3208 tac send - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 3208 tac send (/showthread.php?tid=8791) |
3208 tac send - Ralph L. Fullenwider - 01-24-2010 07:32 Well it is late Jan so most things done to the Coach are on the inside. FC owners, where are the tac send units located? Mine is not on the front of the fuel injector pump out put shaft and the tac in my Coach is electronic. The tac reports correctly until it warms the becomes erratic then none at all. Have a feeling there is a bad connection in the sense wiring. Ideas? TIA Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma 3208 tac send - Chuck Wheeler - 01-24-2010 07:49 Ralph, Mine in on the front of the block under - Chuck 1982 FC 31SB From: Well it is late Jan so most things done to the Coach are on the inside. FC owners, where are the tac send units located? Mine is not on the front of the fuel injector pump out put shaft and the tac in my Coach is electronic. The tac reports correctly until it warms the becomes erratic then none at all. Have a feeling there is a bad connection in the sense wiring. Ideas? TIA Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" 3208 tac send - Ralph L. Fullenwider - 01-24-2010 08:46 Thanks Chuck, will check that area closer when I open up the front again. I had just never notice it back there I guess. I know it is not on the fuel injection pump timing drive like the book says it is. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 01:49 PM 1/24/2010 -0600, you wrote: >Ralph, > > > >Mine in on the front of the block under the fan clutch. > > > >- Chuck Wheeler- > >1982 FC 31SB Fort Worth TX > >---------- >From: WanderlodgeForum@yahoogroups.com >[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ralph L. Fullenwider >Sent: Sunday, January 24, 2010 1:32 PM >To: WanderlodgeForum@Yahoogroups.com >Subject: [WanderlodgeForum] 3208 tac send > > > > > >Well it is late Jan so most things done to the Coach are on the inside. FC >owners, where are the tac send units located? Mine is not on the front of >the fuel injector pump out put shaft and the tac in my Coach is electronic. > >The tac reports correctly until it warms the becomes erratic then none at >all. Have a feeling there is a bad connection in the sense wiring. Ideas? > >TIA > >Safe travels, > >Ralph and Charolette Fullenwider >"84FC35 "Ruff Diamond" >Duncan, Oklahoma > > > > 3208 tac send - Chuck Wheeler - 01-24-2010 09:01 Mine looks like it is driving off the end - Chuck 1982 FC 31SB From: Thanks Chuck, will check that area closer when I open up the front again. I had just never notice it back there I guess. I know it is not on the fuel injection pump timing drive like the book says it is. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" At 01:49 PM 1/24/2010 -0600, you wrote: >Ralph, > > > >Mine in on the front of the block under the fan clutch. > > > >- Chuck Wheeler- > >1982 FC 31SB > >---------- >From: "WanderlodgeForum%40yahoogroups.com" >[mailto:"WanderlodgeForum%40yahoogroups.com"] On Behalf Of Ralph L. Fullenwider >Sent: Sunday, January 24, 2010 1:32 PM >To: "WanderlodgeForum%40Yahoogroups.com" >Subject: [WanderlodgeForum] 3208 tac send > > > > > >Well it is late Jan so most things done to the Coach are on the inside. FC >owners, where are the tac send units located? Mine is not on the front of >the fuel injector pump out put shaft and the tac in my Coach is electronic. > >The tac reports correctly until it warms the becomes erratic then none at >all. Have a feeling there is a bad connection in the sense wiring. Ideas? > >TIA > >Safe travels, > >Ralph and Charolette Fullenwider >"84FC35 "Ruff Diamond" > > > > > 3208 tac send - Michael - 01-24-2010 11:18 That's where mine is, front of the engine. It's driven off the injector pump shaft via the transfer gear bolt. Transfer gear for lack of a better term indexes into the cam gear and turns the pump. The bolt secures the pump gear to the tapered shaft of the pump. Engine timing adjustment is accomplished by moving the gear on the taper. Bolt is torqued to 110 ft. #s. 