Air Springs Replaced - popping sound revisited - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Springs Replaced - popping sound revisited (/showthread.php?tid=883) |
Air Springs Replaced - popping sound revisited - Jeff Miller - 06-19-2005 05:07 I happened to think about another possibility Kurt. Are you hearing this after using the front leveling jacks? On the '83-up the jacks will usually not swing up until the airbags begin to inflate/lift the coach, often they will swing up fast enough to hit the stop hard and make a fairly loud "pop" sound when they do. - Jeff Miller http://www.millercoachworks.com http://www.wanderlodge.net --- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" wrote: > > > When I drop the suspension and later reinflate, I hear a loud popping > noise coming from the front airbags----- this leads me to believe > they are getting pinched somehow during deflation? Is this anything > to be concerned? > Thanks for your advise > Kurt > '83FC35SB in NH Air Springs Replaced - popping sound revisited - Kurt Achenbach - 06-20-2005 00:04 Jeff, I certainly appreciate your thoughts. It happens when I set the jacks to retract, before having some air in the bags. Then I heared a popping in one or two of the bags as the coach started to lift. This happend only a few times, after that, I changed the start up procedure. Now when the coach rests on the jacks I make sure the dump switch is off, I start the engine and let the air build up and after a few minutes I raise the jacks slowly, releasing the weight on to the filling bags. This way no mor popping. I keep the coach inside a garage and will check the issue on our next outing, which unfortunately will not be until early August. As allways thank you Kurt '38FC35SB in NH --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > I happened to think about another possibility Kurt. Are you hearing > this after using the front leveling jacks? On the '83-up the jacks will > usually not swing up until the airbags begin to inflate/lift the coach, > often they will swing up fast enough to hit the stop hard and make a > fairly loud "pop" sound when they do. > > - Jeff Miller > http://www.millercoachworks.com > http://www.wanderlodge.net > > > --- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" > wrote: > > > > > > When I drop the suspension and later reinflate, I hear a loud popping > > noise coming from the front airbags----- this leads me to believe > > they are getting pinched somehow during deflation? Is this anything > > to be concerned? > > Thanks for your advise > > Kurt > > '83FC35SB in NH Air Springs Replaced - popping sound revisited - George Lowry - 06-20-2005 03:14 Kurt, I realize that procedure change, sometimes each year but for our '95, the instructions say to dump the air pressure completely before lowering the jacks and conversely, to be completely aired up before retracting the jacks. Trying to find strange sounds can be a problem, especially since they can be intermittent. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Kurt Achenbach wrote: > > Jeff, I certainly appreciate your thoughts. > > It happens when I set the jacks to retract, before having some air in > the bags. Then I heared a popping in one or two of the bags as the > coach started to lift. This happend only a few times, after that, I > changed the start up procedure. Now when the coach rests on the jacks > I make sure the dump switch is off, I start the engine and let the > air build up and after a few minutes I raise the jacks slowly, > releasing the weight on to the filling bags. This way no mor popping. > I keep the coach inside a garage and will check the issue on our next > outing, which unfortunately will not be until early August. > As allways thank you > Kurt > '38FC35SB in NH > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > >>I happened to think about another possibility Kurt. Are you hearing >>this after using the front leveling jacks? On the '83-up the jacks > > will > >>usually not swing up until the airbags begin to inflate/lift the > > coach, > >>often they will swing up fast enough to hit the stop hard and make > > a > >>fairly loud "pop" sound when they do. >> >> - Jeff Miller >>http://www.millercoachworks.com >>http://www.wanderlodge.net >> >> >>--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" > > > >>wrote: >> >>> >>>When I drop the suspension and later reinflate, I hear a loud > > popping > >>>noise coming from the front airbags----- this leads me to believe >>>they are getting pinched somehow during deflation? Is this > > anything > >>>to be concerned? >>>Thanks for your advise >>>Kurt >>>'83FC35SB in NH > > > > > > > Yahoo! Groups Links > > > > > > > > > Air Springs Replaced - popping sound revisited - Kurt Achenbach - 06-20-2005 06:14 George I hear you, but on my '83FC35 the coach is to low with the bags dumped, for the jacks to swing down properly. Thanks Kurt --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Kurt, > > I realize that procedure change, sometimes each year but for our '95, > the instructions say to dump the air pressure completely before > lowering the jacks and conversely, to be completely aired up before > retracting the jacks. Trying to find strange sounds can be a problem, > especially since they can be intermittent. > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > Kurt Achenbach wrote: > > > > > Jeff, I certainly appreciate your thoughts. > > > > It happens when I set the jacks to retract, before having some air in > > the bags. Then I heared a popping in one or two of the bags as the > > coach started to lift. This happend only a few times, after that, I > > changed the start up procedure. Now when the coach rests on the jacks > > I make sure the dump switch is off, I start the engine and let the > > air build up and after a few minutes I raise the jacks slowly, > > releasing the weight on to the filling bags. This way no mor popping. > > I keep the coach inside a garage and will check the issue on our next > > outing, which unfortunately will not be until early August. > > As allways thank you > > Kurt > > '38FC35SB in NH > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > >>I happened to think about another possibility Kurt. Are you hearing > >>this after using the front leveling jacks? On the '83-up the jacks > > > > will > > > >>usually not swing up until the airbags begin to inflate/lift the > > > > coach, > > > >>often they will swing up fast enough to hit the stop hard and make > > > > a > > > >>fairly loud "pop" sound when they do. > >> > >> - Jeff Miller > >>http://www.millercoachworks.com > >>http://www.wanderlodge.net > >> > >> > >>--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" > > > > > > > >>wrote: > >> > >>> > >>>When I drop the suspension and later reinflate, I hear a loud > > > > popping > > > >>>noise coming from the front airbags----- this leads me to believe > >>>they are getting pinched somehow during deflation? Is this > > > > anything > > > >>>to be concerned? > >>>Thanks for your advise > >>>Kurt > >>>'83FC35SB in NH > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > Air Springs Replaced - popping sound revisited - Chet Geist - 06-20-2005 06:24 Kurt, I may be way off base with this, but I get popping sounds from the jack retracting springs. This frequently happens when they come up slowly. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Kurt Achenbach Sent: Monday, June 20, 2005 1:15 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Air Springs Replaced - popping sound revisited George I hear you, but on my '83FC35 the coach is to low with the bags dumped, for the jacks to swing down properly. Thanks Kurt --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Kurt, > > I realize that procedure change, sometimes each year but for our '95, > the instructions say to dump the air pressure completely before > lowering the jacks and conversely, to be completely aired up before > retracting the jacks. Trying to find strange sounds can be a problem, > especially since they can be intermittent. > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > Kurt Achenbach wrote: > > > > > Jeff, I certainly appreciate your thoughts. > > > > It happens when I set the jacks to retract, before having some air in > > the bags. Then I heared a popping in one or two of the bags as the > > coach started to lift. This happend only a few times, after that, I > > changed the start up procedure. Now when the coach rests on the jacks > > I make sure the dump switch is off, I start the engine and let the > > air build up and after a few minutes I raise the jacks slowly, > > releasing the weight on to the filling bags. This way no mor popping. > > I keep the coach inside a garage and will check the issue on our next > > outing, which unfortunately will not be until early August. > > As allways thank you > > Kurt > > '38FC35SB in NH > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > >>I happened to think about another possibility Kurt. Are you hearing > >>this after using the front leveling jacks? On the '83-up the jacks > > > > will > > > >>usually not swing up until the airbags begin to inflate/lift the > > > > coach, > > > >>often they will swing up fast enough to hit the stop hard and make > > > > a > > > >>fairly loud "pop" sound when they do. > >> > >> - Jeff Miller > >>http://www.millercoachworks.com > >>http://www.wanderlodge.net > >> > >> > >>--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" > > > > > > > >>wrote: > >> > >>> > >>>When I drop the suspension and later reinflate, I hear a loud > > > > popping > > > >>>noise coming from the front airbags----- this leads me to believe > >>>they are getting pinched somehow during deflation? Is this > > > > anything > > > >>>to be concerned? > >>>Thanks for your advise > >>>Kurt > >>>'83FC35SB in NH > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > ---------------------------------------------------------------------------- -- Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Air Springs Replaced - popping sound revisited - George Lowry - 06-20-2005 07:06 That explains it - mine are straight acting jacks. Well, I tried. George Lowry '95 WBDA 4203 & GM 4106 (for