need help again. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: need help again. (/showthread.php?tid=8918) |
need help again. - nelsons - 04-15-2010 11:03 I found out why the dash lights did not come on. The back of the headlight switch had separated. Now the problem is with the headlight safety buzzer and warning light stays on when the engine is running. As soon as I turn on the headlights it's starts to buzz and the headlight warning comes on. It does not make a difference whether the key is in the ignition or even while the engine is running. Any suggestions on how to fix this? Thanks in Advance. Nelson Slinkman 1994 40ft need help again. - Fred Hulse - 04-15-2010 12:51 Nelson
Did you replace the switch or reassemble it?
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 need help again. - nelsons - 04-16-2010 01:27 Hello Fred, All I did was squeeze the case and the dash lights started working. I was not aware that it was a two part switch. Do you know if this switch can be found if is need to be replaced? Thanks Nelson 1994 40ft --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Nelson > Did you replace the switch or reassemble it? > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > need help again. - Fred Hulse - 04-16-2010 02:00 Nelson
I would pull it out and take it to a good parts store with a real parts guy and he should be able to match it up.
I don't recall right this moment,but I believe it is a late 80's or early 90's GM switch.
Most GM switches have the last 3 or 4 numbers of the 7 digit factory number (Delco Remy) cast or stamped on them.
You may find it online,but a good description and decent photo is really important.Most suppliers won't bother to post that kind of information.
I hope you can find one,because I think it needs replacing.
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 need help again. - nelsons - 04-16-2010 07:17 Thanks Fred, I will give it a try. Thanks Nelson 1994 40ft --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > Nelson > I would pull it out and take it to a good parts store with a real parts guy and he should be able to match it up. > I don't recall right this moment,but I believe it is a late 80's or early 90's GM switch. > Most GM switches have the last 3 or 4 numbers of the 7 digit factory number (Delco Remy) cast or stamped on them. > You may find it online,but a good description and decent photo is really important.Most suppliers won't bother to post that kind of information. > I hope you can find one,because I think it needs replacing. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > |
