removing the front sliding windows on a 78 31' FC - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: removing the front sliding windows on a 78 31' FC (/showthread.php?tid=9128) |
removing the front sliding windows on a 78 31' FC - groupj - 08-21-2010 06:43 Please confirm that this is the right order of steps 1. remove screws on the inside flashing that go to the window frame (no need to remove flashing to bus wall screws). 2. Remove window frame to outside of bus 3. disassemble window frame and remove sliding window (need help with las step - do you just remove the 2 screws holding in the latch and then the two flat head screws on either side of the split line? thanks Al - San Diego |
