Radio static - DonS - 02-04-2010 12:16
My radio in the front had static in it from the florescent lights. I installed a
new one because I wanted a HD radio & it still has static in it. The old radio
in the bedroom which is original equipment. Is there a suppressor for static
some where up front that went bad?
Don Spithaler
89 SP 36'
Butler, PA New Port Richey, FL for the winter
Radio static - Ernie Ekberg - 02-04-2010 12:21
Under one of your couches is a electronic filter. That box is about 6 inches by 6 inches by 12 inches long. The older coaches had boxes larger then that. There is just one cable going to it. I suspect that in that shielded cable are 2 wires. I never took it apart and it weighs about 30 pounds. Yours may have quit.
ERnie in AZ
83PT40
Wanderlodge
Weatherford, Tx 817-475-3991
--- On Thu, 2/4/10, DonS wrote:
Subject: [WanderlodgeForum] Radio static
Date: Thursday, February 4, 2010, 6:16 PM
My radio in the front had static in it from the florescent lights. I installed a new one because I wanted a HD radio & it still has static in it. The old radio in the bedroom which is original equipment. Is there a suppressor for static some where up front that went bad?
Don Spithaler
89 SP 36'
Radio static - Pete Masterson - 02-04-2010 14:44
The box you describe is the 12 volt "filter" for the power. It contains 3 large capacitors (be careful, short one and it'll knock you on your rear -- big time). While capacitors can "go bad" -- it isn't likely.
Part of the 12 volt system is "filtered" (passing though the filter) and part is not. It is vital to make sure that the radio is wired into the filtered electrical system. Also, make sure that there isn't something wired in that crosses between the filtered and non filtered power source. (This is a matter of tracing out wires to ensure they're where they're supposed to be.)
However, fluorescent lights (particularly ballasts) can generate RF signals that directly interfere with the radio signal. This is more frequent as the ballasts degrade over time.
So you may need to "do" something about the fluorescent lights directly rather than a filtering problem. A radio shop may have a filter for the antenna wire -- or shielding -- that might solve the problem.
Pete Masterson (former) '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com"
On Feb 4, 2010, at 4:21 PM, Ernie Ekberg wrote:
Under one of your couches is a electronic filter. That box is about 6 inches by 6 inches by 12 inches long. The older coaches had boxes larger then that. There is just one cable going to it. I suspect that in that shielded cable are 2 wires. I never took it apart and it weighs about 30 pounds. Yours may have quit. ERnie in AZ
Ernie Ekberg 83PT40 Wanderlodge Weatherford, Tx 817-475-3991
To:"WanderlodgeForum@yahoogroups.com"
Don Spithaler
89 SP 36'
Radio static - Donald Spithaler - 02-05-2010 02:00
Thanks   Ernie & Pete  I'll see what I can find.
Don Spithaler
89 SP 36'
Butler, PA Â -----Â New Port Richey, FLÂ Â Â Â
On Thu, Feb 4, 2010 at 9:44 PM, Pete Masterson <"aeonix1@mac.com"> wrote:
Â
The box you describe is the 12 volt "filter" for the power. It contains 3 large capacitors (be careful, short one and it'll knock you on your rear -- big time). While capacitors can "go bad" -- it isn't likely.Â
However, fluorescent lights (particularly ballasts) can generate RF signals that directly interfere with the radio signal. This is more frequent as the ballasts degrade over time.Â
So you may need to "do" something about the fluorescent lights directly rather than a filtering problem. A radio shop may have a filter for the antenna wire -- or shielding -- that might solve the problem.Â
ERnie in AZ
To:Â "WanderlodgeForum@yahoogroups.com"
My radio in the front had static in it from the florescent lights. I installed a new one because I wanted a HD radio & it still has static in it. The old radio in the bedroom which is original equipment. Is there a suppressor for static some where up front that went bad?Â
Don SpithalerÂ
89 SP 36'Â
Butler, PA New Port Richey, FL for the winterÂ
Radio static - randymerri@... - 02-05-2010 03:26
I have an "Accessory" switch on the left hand side of the driversarea that has to be turned on to have sound from the televison come through the speakers in the front of the coach. There is no static or humming when the switch is off and the radio is playing. When theswitch is turned on to hear the televison there is an annoying humming sound. Does the filter talked about in the previous post have anything to do with this? I have considered buying a couple of speakers and hooking the tv straight into them and bypassing the accessory switch. I don't care about surround sound. I just want to get rid of the humming noise.
Any suggestions?
Randy Merrill
2003 LX
Ocala, FL
Radio static - Pete Masterson - 02-05-2010 13:35
Likely you're hearing 60-cycle hum. That's caused by circuits in the TV passing unwanted interference through to the 12vdc based sound system. There should be simple filters that will knock that out. Visit a knowledgeable mobile audio dealer and have a technician check out the system (to make sure my guess is correct) and/or to recommend a device you can wire into the speaker circuit yourself.
On Feb 5, 2010, at 7:26 AM, "randymerri@aol.com" wrote:
I have an "Accessory" switch on the left hand side of the driversarea that has to be turned on to have sound from the televison come through the speakers in the front of the coach. There is no static or humming when the switch is off and the radio is playing. When theswitch is turned on to hear the televison there is an annoying humming sound. Does the filter talked about in the previous post have anything to do with this? I have considered buying a couple of speakers and hooking the tv straight into them and bypassing the accessory switch. I don't care about surround sound. I just want to get rid of the humming noise. Any suggestions? Randy Merrill 2003 LX Ocala, FL
Radio static - randymerri@... - 02-06-2010 02:11
Thanks Pete,
I will give it a try.
Randy Merrill
2003 LX
Ocala, FL