'When' my tach drive fails I'm going to investigate taking the signal off the fly wheel ring gear. There's a threaded bore in the bell housing for that use. The sensor is from a Ford medium duty. --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > Mine looks like it is driving off the end of the camshaft. I had a wiring > problem in that area when the insulation deteriorated. > > > > - Chuck Wheeler- > > 1982 FC 31SB Fort Worth TX > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ralph L. Fullenwider > Sent: Sunday, January 24, 2010 2:47 PM > To: WanderlodgeForum@yahoogroups.com > Subject: RE: [WanderlodgeForum] 3208 tac send > > > > > > Thanks Chuck, will check that area closer when I open up the front again. I > had just never notice it back there I guess. I know it is not on the fuel > injection pump timing drive like the book says it is. > > Safe travels, > > Ralph and Charolette Fullenwider > "84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 01:49 PM 1/24/2010 -0600, you wrote: > > >Ralph, > > > > > > > >Mine in on the front of the block under the fan clutch. > > > > > > > >- Chuck Wheeler- > > > >1982 FC 31SB Fort Worth TX > > > >---------- > >From: WanderlodgeForum@ > yahoogroups.com > >[mailto:WanderlodgeForum@ > yahoogroups.com] On Behalf Of Ralph L. Fullenwider > >Sent: Sunday, January 24, 2010 1:32 PM > >To: WanderlodgeForum@ > Yahoogroups.com > >Subject: [WanderlodgeForum] 3208 tac send > > > > > > > > > > > >Well it is late Jan so most things done to the Coach are on the inside. FC > >owners, where are the tac send units located? Mine is not on the front of > >the fuel injector pump out put shaft and the tac in my Coach is electronic. > > > >The tac reports correctly until it warms the becomes erratic then none at > >all. Have a feeling there is a bad connection in the sense wiring. Ideas? > > > >TIA > > > >Safe travels, > > > >Ralph and Charolette Fullenwider > >"84FC35 "Ruff Diamond" > >Duncan, Oklahoma > > > > > > > > > 3208 tac send - Ralph L. Fullenwider - 01-26-2010 06:57 Thank you Mike: I know it is supposed to be driven by the injector pump but I don't remember seeing it there. But then they say memory is the first thing to go. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 11:18 PM 1/24/2010 +0000, you wrote: >That's where mine is, front of the engine. It's driven off the injector >pump shaft via the transfer gear bolt. Transfer gear for lack of a better >term indexes into the cam gear and turns the pump. The bolt secures the >pump gear to the tapered shaft of the pump. Engine timing adjustment is >accomplished by moving the gear on the taper. Bolt is torqued to 110 ft. >#s. 'When' my tach drive fails I'm going to investigate taking the signal >off the fly wheel ring gear. There's a threaded bore in the bell housing >for that use. The sensor is from a Ford medium duty. > >--- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > > > Mine looks like it is driving off the end of the camshaft. I had a wiring > > problem in that area when the insulation deteriorated. > > > > > > > > - Chuck Wheeler- > > > > 1982 FC 31SB Fort Worth TX > > > > _____ > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ralph L. Fullenwider > > Sent: Sunday, January 24, 2010 2:47 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: RE: [WanderlodgeForum] 3208 tac send > > > > > > > > > > > > Thanks Chuck, will check that area closer when I open up the front > again. I > > had just never notice it back there I guess. I know it is not on the fuel > > injection pump timing drive like the book says it is. > > > > Safe travels, > > > > Ralph and Charolette Fullenwider > > "84FC35 "Ruff Diamond" > > Duncan, Oklahoma > > > > At 01:49 PM 1/24/2010 -0600, you wrote: > > > > >Ralph, > > > > > > > > > > > >Mine in on the front of the block under the fan clutch. > > > > > > > > > > > >- Chuck Wheeler- > > > > > >1982 FC 31SB Fort Worth TX > > > > > >---------- > > >From: WanderlodgeForum@ > > yahoogroups.com > > >[mailto:WanderlodgeForum@ > > yahoogroups.com] On Behalf Of Ralph L. Fullenwider > > >Sent: Sunday, January 24, 2010 1:32 PM > > >To: WanderlodgeForum@ > > Yahoogroups.com > > >Subject: [WanderlodgeForum] 3208 tac send > > > > > > > > > > > > > > > > > >Well it is late Jan so most things done to the Coach are on the inside. FC > > >owners, where are the tac send units located? Mine is not on the front of > > >the fuel injector pump out put shaft and the tac in my Coach is > electronic. > > > > > >The tac reports correctly until it warms the becomes erratic then none at > > >all. Have a feeling there is a bad connection in the sense wiring. Ideas? > > > > > >TIA > > > > > >Safe travels, > > > > > >Ralph and Charolette Fullenwider > > >"84FC35 "Ruff Diamond" > > >Duncan, Oklahoma > > > > > > > > > > > > > > > > > > >------------------------------------ > >Yahoo! Groups Links > > > |
