window frames - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: window frames (/showthread.php?tid=8790) |
window frames - sally brustowicz - 01-24-2010 02:45 Hi, Needing help with peeling on frame around 2 windows on BB. Has anyone dealt with these issues and if so, may I ask what process you used? We are new to the forum and in the process of redoing our interior. Dh thinks we should take them off(window frames) and have a paint shop paint them.. Any suggestions would be appreciated. Also on the 1993 there is a BB logo indentation on the door, was there originally some sort of decal there? It looks as though there might have been. Thanks in advance for your help. Sally Brustowicz
window frames - Eric - 01-24-2010 09:46 Welcome to the forum. All of the windows that I have seen on BB are made out of aluminum. I have been told that BB made the windows in the mid 90's coaches. (Maybe even earlier years???) All the finishes I have seen on the outside of the window frame have been an anodized finish. The fact that you mentioned that something was peeling makes me think that someone may have painted those frames. Anodizing doesn't peel as far as I know. Anodizing is an oxidizing process that forms a layer of "rust" on the surface. It's possible that the anodizing is wearing off but this doesn't occur as peeling so far as I know. There is a rubber seal that goes around the window. I doubt if that is peeling. I can't comment on a BB logo on your door. Honestly, I don't recall seeing a logo on the doors. One suggestion that has been one of the protocols of this forum: It is helpful if, when you sign your name, you put the year and the model of your Bluebird. Eric Perplies 1996 PT-42 window frames - Pete Masterson - 01-24-2010 10:24 The exterior frame on one window (bedroom) showed the dark finish peeling or flaking off in a few patches, leaving a dull aluminum color underneath. So, if the window frames were anodized, that one wasn't. Since a brief inspection showed that there was no real degradation to the window structure, dealing with the issue was far, far down on my "things to do something about" list... I had the understanding that the mid-90s coaches used Hehr brand windows (in, at least, some of the positions). The Hehr maintenance manual appears to describe many of the features of the windows in my coach, including an explanation why they would squeak and the procedure to cure the problem. If the original poster was referring to the Bluebird logo on the -inside- of the door, AFAIK, that was simply a carved (or pressed) decoration that did not have any further embellishment. (I suggest "pressed" because the wood used on the inside door is a particle board-type product that may have been custom crafted for BB.) If there appears to have been an effort to paint the bird image or the background, that might have been done by a prior owner. Pete Masterson (former) '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jan 24, 2010, at 1:46 PM, Eric wrote:
window frames - tcandt - 01-24-2010 11:08 It is not the windows themselves I believe she refers to. There is a wooden frame aroung the door and driver's window sets that get moisture through the glass and need to be painted from time to time. If you have a skylight, you might have the same problem if you do not re-seal them from the outside from time to time (guess what? Mine leaked at the Q this week and I know I hould have performed preventive maintainance sooner). You might want to rmove them so you can sand then down without damage to walls aroud them. A good primer and enamel spray paint works well. What is you coach year and model? --- In WanderlodgeForum@yahoogroups.com, "Eric" > > Welcome to the forum. > > All of the windows that I have seen on BB are made out of aluminum. I have been told that BB made the windows in the mid 90's coaches. (Maybe even earlier years???) All the finishes I have seen on the outside of the window frame have been an anodized finish. The fact that you mentioned that something was peeling makes me think that someone may have painted those frames. Anodizing doesn't peel as far as I know. Anodizing is an oxidizing process that forms a layer of "rust" on the surface. It's possible that the anodizing is wearing off but this doesn't occur as peeling so far as I know. There is a rubber seal that goes around the window. I doubt if that is peeling. > > I can't comment on a BB logo on your door. Honestly, I don't recall seeing a logo on the doors. > > One suggestion that has been one of the protocols of this forum: It is helpful if, when you sign your name, you put the year and the model of your Bluebird. > > Eric Perplies > 1996 PT-42 > window frames - sally brustowicz - 01-24-2010 11:57 The coach is a 1993 WL WB PT. We recently bought it.. What you said is what I was thinking of doing. Sanding and paining them with enamel paint.. The window big on the drivers side only has a small area. The window frame on the inside of the door is the worst one. I will try to remove the wood.. I was thinking of sanding and painting the larger window frame with it in place if possible. Then use an enamel paint after masking it off. We are previous boaters, so I'm used to doing things like this. Thanks for your help. We are new to the forum and BB.. Sally Brustowicz 1993 WL WB PT 40 Niceville fl
On Jan 24, 2010, at 5:08 PM, tcandt wrote:
window frames - Light Ltenergy@... - 01-25-2010 09:37 Hi Sally, First, the door does have a carving or "pressed" image. It was never more than that. Keep it subtle, no doubt. Is your peeling on the window wood frame or on the aluminum window frame itself ? Hugs, Light 1991 PT WB Santa Cruz, CA --- In WanderlodgeForum@yahoogroups.com, sally brustowicz <sbrustowicz@...> wrote: > > Hi, > Needing help with peeling on frame around 2 windows on BB. Has anyone dealt with these issues and if so, may I ask what process you used? We are new to the forum > and in the process of redoing our interior. Dh thinks we should take them off(window frames) and have a paint shop paint them.. Any suggestions would be appreciated. > Also on the 1993 there is a BB logo indentation on the door, was there originally some sort of decal there? It looks as though there might have been. > > Thanks in advance for your help. > > Sally Brustowicz > window frames - sally brustowicz - 01-25-2010 09:45 It is on the wood frame. Sally Brustowicz 1993 WL WB PT 40 Niceville Fl On Jan 25, 2010, at 3:37 PM, Light "Ltenergy@aol.com" wrote:
window frames - Light Ltenergy@... - 01-26-2010 18:46 Hi Sally, Ahhh... so it is the wood. I figured it probably was, as did many others who wrote you back. The wood can be sanded down and refinished. If you are having any condensation, it will continue to add issues for the wood. We had some HEAVY condensation issues and brought a dehumidifier and it has been pulling about one GALLON every day. (Can you believe that?, no wonder I couldn't keep up with squeegee-ing and drying the windows. But of course, we live in the Redwoods right now, and it is ALWAYS WET everywhere). Our coach has dried out completely. It was our saving grace... Our windows were all having issues because of the uncontrollable condensation. GOOD LUCK... you had a boat... so refinishing should be a piece of cake for you. Hugs, Light 1991 PT WB Santa Cruz, CA --- In WanderlodgeForum@yahoogroups.com, sally brustowicz <sbrustowicz@...> wrote: > > It is on the wood frame. > Sally Brustowicz > 1993 WL WB PT 40 > Niceville Fl > > On Jan 25, 2010, at 3:37 PM, Light Ltenergy@... wrote: > > > Hi Sally, > > First, the door does have a carving or "pressed" image. It was never more than that. Keep it subtle, no doubt. > > > > Is your peeling on the window wood frame or on the aluminum window frame itself ? > > > > Hugs, > > > > Light > > 1991 PT WB > > Santa Cruz, CA > > > > --- In WanderlodgeForum@yahoogroups.com, sally brustowicz <sbrustowicz@> wrote: > > > > > > Hi, > > > Needing help with peeling on frame around 2 windows on BB. Has anyone dealt with these issues and if so, may I ask what process you used? We are new to the forum > > > and in the process of redoing our interior. Dh thinks we should take them off(window frames) and have a paint shop paint them.. Any suggestions would be appreciated. > > > Also on the 1993 there is a BB logo indentation on the door, was there originally some sort of decal there? It looks as though there might have been. > > > > > > Thanks in advance for your help. > > > > > > Sally Brustowicz > > > > > > > > |
