Hydraulic filter gasket or O ring. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Hydraulic filter gasket or O ring. (/showthread.php?tid=9117) |
Hydraulic filter gasket or O ring. - artw - 08-16-2010 17:11 Got back from the Monterey Rolex Autosports Reunion ( formerly called the Historical Auto Races) at 2:30 this morning. The one problem I had was a leaking hydrailic filter. I changed that filter last November. Does anyone have the numbet of the seal for the canister? I went back into the archives and found some discussion a year ago but no definate numbers. I changed all the hydraulic filters because the filter monitor light was red. It's still rad. I was able to charge my batteries with the generator. Shane, perhaps you're right - bad trafer switch. The other day it wouldn't charge. I just thought I'd try it again and was able to charge all week. Art Weatherly Riverside Ca '85 PT36 Hydraulic filter gasket or O ring. - sfedeli3 - 08-16-2010 22:36 Hi Art, I'll assume you are speaking about the long, tall canister that hangs right behind the fan motor assembly. The canister system on the hydraulic fan is a Parker 30P High Pressure Filter assembly. The Parker Nitrile O-ring part number is N92151. There is also a Fluoroelastomer O-ring that is the same size with a V prefix instead of an N. When I got the new o-ring from Parker, I took it down to the Caterpillar hose shop in Harrisburg and they were able to match it up with an O-ring that they stock for Cat equipment. The part number is 119-7844 and is printed on the o-ring. The package has number 1 1197844 1008477. So far, this was the least expensive source too. they ran $2.10 apiece. Also- here are several cross references for the high pressure filter- Baldwin #PT8498; Fleetguard #HF7795; Wix #57125; Parker #925835 and Donaldson #P170073. The stacked filters in the oil sump are also easy to find. I used Wix #57317. -Shane --- In WanderlodgeForum@yahoogroups.com, "artw" > > Got back from the Monterey Rolex Autosports Reunion ( formerly called > the Historical Auto Races) at 2:30 this morning. The one problem I had > was a leaking hydrailic filter. I changed that filter last November. > Does anyone have the numbet of the seal for the canister? I went back > into the archives and found some discussion a year ago but no definate > numbers. I changed all the hydraulic filters because the filter monitor > light was red. It's still rad. > > I was able to charge my batteries with the generator. Shane, perhaps > you're right - bad trafer switch. The other day it wouldn't charge. > I just thought I'd try it again and was able to charge all week. > > Art Weatherly > Riverside Ca > '85 PT36 > Hydraulic filter gasket or O ring. - Michael Bulriss - 08-17-2010 01:24
Hydraulic filter gasket or O ring. - artw - 08-17-2010 04:06 The light I was referring to was a filter monitor mounted where the suspention dump switches are. Shane, thanks for the info. Art Weatherly Riverside Ca '85 PT36 --- In WanderlodgeForum@yahoogroups.com, Michael Bulriss <mbulriss@...> wrote: > > Art, > > You got some great info from Shane.Ã But I note your comment: > > > I changed all the hydraulic filters because the filter monitor > > > light was red. It's still rad. > > If you are talking about the racor filter monitor, usually on the overhead dash panel, that is for the racor fuel filter.Ã So yes, changing a hydraulic filter has no effect.Ã You need to change the racor fuel filter to have that gauge move back out out the red.Ã The racor fuel filter on a PT should be in the cannister near/above the batteries on the passenger side of the engine compartment. > > Mike Bulriss > Hydraulic filter gasket or O ring. - artw - 08-17-2010 06:02 --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...> wrote: Shane, Which of those seals did you use. Also, the canister takes a 1 1/8 socket to tighten it. I would assume that means very tight. I did tighten it about one more turn while at Monterey. That slowed the leaking down from two Qts. every 100 miles to one Qt. It took almost an hour to get the rear of the coach clean. Shoud the seal be lubricated with something before installing? I don't remember doing that when I changed that filter. Art Weatherly Riverside Ca '85 PT36 > Hydraulic filter gasket or O ring. - Rob Robinson - 08-17-2010 06:36 I'll be corrected here if I'm wrong Art but all seals need some lube. A few days ago I had a coolant filter installed and the tech lubed it. On 17 August 2010 11:02, artw <"amweatherly@att.net"> wrote:
-- Rob, Sue and Joey Robinson Hydraulic filter gasket or O ring. - sfedeli3 - 08-17-2010 21:49 Hi Art, I used the one from Parker and later the one from Cat (part #119-7844) when I re-serviced the system. The o-ring fits into a small groove on the top of the filter canister. I lubed it with a bit of 10W30 motor oil (same as what is in the large filter tank) and then hand tightened the canister onto the filter head. Since the canister had fine, machine threads, it was really challenging to get the threads lined up with the canister full of oil. You also had to be careful not to knock the filter element off the nipple where it hangs from the filter head. The second time that I did it, I installed the filter element on the head, filled the canister only about 1/2 full of oil and that really kept me from making a mess. If you don't insert the filter onto the head first, it will usually not line up with the nipple when it's in the canister. It's an awkward place to work and hard to apply much force up on the canister while laying on your back. Once it is hand-tight, you can only turn it about 1/2 a rotation before it is fully seated. The canister is made of aluminum, so be very careful not to cross-thread it. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "artw" > > > > --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@> wrote: > Shane, > > Which of those seals did you use. Also, the canister takes a 1 1/8 socket to > tighten it. I would assume that means very tight. I did tighten it about one more turn while at Monterey. That slowed the leaking down > from two Qts. every 100 miles to one Qt. It took almost an hour to get the rear of the coach clean. Shoud the seal be lubricated with something > before installing? I don't remember doing that when I changed that filter. > > Art Weatherly > Riverside Ca > '85 PT36 > > > RE: Hydraulic filter gasket or O ring. - csprenger - 10-28-2015 19:34 Oil on parking pad. Fresh oil visible at the top of the Hyd. high pressure filter canister. Found the canister needed 1//3 to 1/2 turn to take up the slack. |
