Fireproof safes - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Fireproof safes (/showthread.php?tid=9151) |
Fireproof safes - Ryan Wright - 09-04-2010 04:56 I'm guessing the built in safe in my '86 PT-40 is not fireproof, and any cash carried would be lost if the coach burned to the ground, yeah? So I'm considering buying a fire proof safe. I'm fishing for mounting locations / ideas, but more importantly, wondering if ANY fireproof safes are good enough for this application? Will a 2 hour rated 1850 degree safe adequately protect it's contents in a fire fed by 300 gallons of fuel and a big old propane tank? It seems iffy at best. Any thoughts or ideas would be most appreciated. -Ryan '86 PT-40 8V92 Fireproof safes - Jonathan L - 09-05-2010 01:56 I don't think you have much to worry about in terms of keeping things from burning in the safe. RV's burn up. Anything at floor level or below is not really subjected to that much heat. The heat goes up - not down. Go take a look at the thread on Randy's RV and when it burned. He was able to retrieve things from the storage compartments that weren't damaged at all. Also, I was at a campground this summer and a SOB RV burned and pretty much left NOTHING above the floor. Yet, they were able to retrieve most of the stuff from the storage compartments below. Also, propane tanks rarely burn in those fires for the same reason - fires burn up not down. Nor do the fuel tanks. As mentioned, that SOB fire didn't burn the propane nor the gas in the tank (and it was gas - not diesel). Jonathan Leifheit Gonnabee Marietta, GA On 9/5/2010 5:59 AM, WanderlodgeForum@yahoogroups.com wrote: > 1. Fireproof safes > Posted by: "Ryan Wright"ryanpwright@... ryanpwright > Date: Sat Sep 4, 2010 10:11 am ((PDT)) > > I'm guessing the built in safe in my '86 PT-40 is not fireproof, and any cash carried would be lost if the coach burned to the ground, yeah? > > So I'm considering buying a fire proof safe. I'm fishing for mounting locations / ideas, but more importantly, wondering if ANY fireproof safes are good enough for this application? Will a 2 hour rated 1850 degree safe adequately protect it's contents in a fire fed by 300 gallons of fuel and a big old propane tank? It seems iffy at best. > > Any thoughts or ideas would be most appreciated. > > -Ryan > '86 PT-40 8V92 > |
