Water pressure regulator? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Water pressure regulator? (/showthread.php?tid=8709) |
Water pressure regulator? - chaunceyboyblu - 12-17-2009 05:13 Hello and Merry Christmas to everyone!!! We are in Olympia Washington now and are having a water issue. Been hooked up to water pressure and heard water outside this morning and it was spewing out from where hose goes into bus. Turned water off outside and went to pump and the pump kept running. So, it is the white plastic thing that the hose hooks to that is leaking. Does anyone know how to start with this problem? Do you do it from outside or inside? If it is the regulator does anyone know where to get a new one? Got the mattress up and looked under bed, but looks we may have to tear some carpet up?? Any help or suggestions would be greatly appreciated! Thanks so much! Robert & Teri Rahn 1988 pt40 Water pressure regulator? - chunkymar - 12-17-2009 06:40 By any chance is your fill switch on, this can cause the pump to keep running. --- In WanderlodgeForum@yahoogroups.com, "chaunceyboyblu" wrote: > > Hello and Merry Christmas to everyone!!! > > We are in Olympia Washington now and are having a water issue. Been hooked up to water pressure and heard water outside this morning and it was spewing out from where hose goes into bus. Turned water off outside and went to pump and the pump kept running. So, it is the white plastic thing that the hose hooks to that is leaking. Does anyone know how to start with this problem? Do you do it from outside or inside? If it is the regulator does anyone know where to get a new one? Got the mattress up and looked under bed, but looks we may have to tear some carpet up?? Any help or suggestions would be greatly appreciated! > > Thanks so much! > > Robert & Teri Rahn > 1988 pt40 > Water pressure regulator? - Markus Meyer - 12-17-2009 06:47 Has anyone else now gotten this same email for the 4th time? I wonder if there is an issue, or ifthe poster is posting the same message over and over again? Markus To: WanderlodgeForum@yahoogroups.com From: chaunceyboyblu@... Date: Thu, 17 Dec 2009 17:13:15 +0000 Subject: [WanderlodgeForum] Water pressure regulator?
We are in Olympia Washington now and are having a water issue. Been hooked up to water pressure and heard water outside this morning and it was spewing out from where hose goes into bus. Turned water off outside and went to pump and the pump kept running. So, it is the white plastic thing that the hose hooks to that is leaking. Does anyone know how to start with this problem? Do you do it from outside or inside? If it is the regulator does anyone know where to get a new one? Got the mattress up and looked under bed, but looks we may have to tear some carpet up?? Any help or suggestions would be greatly appreciated! Thanks so much! Robert & Teri Rahn 1988 pt40 Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. Sign up now. |
