VuQube - Ernie E - 01-04-2010 13:35
Anyone familiar with these receivers?
Ernie- needing something to watch the tube with
83PT40, Deming, Nm
VuQube - Rob Robinson - 01-04-2010 23:26
Ernie John Heckman has one I believe. He'll tell you what he thinks. He's not shy
2010/1/4 Ernie E <"ernietex@yahoo.com">
Â
83PT40, Deming, Nm
Rob, Sue and Joey Robinson
94 WLWB
VuQube - KP Marsh - 01-05-2010 02:32
Good Morning Ernie,
Yes we are very familiar with VuQube - as we have had one for more than a year and love it. Got it from Camping world and contacted Direct TVour selves rather than taking the converter box from Camping World. Took advantage of the introductory offer and have been using it for nearly a year now. Advantages are that it can be set up on the ground if you are in trees, all you need is a clear shot south. Takes about 5 minutes to set up with the controller. We also bought theladder mount and adapted it to be mounted on the goat rail so when we are somewhere with no trees we don't have to worry about someone stealing it or the wind blowing it over. We got ours in Stonewall so we have local stations when we are in Austin and as far away as San Antonio. The cube only weighs about 10# and can be stored in the toad or the coach when we travel. Power is from the cable connectionin thehook-up compartment. If you
have any questions give me a call - you have the number.
Ken and Patti Marsh
Towanda - 89 WBWL PT40
--- On Mon, 1/4/10, Ernie E wrote:
Subject: [WanderlodgeForum] VuQube
Date: Monday, January 4, 2010, 7:35 PM
83PT40, Deming, Nm
VuQube - jvredden@... - 01-05-2010 07:02
My father in law as one mounted on top of his class B Sprinter. He is very satisfied with it. Uses directv
john redden
91PT 40
North Carolina
In a message dated 1/5/2010 6:33:48 P.M. Eastern Standard Time, ernietex@... writes:
thanks, Rob, see you in a couple weeks
Ernie- New River, Az
72 degrees
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Tue, 1/5/10, Rob Robinson com> wrote:
Subject: Re: [WanderlodgeForum] VuQube
Date: Tuesday, January 5, 2010, 5:26 AM
2010/1/4 Ernie E <ernietex@yahoo. com>
83PT40, Deming, Nm
94 WLWB
VuQube - Ernie Ekberg - 01-05-2010 11:31
72 degrees
83PT40
Wanderlodge
83PT40, Deming, Nm
94 WLWB
