Toad Battery Charging - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Toad Battery Charging (/showthread.php?tid=9023) |
Toad Battery Charging - Curt Sprenger - 06-26-2010 14:53 Just finished building/installing a base plate for our 2007 Wrangler. Now on to the next phase. The Wrangler owners manual recommends disconnecting the batter when towing 4 down. My SMI brake unit uses the battery for the vacuum pump so disconnecting the battery is not a good option. I located this http://www.lslproducts.com/ToadChargePage.html on the net. Anyone have experience with this unit? What have others done to keep the toad battery charged while going down the road? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Toad Battery Charging - Ralph L. Fullenwider - 06-26-2010 15:06 Hi Curt: The center pin on a 7 pin set up is used to charge trailer batteries from the Coach and can be used to trickle charge your toad. Check the wiring diagram in the files, it is a good source of info. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 07:53 PM 6/26/2010 -0700, you wrote: >Just finished building/installing a base plate for our 2007 Wrangler. Now >on to the next phase. The Wrangler owners manual recommends disconnecting >the batter when towing 4 down. My SMI brake unit uses the battery for the >vacuum pump so disconnecting the battery is not a good option. I located >this ><http://www.lslproducts.com/ToadChargePage.html>http://www.lslproducts.com/Toad\ ChargePage.html >on the net. Anyone have experience with this unit? What have others done >to keep the toad battery charged while going down the road? > >Curt Sprenger >1987 PT38 8V92 "MacAttack Racing" >Anaheim Hills, CA > > > Toad Battery Charging - Fred Hulse - 06-26-2010 15:17  Hi Curt
Haven't used any add-on towed chargers at all. The Dakota we bought calls for removing the battery cable also, but haven't done so.
I would think that unless you are going to drive for 8 or 12 hours at a time, the idea of charging the car towedbattery seems unnecessary.
Although that lsl toad charge does look sensible and practical if one sees the need.
Fred & Jeanne Hulse
Morristown Arizona 1997 Wanderlodge WLWB41 Toad Battery Charging - Chuck Wheeler - 06-26-2010 16:24 I would want to understand why they want - Chuck 1982 FC 31SB From: Just finished building/installing a base plate for our 2007 Wrangler. Now on to the next phase. The Wrangler owners manual recommends disconnecting the batter when towing 4 down. My SMI brake unit uses the battery for the vacuum pump so disconnecting the battery is not a good option. I located this http://www.lslprodu on the net. Anyone have experience with this unit? What have others done to keep the toad battery charged while going down the road? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Toad Battery Charging - jburgessx2@... - 06-26-2010 16:28 I disconnect my battery because I don't want the airbags to deploy if I have too stomp on the brakes too quickly. I'm not sure they will deploy but I'm not going to risk it. Jerry 85 PT 40 Sent via BlackBerry from T-Mobile From: "Chuck Wheeler" Date: Sat, 26 Jun 2010 23:24:33 -0500 To: Subject: RE: [WanderlodgeForum] Toad Battery Charging I would want to understand why they want - Chuck 1982 FC 31SB From: Just finished building/installing a base plate for our 2007 Wrangler. Now on to the next phase. The Wrangler owners manual recommends disconnecting the batter when towing 4 down. My SMI brake unit uses the battery for the vacuum pump so disconnecting the battery is not a good option. I located this http://www.lslprodu on the net. Anyone have experience with this unit? What have others done to keep the toad battery charged while going down the road? Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" |
