Microphor Parts - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Microphor Parts (/showthread.php?tid=9120) |
Microphor Parts - Curt Sprenger - 08-18-2010 07:59 Microphor Toilet Removed ââ¬â Microphor Parts For Sale New ââ¬â Master Service Kit for LF-210 / LF-219; purchased April 2010. I paid $115.00. Make offer. New ââ¬â Flapper Assemble, Crank Assemble, O-Ring for hopper LF-210, 10-16 x þ SS Hex screws and washers; purchased April 2010. I paid $68.60. Make offer. Used ââ¬â Toilet Compressor, purchased new in 2005. Adjustable air regulator. Make Offer. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Microphor Parts - Dan and Cindy - 08-18-2010 08:55 What is a master service kit? Dan Sunderland 2005 450LXi San Marcos, CA --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Microphor Toilet Removed ââ¬" > Microphor Parts For Sale > > New ââ¬" Master Service Kit for LF-210 / LF-219; purchased April 2010. I > paid $115.00. Make offer. > > New ââ¬" Flapper Assemble, Crank Assemble, O-Ring for hopper LF-210, > 10-16 x þ SS Hex screws and washers; purchased April 2010. I paid > $68.60. Make offer. > > Used ââ¬" Toilet Compressor, purchased new in 2005. Adjustable air > regulator. Make Offer. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > Microphor Parts - Curt Sprenger - 08-18-2010 09:33 Dan, The master service kit is the "description" on the invoice...parts to rebuild the Microphor toilet internals, not including the flapper assemble.ààCurt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Wed, Aug 18, 2010 at 1:55 PM, Dan and Cindy <"86bluebird@sbcglobal.net"> wrote:
Microphor Parts - Rob Robinson - 08-18-2010 10:58 Curt I'll buy the flapper assembly. Could you bring it to Q in January On 18 August 2010 14:33, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
-- Rob, Sue and Joey Robinson Microphor Parts - Curt Sprenger - 08-18-2010 17:11 Rob, your offer is? Others would like to own the flapper kit.ÃÂ Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA On Wed, Aug 18, 2010 at 3:58 PM, Rob Robinson <"wander.rob@gmail.com"> wrote:
Microphor Parts - Rob Robinson - 08-18-2010 17:20 I took a look at mine and it appears I will have to remove the toilet to replace the valve and this involves a chance of breaking the lateral plumbing line. So I've decided to live with my leaking flapper for now. Sorry if I inconvenienced you. I was going to offer what you paid for it. Remember I still owe you a box of Bud Light. You can collect next January at the Q store okay On 18 August 2010 22:11, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
-- Rob, Sue and Joey Robinson Microphor Parts - Curt Sprenger - 08-19-2010 02:14 Yes, to change the flapper the toilet comes out. My guess is the lateral plumbing won't be a problem. Remember, BB and overkill. When I ordered the flapper kit the fellow said to be very careful removing and replacing the bowl. Others have replaced the flapper without issue. Bud Light and Q...sounds good. ÃÂ When are you coming down for the winter? Curt On Wed, Aug 18, 2010 at 10:20 PM, Rob Robinson <"wander.rob@gmail.com"> wrote:
Microphor Parts - Rob Robinson - 08-19-2010 02:38 We leave for Georgia and RATS/Maxton Oct 14th. Then after Christmas we head over your way for Q and some Southern Cal time On 19 August 2010 07:14, Curt Sprenger <"curtsprenger@gmail.com"> wrote:
-- Rob, Sue and Joey Robinson Microphor Parts - mcmike1952 - 08-19-2010 03:14 Rob, You have two otions on the leaking toilet flapper valve. It is really not hard to replace the flapper valve. As I remember one water inlet line to disconnect and one or two 12v connections to disconnect. Hardest part is adjusting the tension on the new valve. Other option is to clean the rubber seal on the valve and put a light coat of vaseline on it. Did this to our several months ago and no further leaking. Mike McMahan 96 42' Wanderlodge --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Yes, to change the flapper the toilet comes out. My guess is the lateral > plumbing won't be a problem. Remember, BB and overkill. When I ordered the > flapper kit the fellow said to be very careful removing and replacing the > bowl. Others have replaced the flapper without issue. > > Bud Light and Q...sounds good. > > When are you coming down for the winter? > > Curt > > > On Wed, Aug 18, 2010 at 10:20 PM, Rob Robinson > > > > > > > I took a look at mine and it appears I will have to remove the toilet to > > replace the valve and this involves a chance of breaking the lateral > > plumbing line. So I've decided to live with my leaking flapper for now. > > Sorry if I inconvenienced you. I was going to offer what you paid for it. > > Remember I still owe you a box of Bud Light. You can collect next January at > > the Q store okay > > > > > > On 18 August 