was; Way past cold: now in line fan - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: was; Way past cold: now in line fan (/showthread.php?tid=8754) |
was; Way past cold: now in line fan - Ralph L. Fullenwider - 01-08-2010 10:54 Good find Peter, thank you. I checked West Marine but missed them due to Noun/nomenclature I should imagine. Price is not bad either, looks like. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 12:26 PM 1/8/2010 -0800, you wrote: >if you are looking for those yellow tail fans, in the marine world, they >are called blowers and are available from west marine. in my catalogue >they are 34.99 for the 4 inch. <http://www.westmarine.com>http://www.westmarine.com > >Wanderlodge wannabee and cruising boater >1986 Citation Class c > >Peter Sanderson >Comox Valley, BC >>----- Original Message ----- >>From: >>To: >> >>Sent: Friday, January 08, 2010 11:42 AM >>Subject: [WanderlodgeForum] Way past cold >> >> >> >>Good morning to everyone from BRRRR Oklahoma: >> >>You know it is cold when the lock on the shed out back is frozen shut hey?! >> >>I am doing some inside the Coach things that are on my way down the list of >>to do things. Like working on the in-line duct fan from the front furnace >>to the center bath on the FC's. The fan unit is plastic, as it turns out, >>instead of in a metal housing, and the constant heat simply melts the >>plastic housing and stops the fan blade. Having run into this same problem >>in other older Coaches, I am assuming much the same is going on there as >>well. I am in process of converting a refrigerator compartment 12vdc fan >>into an in line duct fan. Shurflo has a unit for marine use called the >>yellow tail that is a 4 inch in line duct fan but I can't find any info on >>pricing or where to buy one, but this gives me something to do. >> >>Ok guys, your right, in answer to what your thinking, (what is he doing out >>in this cold weather working on stuff?) I got "the look" earlier today and >>though this item on my to do list needed to be done! ahem >> >>For those on the way to "Q" be safe out there. >> >>Safe travels, >> >>Ralph and Charolette Fullenwider >>"84FC35 "Ruff Diamond" >>Duncan, Oklahoma >> >> >> was; Way past cold: now in line fan - pr - 01-08-2010 13:43 (first post here, looking for a wanderlodge or a vogue) anyway, I'm an "old boater" and rather than use the "evil emipre" of westmarine, try... defender.com, search blower or yellowtail the 4 in model of yellowtail is 24.99. I've got no dog in either place, but I've always found better pricing @ defender. Paul --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" wrote: > > Good find Peter, thank you. I checked West Marine but missed them due to > Noun/nomenclature I should imagine. Price is not bad either, looks like. > > Safe travels, > > Ralph and Charolette Fullenwider > "84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 12:26 PM 1/8/2010 -0800, you wrote: > > > >if you are looking for those yellow tail fans, in the marine world, they > >are called blowers and are available from west marine. in my catalogue > >they are 34.99 for the 4 inch. <http://www.westmarine.com>http://www.westmarine.com > > > >Wanderlodge wannabee and cruising boater > >1986 Citation Class c > > > >Peter Sanderson > >Comox Valley, BC > >>----- Original Message ----- > >>From: > >>To: > >> > >>Sent: Friday, January 08, 2010 11:42 AM > >>Subject: [WanderlodgeForum] Way past cold > >> > >> > >> > >>Good morning to everyone from BRRRR Oklahoma: > >> > >>You know it is cold when the lock on the shed out back is frozen shut hey?! > >> > >>I am doing some inside the Coach things that are on my way down the list of > >>to do things. Like working on the in-line duct fan from the front furnace > >>to the center bath on the FC's. The fan unit is plastic, as it turns out, > >>instead of in a metal housing, and the constant heat simply melts the > >>plastic housing and stops the fan blade. Having run into this same problem > >>in other older Coaches, I am assuming much the same is going on there as > >>well. I am in process of converting a refrigerator compartment 12vdc fan > >>into an in line duct fan. Shurflo has a unit for marine use called the > >>yellow tail that is a 4 inch in line duct fan but I can't find any info on > >>pricing or where to buy one, but this gives me something to do. > >> > >>Ok guys, your right, in answer to what your thinking, (what is he doing out > >>in this cold weather working on stuff?) I got "the look" earlier today and > >>though this item on my to do list needed to be done! ahem > >> > >>For those on the way to "Q" be safe out there. > >> > >>Safe travels, > >> > >>Ralph and Charolette Fullenwider > >>"84FC35 "Ruff Diamond" > >>Duncan, Oklahoma > >> > >> > >> > was; Way past cold: now in line fan - Ralph L. Fullenwider - 01-08-2010 18:22 Hi Paul and thank you. Will take a look at your suggestion, and hope you find the Coach your searching for. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 01:43 AM 1/9/2010 +0000, you wrote: >(first post here, looking for a wanderlodge or a vogue) > >anyway, I'm an "old boater" and rather than use the "evil emipre" of >westmarine, try... defender.com, search blower or yellowtail >the 4 in model of yellowtail is 24.99. >I've got no dog in either place, but I've always found better pricing @ >defender. > >Paul > >--- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > > > > Good find Peter, thank you. I checked West Marine but missed them due to > > Noun/nomenclature I should imagine. Price is not bad either, looks like. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > "84FC35 "Ruff Diamond" > > Duncan, Oklahoma > > > > At 12:26 PM 1/8/2010 -0800, you wrote: > > > > > > >if you are looking for those yellow tail fans, in the marine world, they > > >are called blowers and are available from west marine. in my catalogue > > >they are 34.99 for the 4 > inch. <http://www.westmarine.com>http://www.westmarine.com > > > > > >Wanderlodge wannabee and cruising boater > > >1986 Citation Class c > > > > > >Peter Sanderson > > >Comox Valley, BC > > >>----- Original Message ----- > > >>From: > > >>To: > > >> > > >>Sent: Friday, January 08, 2010 11:42 AM > > >>Subject: [WanderlodgeForum] Way past cold > > >> > > >> > > >> > > >>Good morning to everyone from BRRRR Oklahoma: > > >> > > >>You know it is cold when the lock on the shed out back is frozen shut > hey?! > > >> > > >>I am doing some inside the Coach things that are on my way down the > list of > > >>to do things. Like working on the in-line duct fan from the front furnace > > >>to the center bath on the FC's. The fan unit is plastic, as it turns out, > > >>instead of in a metal housing, and the constant heat simply melts the > > >>plastic housing and stops the fan blade. Having run into this same > problem > > >>in other older Coaches, I am assuming much the same is going on there as > > >>well. I am in process of converting a refrigerator compartment 12vdc fan > > >>into an in line duct fan. Shurflo has a unit for marine use called the > > >>yellow tail that is a 4 inch in line duct fan but I can't find any > info on > > >>pricing or where to buy one, but this gives me something to do. > > >> > > >>Ok guys, your right, in answer to what your thinking, (what is he > doing out > > >>in this cold weather working on stuff?) I got "the look" earlier > today and > > >>though this item on my to do list needed to be done! ahem > > >> > > >>For those on the way to "Q" be safe out there. > > >> > > >>Safe travels, > > >> > > >>Ralph and Charolette Fullenwider > > >>"84FC35 "Ruff Diamond" > > >>Duncan, Oklahoma > > >> > |
