wb40 rubber wheel guards - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: wb40 rubber wheel guards (/showthread.php?tid=8812) |
wb40 rubber wheel guards - gasparillaglass - 01-31-2010 08:04 dose anyone know where I can get new rubber wheel guards I'm looking to redo mine but I thought it would be easy to just buy them ??? anyone have any pointers on how to strip the paint off??? thank you all Jamie Brandt 1990 wb 40 florida wb40 rubber wheel guards - g_man1146 - 02-01-2010 03:25 Jamie, When we had our '90 PT40, the wheel trims were cracked and the paint was so brittle they got worse by just touching them. I marked the stripes on each one and removed them. My local body shop repainted them to match the original paint stripes but used a paint and clearcoat that would not crack. They actually brought them back rolled up! They were a PITA to put back on but came out perfect. If your local body shop can't paint them with a flex paint, let me know and I will put you in touch with the guy who did mine. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "gasparillaglass" wrote: > > dose anyone know where I can get new rubber wheel guards I'm looking to redo mine but I thought it would be easy to just buy them > ??? anyone have any pointers on how to strip the paint off??? > thank you all > Jamie Brandt > 1990 wb 40 > florida > wb40 rubber wheel guards - Don Bradner - 02-01-2010 03:59 Interesting, I didn't know that. One reason I didn't is because apparently there's a finite life to the flexibility - lots of cracks and some chips now (I have the 90 Rich is talking about). Overall they still look fairly good. I haven't compared them with others of similar age, but I will the next rally. Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 On 2/1/2010 at 3:25 PM g_man1146 wrote: >Jamie, > >When we had our '90 PT40, the wheel trims were cracked and the paint was >so brittle they got worse by just touching them. I marked the stripes on >each one and removed them. My local body shop repainted them to match the >original paint stripes but used a paint and clearcoat that would not >crack. They actually brought them back rolled up! They were a PITA to put >back on but came out perfect. If your local body shop can't paint them >with a flex paint, let me know and I will put you in touch with the guy >who did mine. > >Rich D. >'99LXi43' CT > > >--- In WanderlodgeForum@yahoogroups.com, "gasparillaglass" > >> >> dose anyone know where I can get new rubber wheel guards I'm looking to >redo mine but I thought it would be easy to just buy them >> ??? anyone have any pointers on how to strip the paint off??? >> thank you all >> Jamie Brandt >> 1990 wb 40 >> florida >> wb40 rubber wheel guards - gasparillaglass - 02-03-2010 09:54 Thank you for your responce I was thinking of painting them with one color but I would rather have it done with the lines So now that you havwe done that I will take them to a shop and see what the cost will be anyway thanks for the responce Jamie Brandt 1990 wb40 --- In WanderlodgeForum@yahoogroups.com, "g_man1146" > > Jamie, > > When we had our '90 PT40, the wheel trims were cracked and the paint was so brittle they got worse by just touching them. I marked the stripes on each one and removed them. My local body shop repainted them to match the original paint stripes but used a paint and clearcoat that would not crack. They actually brought them back rolled up! They were a PITA to put back on but came out perfect. If your local body shop can't paint them with a flex paint, let me know and I will put you in touch with the guy who did mine. > > Rich D. > '99LXi43' CT > > > --- In WanderlodgeForum@yahoogroups.com, "gasparillaglass" wrote: > > > > dose anyone know where I can get new rubber wheel guards I'm looking to redo mine but I thought it would be easy to just buy them > > ??? anyone have any pointers on how to strip the paint off??? > > thank you all > > Jamie Brandt > > 1990 wb 40 > > florida > > > wb40 rubber wheel guards - g_man1146 - 02-04-2010 07:41 Don, I believe that the owner between you and me had the coach repainted. The flexibility would have been lost even if they just re-clear coated the rubber. When BB (and most re-painters) painted these coaches they used the same paint on the rubber as they did on the metal. That paint is not the same as that used for rubber or flexible objects. I'm sure it may become less flexible over time (I did!) but the paint was already cracked on the wheels when I bought that coach with 6000 miles and one year old. The repaint lasted and was perfect when I sold it in 2001. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > Interesting, I didn't know that. One reason I didn't is because apparently there's a finite life to the flexibility - lots of cracks and some chips now (I have the 90 Rich is talking about). > > Overall they still look fairly good. I haven't compared them with others of similar age, but I will the next rally. > > Don Bradner > 90 PT40 "Blue Thunder" > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > On 2/1/2010 at 3:25 PM g_man1146 wrote: > > >Jamie, > > > >When we had our '90 PT40, the wheel trims were cracked and the paint was > >so brittle they got worse by just touching them. I marked the stripes on > >each one and removed them. My local body shop repainted them to match the > >original paint stripes but used a paint and clearcoat that would not > >crack. They actually brought them back rolled up! They were a PITA to put > >back on but came out perfect. If your local body shop can't paint them > >with a flex paint, let me know and I will put you in touch with the guy > >who did mine. > > > >Rich D. > >'99LXi43' CT > > > > > >--- In WanderlodgeForum@yahoogroups.com, "gasparillaglass" > > > >> > >> dose anyone know where I can get new rubber wheel guards I'm looking to > >redo mine but I thought it would be easy to just buy them > >> ??? anyone have any pointers on how to strip the paint off??? > >> thank you all > >> Jamie Brandt > >> 1990 wb 40 > >> florida > >> > wb40 rubber wheel guards - gasparillaglass - 02-06-2010 00:53 what kind of price would you think it should cost me I just got a price with me doing all the work as for stripping them taking them of and re installing basically just having them painted and that was just one color and it was $750 which iI think is high?? so I think what you are saying just paint them with the same paint?? is that right?? --- In WanderlodgeForum@yahoogroups.com, "g_man1146" > > Don, I believe that the owner between you and me had the coach repainted. The flexibility would have been lost even if they just re-clear coated the rubber. When BB (and most re-painters) painted these coaches they used the same paint on the rubber as they did on the metal. That paint is not the same as that used for rubber or flexible objects. I'm sure it may become less flexible over time (I did!) but the paint was already cracked on the wheels when I bought that coach with 6000 miles and one year old. The repaint lasted and was perfect when I sold it in 2001. > > Rich D. '99LXi43' CT > > --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > > > Interesting, I didn't know that. One reason I didn't is because apparently there's a finite life to the flexibility - lots of cracks and some chips now (I have the 90 Rich is talking about). > > > > Overall they still look fairly good. I haven't compared them with others of similar age, but I will the next rally. > > > > Don Bradner > > 90 PT40 "Blue Thunder" > > My location: http://www.bbirdmaps.com/user2.cfm?user=1 > > > > On 2/1/2010 at 3:25 PM g_man1146 wrote: > > > > >Jamie, > > > > > >When we had our '90 PT40, the wheel trims were cracked and the paint was > > >so brittle they got worse by just touching them. I marked the stripes on > > >each one and removed them. My local body shop repainted them to match the > > >original paint stripes but used a paint and clearcoat that would not > > >crack. They actually brought them back rolled up! They were a PITA to put > > >back on but came out perfect. If your local body shop can't paint them > > >with a flex paint, let me know and I will put you in touch with the guy > > >who did mine. > > > > > >Rich D. > > >'99LXi43' CT > > > > > > > > >--- In WanderlodgeForum@yahoogroups.com, "gasparillaglass" > > > > > >> > > >> dose anyone know where I can get new rubber wheel guards I'm looking to > > >redo mine but I thought it would be easy to just buy them > > >> ??? anyone have any pointers on how to strip the paint off??? > > >> thank you all > > >> Jamie Brandt > > >> 1990 wb 40 > > >> florida > > >> > > > wb40 rubber wheel guards - David Ward - 02-06-2010 03:31
wb40 rubber wheel guards - gasparillaglass - 02-06-2010 04:00 thank you I will look into that Jamie Brandt 1990 wb40 --- In WanderlodgeForum@yahoogroups.com, David Ward > > FWIW several years ago I painted a motorcycle with paint from N.A.P.A. they did paint matching and also had a flex agent to add to the paint to prevent cracking on the soft parts. > Dave > Mesa, AZ > 80FC31SB > > --- On Sat, 2/6/10, gasparillaglass > > From: gasparillaglass > Subject: [WanderlodgeForum] Re: wb40 rubber wheel guards > To: WanderlodgeForum@yahoogroups.com > Date: Saturday, February 6, 2010, 12:53 PM > > > > > > > > Ã > > > > > > > > > > what kind of price would you think it should cost me > > I just got a price with me doing all the work as for stripping them taking them of and re installing basically just having them painted and that was just one color and it was $750 which iI think is high?? > > so I think what you are saying just paint them with the same paint?? > > is that right?? > > > > --- In WanderlodgeForum@ yahoogroups. com, "g_man1146" > > > > > > Don, I believe that the owner between you and me had the coach repainted. The flexibility would have been lost even if they just re-clear coated the rubber. When BB (and most re-painters) painted these coaches they used the same paint on the rubber as they did on the metal. That paint is not the same as that used for rubber or flexible objects. I'm sure it may become less flexible over time (I did!) but the paint was already cracked on the wheels when I bought that coach with 6000 miles and one year old. The repaint lasted and was perfect when I sold it in 2001. > > > > > > Rich D. '99LXi43' CT > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Don Bradner" wrote: > > > > > > > > Interesting, I didn't know that. One reason I didn't is because apparently there's a finite life to the flexibility - lots of cracks and some chips now (I have the 90 Rich is talking about). > > > > > > > > Overall they still look fairly good. I haven't compared them with others of similar age, but I will the next rally. > > > > > > > > Don Bradner > > > > 90 PT40 "Blue Thunder" > > > > My location: http://www.bbirdmaps. com/user2. cfm?user= 1 > > > > > > > > On 2/1/2010 at 3:25 PM g_man1146 wrote: > > > > > > > > >Jamie, > > > > > > > > > >When we had our '90 PT40, the wheel trims were cracked and the paint was > > > > >so brittle they got worse by just touching them. I marked the stripes on > > > > >each one and removed them. My local body shop repainted them to match the > > > > >original paint stripes but used a paint and clearcoat that would not > > > > >crack. They actually brought them back rolled up! They were a PITA to put > > > > >back on but came out perfect. If your local body shop can't paint them > > > > >with a flex paint, let me know and I will put you in touch with the guy > > > > >who did mine. > > > > > > > > > >Rich D. > > > > >'99LXi43' CT > > > > > > > > > > > > > > >--- In WanderlodgeForum@ yahoogroups. com, "gasparillaglass" > > > > > > > > > >> > > > > >> dose anyone know where I can get new rubber wheel guards I'm looking to > > > > >redo mine but I thought it would be easy to just buy them > > > > >> ??? anyone have any pointers on how to strip the paint off??? > > > > >> thank you all > > > > >> Jamie Brandt > > > > >> 1990 wb 40 > > > > >> florida > > > > >> > > > > > > > > |
