jacking up the bus - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: jacking up the bus (/showthread.php?tid=9155) |
jacking up the bus - MARGARET M ZAKOWSKI - 09-08-2010 02:50 Does any one know where the jacking points on the rear of the bus? Might have to remove the tranny and the levelers do not jack up high enough. Joe 1984 pt 40 ____________________________________________________________ Mortgage Rates Hit 3.25% If you owe under $729k you probably qualify for Obama's Refi Program http://thirdpartyoffers.juno.com/TGL3141/4c87a3253e791116925m06vuc jacking up the bus - Ralph - 09-08-2010 03:00 Anywhere along the lower frame member. The HWH jack points where they attach to the frame or near those points should be good. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: MARGARET M ZAKOWSKI <mjzakowski@...> Sender: WanderlodgeForum@yahoogroups.com Date: Wed, 8 Sep 2010 09:50:28 To: Reply-To: WanderlodgeForum@yahoogroups.com subject:[WanderlodgeForum] jacking up the bus Does any one know where the jacking points on the rear of the bus? Might have to remove the tranny and the levelers do not jack up high enough. Joe 1984 pt 40 ____________________________________________________________ Mortgage Rates Hit 3.25% If you owe under $729k you probably qualify for Obama's Refi Program http://thirdpartyoffers.juno.com/TGL3141/4c87a3253e791116925m06vuc ------------------------------------ Yahoo! Groups Links jacking up the bus - Ralph - 09-08-2010 03:14 One other area to look at after a decision of where your going to jack the frame. With the suspension inflated, measure the distance between the top of the lower frame and bottom of the upper frame the cut Oak blocks to fit in between the frames. This will safely keep the extra 4 inches from the ride height in place, after you dump the suspension with the blocks in place Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: MARGARET M ZAKOWSKI <mjzakowski@...> Sender: WanderlodgeForum@yahoogroups.com Date: Wed, 8 Sep 2010 09:50:28 To: Reply-To: WanderlodgeForum@yahoogroups.com subject:[WanderlodgeForum] jacking up the bus Does any one know where the jacking points on the rear of the bus? Might have to remove the tranny and the levelers do not jack up high enough. Joe 1984 pt 40 ____________________________________________________________ Mortgage Rates Hit 3.25% If you owe under $729k you probably qualify for Obama's Refi Program http://thirdpartyoffers.juno.com/TGL3141/4c87a3253e791116925m06vuc ------------------------------------ Yahoo! Groups Links jacking up the bus - Ralph L. Fullenwider - 09-08-2010 04:03 Just a word of caution, if you lift the rear wheels off the ground the Coach will roll if the front tires are not fully blocked to prevent the roll. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 09:50 AM 9/8/2010 -0500, you wrote: >Does any one know where the jacking points on the rear of the bus? Might >have to remove the tranny and the levelers do not jack up high enough. > >Joe >1984 pt 40 >__________________________________________________________ |
