FUEL TANK VENT - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: FUEL TANK VENT (/showthread.php?tid=8721) |
FUEL TANK VENT - jwasnewski - 12-23-2009 11:53 Merry Christmas to all. Home here for Christmas after running the Wisconsin and Virginia blizzards. Interesting to say the least with 3 inches of ice on the roads. This problem started with my Webasto not firing. I changed the main engine filters, the Webasto filter and the nozzle. I also cleaned the burn chamber. I started the bus and it ran for about 5 minutes and shut down. It ran out of fuel. I opened the Racor and looked inside the secondary fuel filter and empty. Weird. I then thought alge. I disconnected the inlet fuel line to the Racor and blew air to the fuel tank. The tank made a stress noise so I quit. Opened the fill cap and massive amounts of air escaped. I left the fill cap off, primed the engine, and ran it for an hour no issues. Found a broken fuel line on the Webasto. Tomorrows project. Conclusion on the engine problem. I suspect a wasp has built a nest in the fuel tank vent. Anyone know where to look for the vent on a 90 300 gallon tank. Not on my drawings. Leroy Eckert 1990 WB-40 Smoke N Mirrors Dahlonega, GA FUEL TANK VENT - marvjeanm380 - 12-23-2009 11:57 Leroy: Do you think it is possible that water had gotten into the vent and frozen? After being in warmer weather I would give it another try. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "jwasnewski" > > Merry Christmas to all. > Home here for Christmas after running the Wisconsin and Virginia blizzards. Interesting to say the least with 3 inches of ice on the roads. > This problem started with my Webasto not firing. I changed the main engine filters, the Webasto filter and the nozzle. I also cleaned the burn chamber. I started the bus and it ran for about 5 minutes and shut down. It ran out of fuel. I opened the Racor and looked inside the secondary fuel filter and empty. Weird. I then thought alge. I disconnected the inlet fuel line to the Racor and blew air to the fuel tank. The tank made a stress noise so I quit. Opened the fill cap and massive amounts of air escaped. I left the fill cap off, primed the engine, and ran it for an hour no issues. Found a broken fuel line on the Webasto. Tomorrows project. > Conclusion on the engine problem. I suspect a wasp has built a nest in the fuel tank vent. Anyone know where to look for the vent on a 90 300 gallon tank. Not on my drawings. > > Leroy Eckert > 1990 WB-40 Smoke N Mirrors > Dahlonega, GA > FUEL TANK VENT - Ernie Ekberg - 12-23-2009 11:59
