Mufflers - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Mufflers (/showthread.php?tid=8966) |
Mufflers - cape0001 - 05-18-2010 13:35 Pricing will be available tomorrow Wednesday for 6 inch mufflers in either Aluminized Steel, 409 Stainless or 304 Stainless these mufflers will be 51.5 inches long, 6 inch inlet and outlet and 10 inches in diameter following shortly will be mandrel bent tubing for series 60 and 8v92 mandrel bent no welds to impair efficiency. These will also be available in aluminized steel and 409,304 stainless also available a bellows made of 304 stainless. No more ball and socket expansion joint. they will be priced lower than traditional Vendors The above will available in complete exhaust systems and in separate components for older Coaches and newer coaches We are looking at reproducing left and right bank exhaust tubes on the 8v92 Mufflers will available for m380 Stephen 97 bmc 37 dupreeproducts.com Mufflers - jburgessx2@... - 05-18-2010 14:07 Stephen, I'm not sure of all the sizes you mentioned. So, will these fit on an 85 PT40 with the 6V92? I could use a new muffler! Jerry 85 PT40 Sent via BlackBerry from T-Mobile From: "cape0001" <sbirtles@...> Date: Wed, 19 May 2010 01:35:03 -0000 To: Subject: [WanderlodgeForum] Mufflers Pricing will be available tomorrow Wednesday for 6 inch mufflers in either Aluminized Steel, 409 Stainless or 304 Stainless these mufflers will be 51.5 inches long, 6 inch inlet and outlet and 10 inches in diameter following shortly will be mandrel bent tubing for series 60 and 8v92 mandrel bent no welds to impair efficiency. These will also be available in aluminized steel and 409,304 stainless also available a bellows made of 304 stainless. No more ball and socket expansion joint. they will be priced lower than traditional Vendors The above will available in complete exhaust systems and in separate components for older Coaches and newer coaches We are looking at reproducing left and right bank exhaust tubes on the 8v92 Mufflers will available for m380 Stephen 97 bmc 37 dupreeproducts.com Mufflers - Ernie Ekberg - 05-18-2010 23:37
Mufflers - cape0001 - 05-19-2010 13:12 mufflers 51 inch long 10 inch in diameter 6 inch inlet and outlet Aluminized steel $273.00 409 Stainless $403.00 304 Stainless $588.00 Lead time 1 week form time of order from manufacturer to me. Then ups time form me to you __________________ Have a Great Day Stephen Birtles 97BMC37 http://www.dupreeproducts.com Telephone 888 668 4288 or 905 328 0162 --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@...> wrote: > > Pricing will be available tomorrow Wednesday for 6 inch mufflers in either Aluminized Steel, 409 Stainless or 304 Stainless > these mufflers will be 51.5 inches long, 6 inch inlet and outlet and 10 inches in diameter > following shortly will be mandrel bent tubing for series 60 and 8v92 > mandrel bent no welds to impair efficiency. These will also be available in aluminized steel and 409,304 stainless > also available a bellows made of 304 stainless. No more ball and socket expansion joint. > they will be priced lower than traditional Vendors > The above will available in complete exhaust systems and in separate components > > for older Coaches and newer coaches > We are looking at reproducing left and right bank exhaust tubes on the 8v92 > Mufflers will available for m380 > > Stephen 97 bmc 37 > dupreeproducts.com > Mufflers - ken.hvac-conserve@... - 08-22-2010 03:57 Stephen, I also need pricing for a custom muffler for a 6V92TA 330Hp. Longest life SS 26" body 10 x 15 oval type 2 5" offset in and out Minimum pressure drop Tks BC/Ken Doyle H: 804-725-3132 C: 301-908-5735 ken.hvac-conserve@... --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@...> wrote: > > mufflers > 51 inch long 10 inch in diameter 6 inch inlet and outlet > Aluminized steel $273.00 > 409 Stainless $403.00 > 304 Stainless $588.00 > > Lead time 1 week form time of order from manufacturer to me. Then ups time form me to you > __________________ > Have a Great Day > > > Stephen Birtles > 97BMC37 > > http://www.dupreeproducts.com > Telephone 888 668 4288 > or 905 328 0162 > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@> wrote: > > > > Pricing will be available tomorrow Wednesday for 6 inch mufflers in either Aluminized Steel, 409 Stainless or 304 Stainless > > these mufflers will be 51.5 inches long, 6 inch inlet and outlet and 10 inches in diameter > > following shortly will be mandrel bent tubing for series 60 and 8v92 > > mandrel bent no welds to impair efficiency. These will also be available in aluminized steel and 409,304 stainless > > also available a bellows made of 304 stainless. No more ball and socket expansion joint. > > they will be priced lower than traditional Vendors > > The above will available in complete exhaust systems and in separate components > > > > for older Coaches and newer coaches > > We are looking at reproducing left and right bank exhaust tubes on the 8v92 > > Mufflers will available for m380 > > > > Stephen 97 bmc 37 > > dupreeproducts.com > > > Mufflers - Bluebird Bob - 08-22-2010 12:47 I'd be interested in the reply also. My PT36 has the 6V92 Silver. Bob Lawrence 84 PT36 Cushing, Maine > Stephen, > > I also need pricing for a custom muffler for a 6V92TA 330Hp. > > Longest life SS > 26" body > 10 x 15 oval type 2 > 5" offset in and out > Minimum pressure drop > > Tks BC/Ken Doyle > H: 804-725-3132 > C: 301-908-5735 > ken.hvac-conserve@... > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@> wrote: > > > > mufflers > > 51 inch long 10 inch in diameter 6 inch inlet and outlet > > Aluminized steel $273.00 > > 409 Stainless $403.00 > > 304 Stainless $588.00 > > > > Lead time 1 week form time of order from manufacturer to me. Then ups time form me to you > > __________________ > > Have a Great Day > > > > > > Stephen Birtles > > 97BMC37 > > > > http://www.dupreeproducts.com > > Telephone 888 668 4288 > > or 905 328 0162 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@> wrote: > > > > > > Pricing will be available tomorrow Wednesday for 6 inch mufflers in either Aluminized Steel, 409 Stainless or 304 Stainless > > > these mufflers will be 51.5 inches long, 6 inch inlet and outlet and 10 inches in diameter > > > following shortly will be mandrel bent tubing for series 60 and 8v92 > > > mandrel bent no welds to impair efficiency. These will also be available in aluminized steel and 409,304 stainless > > > also available a bellows made of 304 stainless. No more ball and socket expansion joint. > > > they will be priced lower than traditional Vendors > > > The above will available in complete exhaust systems and in separate components > > > > > > for older Coaches and newer coaches > > > We are looking at reproducing left and right bank exhaust tubes on the 8v92 > > > Mufflers will available for m380 > > > > > > Stephen 97 bmc 37 > > > dupreeproducts.com > > > > > > Mufflers - Patticake - 08-24-2010 11:29 Call Auto-jet muffler #800-247-5391. When the last time I talked to them, a 5" in and out was 185.20. The 6" was 333.48 plus shipping. These were exact replacment for the 6v and the 8v. Before they went to roof exhaust. Steve Gureasko 90WBWL401/2 Jus Chillin Ponchatoula, La. |
