Route info Las Vegas- Phoenix - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Route info Las Vegas- Phoenix (/showthread.php?tid=8875) |
Route info Las Vegas- Phoenix - jkenn48105 - 03-12-2010 09:37 Does anyone have information on the route between Las Vegas and Phoenix? I can see twists and turns on the map, but I don't have any idea how it would be with a 40' Bird towing a car. Route info Las Vegas- Phoenix - Rick Davis - 03-12-2010 09:49 To keep from having to deal with the dam we took hwy 95 south, crossed over through Laughlin on hwy 68 to I-40, then used hwy 93 south to Phoenix. You will watch your temp guages on the hwy 68 portion, but is a pretty drive.
Rick Davis
1993 WBSA
Loudon, TN
From: jkenn48105 To: WanderlodgeForum@yahoogroups.com Sent: Fri, March 12, 2010 4:37:59 PM Subject: [WanderlodgeForum] Route info Las Vegas- Phoenix Does anyone have information on the route between Las Vegas and Phoenix? I can see twists and turns on the map, but I don't have any idea how it would be with a 40' Bird towing a car. Route info Las Vegas- Phoenix - jkenn48105 - 03-12-2010 10:34 Wow, that was fast. I had looked at a similar route but went further south, I like your idea better - thanks --- In WanderlodgeForum@yahoogroups.com, Rick Davis > > To keep from having to deal with the dam we took hwy 95 south, crossed over through Laughlin on hwy 68 to I-40, then used hwy 93 south to Phoenix.Ã You will watch your temp guages on the hwy 68 portion, but is a pretty drive. > > Rick Davis > 1993 WBSA > Loudon, TN > > > > > ________________________________ > From: jkenn48105 > To: WanderlodgeForum@yahoogroups.com > Sent: Fri, March 12, 2010 4:37:59 PM > Subject: [WanderlodgeForum] Route info Las Vegas- Phoenix > > Ã > Does anyone have information on the route between Las Vegas and Phoenix? I can see twists and turns on the map, but I don't have any idea how it would be with a 40' Bird towing a car. > Route info Las Vegas- Phoenix - mbulriss - 03-12-2010 10:44 Both ways are pretty good roads. The map makes 68 look better than it is from Kingman to Laughlin. Once you cross over the mountain range, the downhill side is about 13(?) miles of 7% grade, as I recall, with multiple switchbacks. Make *very* sure you are in a lower gear when you start the downhill side. There is also a stop light at the very end of the last downhill section. To me, 93 over the dam is a much easier ride. Yes, there is a downhill to the dam (downshift again) and one nasty switchback on the way back up the Nevada side, but it is a unique ride. However, I think the new bridge bypass is scheduled for August completion, which will hake it a straight shot. Have a great trip. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "jkenn48105" > > Does anyone have information on the route between Las Vegas and Phoenix? I can see twists and turns on the map, but I don't have any idea how it would be with a 40' Bird towing a car. > Route info Las Vegas- Phoenix - mbulriss - 03-12-2010 11:03 Actually, I mis-interpreted your post. I was thinking Phoenix to Vegas. If you are going Vegas to Phoenix, then 93 is my absolute first choice. Only that one downhill switchback to the dam is tight. Unique treat to watch all the tourists staring at a PT/WB towing a toad across the dam! Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Both ways are pretty good roads. The map makes 68 look better than it is from Kingman to Laughlin. Once you cross over the mountain range, the downhill side is about 13(?) miles of 7% grade, as I recall, with multiple switchbacks. Make *very* sure you are in a lower gear when you start the downhill side. There is also a stop light at the very end of the last downhill section. > > To me, 93 over the dam is a much easier ride. Yes, there is a downhill to the dam (downshift again) and one nasty switchback on the way back up the Nevada side, but it is a unique ride. However, I think the new bridge bypass is scheduled for August completion, which will hake it a straight shot. > > Have a great trip. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "jkenn48105" > > > > Does anyone have information on the route between Las Vegas and Phoenix? I can see twists and turns on the map, but I don't have any idea how it would be with a 40' Bird towing a car. > > > Route info Las Vegas- Phoenix - hardestyr35 - 03-12-2010 12:09 We went across the dam with our 97 43" PT, towing a Jeep and had no problems. Going that way you will get to see the new bridge. Richard Hardesty Zanesville, Ohio 1997 43" PT --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > Actually, I mis-interpreted your post. I was thinking Phoenix to Vegas. If you are going Vegas to Phoenix, then 93 is my absolute first choice. Only that one downhill switchback to the dam is tight. Unique treat to watch all the tourists staring at a PT/WB towing a toad across the dam! > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Both ways are pretty good roads. The map makes 68 look better than it is from Kingman to Laughlin. Once you cross over the mountain range, the downhill side is about 13(?) miles of 7% grade, as I recall, with multiple switchbacks. Make *very* sure you are in a lower gear when you start the downhill side. There is also a stop light at the very end of the last downhill section. > > > > To me, 93 over the dam is a much easier ride. Yes, there is a downhill to the dam (downshift again) and one nasty switchback on the way back up the Nevada side, but it is a unique ride. However, I think the new bridge bypass is scheduled for August completion, which will hake it a straight shot. > > > > Have a great trip. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "jkenn48105" > > > > > > Does anyone have information on the route between Las Vegas and Phoenix? I can see twists and turns on the map, but I don't have any idea how it would be with a 40' Bird towing a car. > > > > > > Route info Las Vegas- Phoenix - HANK - 03-15-2010 20:30 I left vegas at 4am and took the DAM route........no problem with my 90SP36 and a toad............ regards, Hank 90SP36 In OZ --- In WanderlodgeForum@yahoogroups.com, "hardestyr35" wrote: > > > > We went across the dam with our 97 43" PT, towing a Jeep and had no problems. Going that way you will get to see the new bridge. > Richard Hardesty > Zanesville, Ohio > 1997 43" PT > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > Actually, I mis-interpreted your post. I was thinking Phoenix to Vegas. If you are going Vegas to Phoenix, then 93 is my absolute first choice. Only that one downhill switchback to the dam is tight. Unique treat to watch all the tourists staring at a PT/WB towing a toad across the dam! > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > > > Both ways are pretty good roads. The map makes 68 look better than it is from Kingman to Laughlin. Once you cross over the mountain range, the downhill side is about 13(?) miles of 7% grade, as I recall, with multiple switchbacks. Make *very* sure you are in a lower gear when you start the downhill side. There is also a stop light at the very end of the last downhill section. > > > > > > To me, 93 over the dam is a much easier ride. Yes, there is a downhill to the dam (downshift again) and one nasty switchback on the way back up the Nevada side, but it is a unique ride. However, I think the new bridge bypass is scheduled for August completion, which will hake it a straight shot. > > > > > > Have a great trip. > > > > > > Mike Bulriss > > > 1991 WB40 "Texas Minivan" > > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "jkenn48105" > > > > > > > > Does anyone have information on the route between Las Vegas and Phoenix? I can see twists and turns on the map, but I don't have any idea how it would be with a 40' Bird towing a car. > > > > > > > > > > |
