-2009 09:28 I chipped away some of the insulating foam looking for a part number and unless I'm dreaming, the black water tank is METAL ??? Can someone confirm this or is it a metal pan around the real tank. Can anyone that's seen the outlet fitting tell me what it's like.? A previous owner has wrapped the pipe between the tank wall and the valve with something like fiberglass (or glued blue jeans) and I'm really reluctant to cut it off because if this sucker starts leaking really bad they will throw us out of the park we're in and a motel with 3 dogs isn't a very viable option. I was considering having the tank replaced but if it's not plastic and is metal that is more repairable and someone totally different. Regards, Black Water tank - 1984 FC35SB - Ralph - 11-30-2009 09:40 One my '84 they are fiberglass tanks. I recently replaced the Dupree valve on my grey tank. It was dicey but formed the new valve and a repair insert with a dremmel and with the help of Bim Burt, glued every thing back in tight with no leaks and painted black to match. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "hippieforever3" Date: Mon, 30 Nov 2009 21:28:02 To: Subject: [WanderlodgeForum] Re: Black Water tank - 1984 FC35SB I chipped away some of the insulating foam looking for a part number and unless I'm dreaming, the black water tank is METAL ??? Can someone confirm this or is it a metal pan around the real tank. Can anyone that's seen the outlet fitting tell me what it's like.? A previous owner has wrapped the pipe between the tank wall and the valve with something like fiberglass (or glued blue jeans) and I'm really reluctant to cut it off because if this sucker starts leaking really bad they will throw us out of the park we're in and a motel with 3 dogs isn't a very viable option. I was considering having the tank replaced but if it's not plastic and is metal that is more repairable and someone totally different. Regards, ------------------------------------ Yahoo! Groups Links Black Water tank - 1984 FC35SB - hippieforever3 - 11-30-2009 14:11 Ralph does it again. Fiberglass I can deal with. Regards, GPSGary --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > One my '84 they are fiberglass tanks. I recently replaced the Dupree valve on my grey tank. It was dicey but formed the new valve and a repair insert with a dremmel and with the help of Bim Burt, glued every thing back in tight with no leaks and painted black to match. > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "hippieforever3" > Date: Mon, 30 Nov 2009 21:28:02 > To: > Subject: [WanderlodgeForum] Re: Black Water tank - 1984 FC35SB > > I chipped away some of the insulating foam looking for a part number and unless I'm dreaming, the black water tank is METAL ??? > > Can someone confirm this or is it a metal pan around the real tank. > > Can anyone that's seen the outlet fitting tell me what it's like.? > > A previous owner has wrapped the pipe between the tank wall and the valve with something like fiberglass (or glued blue jeans) and I'm really reluctant to cut it off because if this sucker starts leaking really bad they will throw us out of the park we're in and a motel with 3 dogs isn't a very viable option. > > I was considering having the tank replaced but if it's not plastic and is metal that is more repairable and someone totally different. > > Regards, > > > > ------------------------------------ > > Yahoo! Groups Links > |