2010 22:11, Curt Sprenger > > > >> > >> > >> Rob, your offer is? Others would like to own the flapper kit. > >> > >> Curt Sprenger > >> 1987 PT38 8V92 "MacAttack Racing" > >> Anaheim Hills, CA > >> > >> > >> > >> On Wed, Aug 18, 2010 at 3:58 PM, Rob Robinson > >> > >>> > >>> > >>> Curt I'll buy the flapper assembly. Could you bring it to Q in January > >>> > >>> On 18 August 2010 14:33, Curt Sprenger > >>> > >>>> > >>>> > >>>> Dan, > >>>> The master service kit is the "description" on the invoice...parts to > >>>> rebuild the Microphor toilet internals, not including the flapper > >>>> assemble. > >>>> > >>>> Curt Sprenger > >>>> 1987 PT38 8V92 "MacAttack Racing" > >>>> Anaheim Hills, CA > >>>> > >>>> > >>>> > >>>> On Wed, Aug 18, 2010 at 1:55 PM, Dan and Cindy < > >>>> 86bluebird@...> wrote: > >>>> > >>>>> > >>>>> > >>>>> What is a master service kit? > >>>>> > >>>>> Dan Sunderland > >>>>> 2005 450LXi > >>>>> San Marcos, CA > >>>>> > >>>>> --- In WanderlodgeForum@yahoogroups.com > >>>>> Curt Sprenger > >>>>> > > >>>>> > Microphor Toilet Removed âââ¬" > >>>>> > Microphor Parts For Sale > >>>>> > > >>>>> > New âââ¬" Master Service Kit for LF-210 / LF-219; purchased April 2010. > >>>>> I > >>>>> > >>>>> > paid $115.00. Make offer. > >>>>> > > >>>>> > New âââ¬" Flapper Assemble, Crank Assemble, O-Ring for hopper LF-210, > >>>>> > 10-16 x Ãâþ SS Hex screws and washers; purchased April 2010. I paid > >>>>> > $68.60. Make offer. > >>>>> > > >>>>> > Used âââ¬" Toilet Compressor, purchased new in 2005. Adjustable air > >>>>> > >>>>> > regulator. Make Offer. > >>>>> > > >>>>> > Curt Sprenger > >>>>> > 1987 PT38 8V92 "MacAttack Racing" > >>>>> > Anaheim Hills, CA > >>>>> > > >>>>> > >>>>> > >>>> > >>> > >>> > >>> -- > >>> Rob, Sue and Joey Robinson > >>> > >>> > >> > > > > > > -- > > Rob, Sue and Joey Robinson > > > > > > > Microphor Parts - Light Ltenergy@... - 08-21-2010 06:55 With our Blue, we had a "leak" in the Microphor and it turned out to be a matter of trying two things. First and easiest you can turn the bowl fill regulator a bit and then turn it back to where it is filling correctly for you. Sometimes the knob itself just needs to be turned some to get it to seat well again. We did that and it helped. THEN we had another overflow (clean water) and we got a kit to rebuild the little tiny flap that controls when the water closes off. THAT fixed our issues. NO removing the toliet. It wasn't the full rebuild kit, just the lesser one. Microphor people are extremely healful on this. Good luck!!! Light and Dennis Barrett 1991 PT WB 40' BLUE in the lower Sierras right now --- In WanderlodgeForum@yahoogroups.com, Rob Robinson > > I took a look at mine and it appears I will have to remove the toilet to > replace the valve and this involves a chance of breaking the lateral > plumbing line. So I've decided to live with my leaking flapper for now. > Sorry if I inconvenienced you. I was going to offer what you paid for it. > Remember I still owe you a box of Bud Light. You can collect next January at > the Q store okay > > On 18 August 2010 22:11, Curt Sprenger > > > > > > > Rob, your offer is? Others would like to own the flapper kit. > > > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > > > > > > On Wed, Aug 18, 2010 at 3:58 PM, Rob Robinson > > > >> > >> > >> Curt I'll buy the flapper assembly. Could you bring it to Q in January > >> > >> On 18 August 2010 14:33, Curt Sprenger > >> > >>> > >>> > >>> Dan, > >>> The master service kit is the "description" on the invoice...parts to > >>> rebuild the Microphor toilet internals, not including the flapper > >>> assemble. > >>> > >>> Curt Sprenger > >>> 1987 PT38 8V92 "MacAttack Racing" > >>> Anaheim Hills, CA > >>> > >>> > >>> > >>> On Wed, Aug 18, 2010 at 1:55 PM, Dan and Cindy <86bluebird@... > >>> > wrote: > >>> > >>>> > >>>> > >>>> What is a master service kit? > >>>> > >>>> Dan Sunderland > >>>> 2005 450LXi > >>>> San Marcos, CA > >>>> > >>>> --- In WanderlodgeForum@yahoogroups.com > >>>> Curt Sprenger > >>>> > > >>>> > Microphor Toilet Removed ââ¬" > >>>> > Microphor Parts For Sale > >>>> > > >>>> > New ââ¬" Master Service Kit for LF-210 / LF-219; purchased April 2010. > >>>> I > >>>> > >>>> > paid $115.00. Make offer. > >>>> > > >>>> > New ââ¬" Flapper Assemble, Crank Assemble, O-Ring for hopper LF-210, > >>>> > 10-16 x þ SS Hex screws and washers; purchased April 2010. I paid > >>>> > $68.60. Make offer. > >>>> > > >>>> > Used ââ¬" Toilet Compressor, purchased new in 2005. Adjustable air > >>>> > >>>> > regulator. Make Offer. > >>>> > > >>>> > Curt Sprenger > >>>> > 1987 PT38 8V92 "MacAttack Racing" > >>>> > Anaheim Hills, CA > >>>> > > >>>> > >>>> > >>> > >> > >> > >> -- > >> Rob, Sue and Joey Robinson > >> > >> > > > > > > > > -- > Rob, Sue and Joey Robinson > |
