Fan override - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fan override (/showthread.php?tid=9116) |
Fan override - Don Bradner - 08-15-2010 03:53 >In a message dated 8/15/2010 12:47:32 A.M. Eastern Daylight Time, >waynekotila@... writes: >Hi Fred: > >How can you tell it comes on going down the road? >I have been trying to figure how it works in order to determine if it >works, and or what could be wrong with it. It is always problematic when the years aren't the same, but with mine there is a 7 degree swing when the fan is operating automatically - on at 196, off at 189. It helps that I have VMSpc to see the exact numbers, but I can see the swing on the analog gauge. When the fan is on override, the temp is essentially steady. If I'm in cool weather on the flat it drops to, and holds at, 180, which is the water thermostat. When I'm climbing hills it may be in the mid 190s or even push 200 with the fan on, but again it makes only slow change. I tend to blow a bit of coolant out the overflow when at or above 195, so I normally turn the fan override on as soon as the engine is fully warm unless I'm using the air conditioning (which also turns override on). Don Bradner 90 PT40 "Blue Thunder" My location: http://www.bbirdmaps.com/user2.cfm?user=1 |
