Source for replacement upholstery - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Source for replacement upholstery (/showthread.php?tid=8993) |
Source for replacement upholstery - Royal - 06-03-2010 02:08 Recently I had to replace a padded vinyl covered ceiling panel due to water damage from a leaking skylight. I contacted several sources but only one responded, Gary's Upholstery in Tampa, FL. They provided fast service and were pleasant to work with. They will request a small sample for matching and will send 2 or 3 samples for you to choose from. In my case they came up with a perfect match. Contact them at http://www.garysupholstery.com if you need to match or replace upholstery material. Royal Washburn 97BBWL43' Conway, AR Source for replacement upholstery - Fred Hulse - 06-03-2010 02:27 Royal
Thanks for the information.
I was thinking about that very issue a couple days ago .
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Source for replacement upholstery - Bluebird Bob - 06-03-2010 11:44 --- In WanderlodgeForum@yahoogroups.com, "Royal" > > Recently I had to replace a padded vinyl covered ceiling panel due to water damage from a leaking skylight. I contacted several sources but only one responded, Gary's Upholstery in Tampa, FL. They provided fast service and were pleasant to work with. They will request a small sample for matching and will send 2 or 3 samples for you to choose from. In my case they came up with a perfect match. Contact them at http://www.garysupholstery.com if you need to match or replace upholstery material. > > Royal Washburn > 97BBWL43' > Conway, AR > Did you try Murial's in Ft. Valley, Ga? Bob Lawrence 84 PT36 Flanders, NJ Source for replacement upholstery - wbostow - 07-24-2010 11:09 --- In WanderlodgeForum@yahoogroups.com, "Bluebird Bob" wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "Royal" > > > > Recently I had to replace a padded vinyl covered ceiling panel due to water damage from a leaking skylight. I contacted several sources but only one responded, Gary's Upholstery in Tampa, FL. They provided fast service and were pleasant to work with. They will request a small sample for matching and will send 2 or 3 samples for you to choose from. In my case they came up with a perfect match. Contact them at http://www.garysupholstery.com if you need to match or replace upholstery material. > > > > Royal Washburn > > 97BBWL43' > > Conway, AR > > > Did you try Murial's in Ft. Valley, Ga? > > Bob Lawrence > 84 PT36 > Flanders, NJ > I'm a newbie to the group and do not have a coach but the ones I am considering all have headliner sagging. First of all, how does one take it off, and will removal damage it, or other stuff to get at it? Source for replacement upholstery - Ernie Ekberg - 07-27-2010 00:01
