Gas springs for compartment doors - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Gas springs for compartment doors (/showthread.php?tid=8671) |
Gas springs for compartment doors - zboy59 - 11-30-2009 17:02 I'm having some issues trying to find the correct replacements for the cargo bay and interior gas springs. I have the numbers FMR115 and FBN12C off the existing ones, but they don't cross reference anywhere I know that the H9412 is a replacement for the interior ... but what about the exterior one ? What kind of thrust lbs should I use ? It's an '86 PT40 ... THANKS !! Gas springs for compartment doors - Joe Garner - 11-30-2009 23:27 Orr and Orr is the place to got for these... http://www.orrorr.com/ Give them a call. I replaced pretty much all of them on my '87 PT40 with springs from them. HTH, Joe On Mon, Nov 30, 2009 at 9:02 PM, zboy59 <"martys@title-check.com"> wrote:
Gas springs for compartment doors - mrkane1952 - 12-01-2009 01:54 Greetings: Look for the force numbers on yours in the middle of the sequence of digits near the "F" number: on my exterior Stabilus units a typical example is "1657EE 0500N 307/09 A 5" which is a 500 Newton (metric unit of force) or about 110 lbs unit. The interior springs on my '87 were replaced by a previous owner with Supra 9" 35lb units. I recently replaced the exterior springs with FBN12K 500 Newton (~110 lb) Stabilus units from Orr and Orr. M.R.Kane 1987 PT40 currently Terrell, TX --- In WanderlodgeForum@yahoogroups.com, "zboy59" > > I'm having some issues trying to find the correct replacements for the cargo bay and interior gas springs. > > I have the numbers FMR115 and FBN12C off the existing ones, but they don't cross reference anywhere > > I know that the H9412 is a replacement for the interior ... but what about the exterior one ? What kind of thrust lbs should I use ? > > It's an '86 PT40 ... > > THANKS !! > |
