Noisy relay - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Noisy relay (/showthread.php?tid=8669) |
Noisy relay - dreamcatcher7300 - 11-30-2009 05:58 Under my rear clothes closet there four metal boxes with four relays in each, one of these are setting up a high pitch harmonic sound that's very annoying, I've cleaned the contacts and stuffed insulation around the boxes, it helped some but not enough. Has anyone had this problem? if so what's the fix, are these relays available? Lee Brown 94WB 40 Noisy relay - GARY MINKER - 12-01-2009 10:10
Noisy relay - freewill2008 - 12-01-2009 10:50 Gary - Do you know any trick to get Grainger to sell to an individual? Our local Grainger just turns you away if you don't represent a company. PITA. Thanks. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, GARY MINKER > > It is a mechanically amplified and transmitted sound through the thing they are mounted on.Ã If it really eats your lunch, mount the boxes on Lord or some other rubber mounts from Grainger. > Gary > 85 pt-40 > http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=rubber+mounts&op=s\ earch&Ntt=rubber+mounts&N=0&sst=All > > --- On Mon, 11/30/09, dreamcatcher7300 <bat73@...> wrote: > > From: dreamcatcher7300 <bat73@...> > Subject: [WanderlodgeForum] Noisy relay > To: WanderlodgeForum@yahoogroups.com > Date: Monday, November 30, 2009, 12:58 PM > > > > > > > > Ã > > > > > > > > > > Under my rear clothes closet there four metal boxes with four relays in each, one of these are setting up a high pitch harmonic sound that's very annoying, I've cleaned the contacts and stuffed insulation around the boxes, it helped some but not enough. Has anyone had this problem? if so what's the fix, are these relays available? Lee Brown 94WB 40 > Noisy relay - GARY MINKER - 12-01-2009 23:56
Noisy relay - birdshill123 - 12-02-2009 10:50 Bob: Some Granger's can be difficult. Here is a solution. Go online and sign up for a cod account. Make up some company name like Bob's Rv Repairs Inc. You can then order online for local pickup. I have friend that did just that. We have a real company account and just walk in! Bruce 1988 FC35 Noisy relay - freewill2008 - 12-02-2009 11:11 Thanks Bruce. Great idea. Bob --- In WanderlodgeForum@yahoogroups.com, "birdshill123" wrote: > > > > Bob: > > Some Granger's can be difficult. Here is a solution. Go online and sign up for a cod account. Make up some company name like Bob's Rv Repairs Inc. You can then order online for local pickup. I have friend that did just that. We have a real company account and just walk in! > > > Bruce > > 1988 FC35 > Noisy relay - Ernie Ekberg - 12-02-2009 11:31