sale) Spearfish, SD Kurt Achenbach wrote: > George I hear you, but on my '83FC35 the coach is to low with the > bags dumped, for the jacks to swing down properly. > > Thanks > Kurt > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > wrote: > >>Kurt, >> >>I realize that procedure change, sometimes each year but for > > our '95, > >>the instructions say to dump the air pressure completely before >>lowering the jacks and conversely, to be completely aired up before >>retracting the jacks. Trying to find strange sounds can be a > > problem, > >>especially since they can be intermittent. >> >>George Lowry >>'95 WBDA 4203 & GM 4106 (for sale) >>Spearfish, SD >> >>Kurt Achenbach wrote: >> >> >>>Jeff, I certainly appreciate your thoughts. >>> >>>It happens when I set the jacks to retract, before having some > > air in > >>>the bags. Then I heared a popping in one or two of the bags as > > the > >>>coach started to lift. This happend only a few times, after that, > > I > >>>changed the start up procedure. Now when the coach rests on the > > jacks > >>>I make sure the dump switch is off, I start the engine and let > > the > >>>air build up and after a few minutes I raise the jacks slowly, >>>releasing the weight on to the filling bags. This way no mor > > popping. > >>>I keep the coach inside a garage and will check the issue on our > > next > >>>outing, which unfortunately will not be until early August. >>>As allways thank you >>>Kurt >>>'38FC35SB in NH >>> >>> >>> >>>--- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" >>> >>> >>> >>>>I happened to think about another possibility Kurt. Are you > > hearing > >>>>this after using the front leveling jacks? On the '83-up the > > jacks > >>>will >>> >>> >>>>usually not swing up until the airbags begin to inflate/lift the >>> >>>coach, >>> >>> >>>>often they will swing up fast enough to hit the stop hard and > > make > >>>a >>> >>> >>>>fairly loud "pop" sound when they do. >>>> >>>>- Jeff Miller >>>>http://www.millercoachworks.com >>>>http://www.wanderlodge.net >>>> >>>> >>>>--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" >>> >>> >>> >>> >>>>wrote: >>>> >>>> >>>>>When I drop the suspension and later reinflate, I hear a loud >>> >>>popping >>> >>> >>>>>noise coming from the front airbags----- this leads me to > > believe > >>>>>they are getting pinched somehow during deflation? Is this >>> >>>anything >>> >>> >>>>>to be concerned? >>>>>Thanks for your advise >>>>>Kurt >>>>>'83FC35SB in NH >>> >>> >>> >>> >>> >>> >>>Yahoo! Groups Links >>> >>> >>> >>> >>> >>> >>> >>> >>> > > > > > > > Yahoo! Groups Links > > > > > > > > > Air Springs Replaced - popping sound revisited - rrob@... - 06-20-2005 08:47 Chet I don't know if this will apply to your coach but my 94 was making noises until Randy Dupree told me that the foot plate was only held on my the two springs and that it rotated on the end of the hydraulic shaft. The shaft has the ball end and the plate has the socket. My socket/ball had rusted up a bit and everytime I used my jacks the socket/ball combination made rusted metal grinding together noise including pops, bangs etc.. I sprayed each socket with lubricant (PB Blaster) and I haven't had these noises since. Hope this helps. Rob Robinson 94 WLWB Original Message: ----------------- From: Chet Geist chetg@... Date: Mon, 20 Jun 2005 13:24:07 -0500 To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Air Springs Replaced - popping sound revisited Kurt, I may be way off base with this, but I get popping sounds from the jack retracting springs. This frequently happens when they come up slowly. Chet Geist 1981 FC33, Austin, Texas  -----Original Message-----  From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Kurt Achenbach  Sent: Monday, June 20, 2005 1:15 PM  To: WanderlodgeForum@yahoogroups.com  Subject: [WanderlodgeForum] Re: Air Springs Replaced - popping sound revisited  George I hear you, but on my '83FC35 the coach is to low with the  bags dumped, for the jacks to swing down properly.  Thanks  Kurt  --- In WanderlodgeForum@yahoogroups.com, George Lowry  wrote:  > Kurt,  >  > I realize that procedure change, sometimes each year but for  our '95,  > the instructions say to dump the air pressure completely before  > lowering the jacks and conversely, to be completely aired up before  > retracting the jacks. Trying to find strange sounds can be a  problem,  > especially since they can be intermittent.  >  > George Lowry  > '95 WBDA 4203 & GM 4106 (for sale)  > Spearfish, SD  >  > Kurt Achenbach wrote:  >  > >  > > Jeff, I certainly appreciate your thoughts.  > >  > > It happens when I set the jacks to retract, before having some  air in  > > the bags. Then I heared a popping in one or two of the bags as  the  > > coach started to lift. This happend only a few times, after that,  I  > > changed the start up procedure. Now when the coach rests on the  jacks  > > I make sure the dump switch is off, I start the engine and let  the  > > air build up and after a few minutes I raise the jacks slowly,  > > releasing the weight on to the filling bags. This way no mor  popping.  > > I keep the coach inside a garage and will check the issue on our  next  > > outing, which unfortunately will not be until early August.  > > As allways thank you  > > Kurt  > > '38FC35SB in NH  > >  > >  > >  > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller"  > >  > >  > >>I happened to think about another possibility Kurt. Are you  hearing  > >>this after using the front leveling jacks? On the '83-up the  jacks  > >  > > will  > >  > >>usually not swing up until the airbags begin to inflate/lift the  > >  > > coach,  > >  > >>often they will swing up fast enough to hit the stop hard and  make  > >  > > a  > >  > >>fairly loud "pop" sound when they do.  > >>  > >> - Jeff Miller  > >>[url]www.millercoachworks.com [/url]  > >>[url]www.wanderlodge.net [/url]  > >>  > >>  > >>--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach"  > >  > >  > >  > >>wrote:  > >>  > >>>  > >>>When I drop the suspension and later reinflate, I hear a loud  > >  > > popping  > >  > >>>noise coming from the front airbags----- this leads me to  believe  > >>>they are getting pinched somehow during deflation? Is this  > >  > > anything  > >  > >>>to be concerned?  > >>>Thanks for your advise  > >>>Kurt  > >>>'83FC35SB in NH  > >  > >  > >  > >  > >  > >  > > Yahoo! Groups Links  > >  > >  > >  > >  > >  > >  > >  > >  > > ---------------------------------------------------------------------------- --  Yahoo! Groups Links    a.. To visit your group on the web, go to:    href="http://groups.yahoo.com/group/WanderlodgeForum/">http://groups.yahoo.c om/group/WanderlodgeForum/    b.. To unsubscribe from this group, send an email to:    WanderlodgeForum-unsubscribe@yahoogroups.com    c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] <!-- |**|begin egp html banner|**| --> Yahoo! Groups Links
<!-- |**|end egp html banner|**| --> -------------------------------------------------------------------- mail2web - Check your email from the web at http://mail2web.com/ . Air Springs Replaced - popping sound revisited - Chet Geist - 06-20-2005 14:18 Thanks Rob, I'll keep that in mind when I get to reworking my jacks. They are a little further down the list. On my jacks the small cylinder that extends the jacks pushes against a small bearing and they get all gunked up from road grim. Need to keep them cleaned and working for a smooth operating jack. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of rrob@... Sent: Monday, June 20, 2005 3:47 PM To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Air Springs Replaced - popping sound revisited Chet I don't know if this will apply to your coach but my 94 was making noises until Randy Dupree told me that the foot plate was only held on my the two springs and that it rotated on the end of the hydraulic shaft. The shaft has the ball end and the plate has the socket. My socket/ball had rusted up a bit and everytime I used my jacks the socket/ball combination made rusted metal grinding together noise including pops, bangs etc.. I sprayed each socket with lubricant (PB Blaster) and I haven't had these noises since. Hope this helps. Rob Robinson 94 WLWB Original Message: ----------------- From: Chet Geist chetg@... Date: Mon, 20 Jun 2005 13:24:07 -0500 To: WanderlodgeForum@yahoogroups.com Subject: RE: [WanderlodgeForum] Re: Air Springs Replaced - popping sound revisited Kurt, I may be way off base with this, but I get popping sounds from the jack retracting springs. This frequently happens when they come up slowly. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Kurt Achenbach Sent: Monday, June 20, 2005 1:15 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Air Springs Replaced - popping sound revisited George I hear you, but on my '83FC35 the coach is to low with the bags dumped, for the jacks to swing down properly. Thanks Kurt --- In WanderlodgeForum@yahoogroups.com, George Lowry wrote: > Kurt, > > I realize that procedure change, sometimes each year but for our '95, > the instructions say to dump the air pressure completely before > lowering the jacks and conversely, to be completely aired up before > retracting the jacks. Trying to find strange sounds can be a problem, > especially since they can be intermittent. > > George Lowry > '95 WBDA 4203 & GM 4106 (for sale) > Spearfish, SD > > Kurt Achenbach wrote: > > > > > Jeff, I certainly appreciate your thoughts. > > > > It happens when I set the jacks to retract, before having some air in > > the bags. Then I heared a popping in one or two of the bags as the > > coach started to lift. This happend only a few times, after that, I > > changed the start up procedure. Now when the coach rests on the jacks > > I make sure the dump switch is off, I start the engine and let the > > air build up and after a few minutes I raise the jacks slowly, > > releasing the weight on to the filling bags. This way no mor popping. > > I keep the coach inside a garage and will check the issue on our next > > outing, which unfortunately will not be until early August. > > As allways thank you > > Kurt > > '38FC35SB in NH > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > >>I happened to think about another possibility Kurt. Are you hearing > >>this after using the front leveling jacks? On the '83-up the jacks > > > > will > > > >>usually not swing up until the airbags begin to inflate/lift the > > > > coach, > > > >>often they will swing up fast enough to hit the stop hard and make > > > > a > > > >>fairly loud "pop" sound when they do. > >> > >> - Jeff Miller > >>[url]www.millercoachworks.com [/url] > >>[url]www.wanderlodge.net [/url] > >> > >> > >>--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" > > > > > > > >>wrote: > >> > >>> > >>>When I drop the suspension and later reinflate, I hear a loud > > > > popping > > > >>>noise coming from the front airbags----- this leads me to believe > >>>they are getting pinched somehow during deflation? Is this > > > > anything > > > >>>to be concerned? > >>>Thanks for your advise > >>>Kurt > >>>'83FC35SB in NH > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > -------------------------------------------------------------------------- -- -- Yahoo! Groups Links a.. To visit your group on the web, go to: href="http://groups.yahoo.com/group/WanderlodgeForum/">http://groups.yahoo .c om/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] <!-- |**|begin egp html banner|**| --> Yahoo! Groups Links
<!-- |**|end egp html banner|**| --> -------------------------------------------------------------------- mail2web - Check your email from the web at http://mail2web.com/ . ---------------------------------------------------------------------------- -- Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Air Springs Replaced - popping sound revisited - Kurt Achenbach - 06-21-2005 04:34 Thanks Chet, I am familiar with the sound the jacks make. The noise I am talking about was like when a newly mounted tire popps in place on the rim. Kurt --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" wrote: > Kurt, > > I may be way off base with this, but I get popping sounds from the jack > retracting springs. This frequently happens when they come up slowly. > > Chet Geist > 1981 FC33, Austin, Texas > -----Original Message----- > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Kurt Achenbach > Sent: Monday, June 20, 2005 1:15 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Air Springs Replaced - popping sound > revisited > > > George I hear you, but on my '83FC35 the coach is to low with the > bags dumped, for the jacks to swing down properly. > > Thanks > Kurt > > --- In WanderlodgeForum@yahoogroups.com, George Lowry > wrote: > > Kurt, > > > > I realize that procedure change, sometimes each year but for > our '95, > > the instructions say to dump the air pressure completely before > > lowering the jacks and conversely, to be completely aired up before > > retracting the jacks. Trying to find strange sounds can be a > problem, > > especially since they can be intermittent. > > > > George Lowry > > '95 WBDA 4203 & GM 4106 (for sale) > > Spearfish, SD > > > > Kurt Achenbach wrote: > > > > > > > > Jeff, I certainly appreciate your thoughts. > > > > > > It happens when I set the jacks to retract, before having some > air in > > > the bags. Then I heared a popping in one or two of the bags as > the > > > coach started to lift. This happend only a few times, after that, > I > > > changed the start up procedure. Now when the coach rests on the > jacks > > > I make sure the dump switch is off, I start the engine and let > the > > > air build up and after a few minutes I raise the jacks slowly, > > > releasing the weight on to the filling bags. This way no mor > popping. > > > I keep the coach inside a garage and will check the issue on our > next > > > outing, which unfortunately will not be until early August. > > > As allways thank you > > > Kurt > > > '38FC35SB in NH > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Jeff Miller" > > > > > > > > >>I happened to think about another possibility Kurt. Are you > hearing > > >>this after using the front leveling jacks? On the '83-up the > jacks > > > > > > will > > > > > >>usually not swing up until the airbags begin to inflate/lift the > > > > > > coach, > > > > > >>often they will swing up fast enough to hit the stop hard and > make > > > > > > a > > > > > >>fairly loud "pop" sound when they do. > > >> > > >> - Jeff Miller > > >>http://www.millercoachworks.com > > >>http://www.wanderlodge.net > > >> > > >> > > >>--- In WanderlodgeForum@yahoogroups.com, "Kurt Achenbach" > > > > > > > > > > > >>wrote: > > >> > > >>> > > >>>When I drop the suspension and later reinflate, I hear a loud > > > > > > popping > > > > > >>>noise coming from the front airbags----- this leads me to > believe > > >>>they are getting pinched somehow during deflation? Is this > > > > > > anything > > > > > >>>to be concerned? > > >>>Thanks for your advise > > >>>Kurt > > >>>'83FC35SB in NH > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -------------------------------------------------------------------- -------- > -- > Yahoo! Groups Links > > a.. To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > > [Non-text portions of this message have been removed] |
