Hydrallic fan by-pass button - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Hydrallic fan by-pass button (/showthread.php?tid=914) |
Hydrallic fan by-pass button - Bob & Carol Howald` - 06-23-2005 01:40 With all the social and BS post going on I imagine my post got overlooked by someone who was not interested in reading all the social and political news. I ask if anyone knew the procedure for doing the hyd-fan by pass test. It's the red light and push button located in the engine compartment of my 93pt. If I run the coach up to hi-idle or at any rpm and push the test button the engine quit's just as though you turned the key off. (yes I've talked to Benny and he's checking also) I don't know which years had this test panel installed but, surely someone has tried this test??? What were your result's and what procdure did you use to test the system. Thanks.Bob 93pt. HOT illinois Hydrallic fan by-pass button - bobloomas - 06-23-2005 02:09 ----- Original Message ----- From: Bob & Carol Howald` To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 23, 2005 8:40 AM Subject: [WanderlodgeForum] Hydrallic fan by-pass button I did read your post .I don't have that on my coach and no nothing about it. Wish i could help. Bob Loomas 85 PT 36 With all the social and BS post going on I imagine my post got overlooked by someone who was not interested in reading all the social and political news. I ask if anyone knew the procedure for doing the hyd-fan by pass test. It's the red light and push button located in the engine compartment of my 93pt. If I run the coach up to hi-idle or at any rpm and push the test button the engine quit's just as though you turned the key off. (yes I've talked to Benny and he's checking also) I don't know which years had this test panel installed but, surely someone has tried this test??? What were your result's and what procdure did you use to test the system. Thanks.Bob 93pt. HOT illinois ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Hydrallic fan by-pass button - ronmarabito2002 - 06-23-2005 12:34 Don't have it on my 92. I do have a fan overide switch on the dash that will turn the fan on manually. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > With all the social and BS post going on I imagine my post got > overlooked by someone who was not interested in reading all the social > and political news. I ask if anyone knew the procedure for doing the > hyd-fan by pass test. It's the red light and push button located in the > engine compartment of my 93pt. If I run the coach up to hi-idle or at > any rpm and push the test button the engine quit's just as though you > turned the key off. (yes I've talked to Benny and he's checking also) > I don't know which years had this test panel installed but, surely > someone has tried this test??? What were your result's and what > procdure did you use to test the system. Thanks.Bob 93pt. HOT illinois |
