Belts & propane furnace - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Belts & propane furnace (/showthread.php?tid=9197) |
Belts & propane furnace - williamcharrison - 10-17-2010 02:40 Is there any way to tighten engine belts without removing the back bumper to swing the radiator out on my 90 SP36? Also, just returned from a chilly trip where only the front propane furnace worked. The rear elec heater and rear propane furnace do not although the elec heater in the bathroom does. The schematic I have refers to a Primus furnace but I don't have a Primus. William C Harrison Akron, Ohio 90 WLSP36 Belts & propane furnace - Donald Spithaler - 10-17-2010 15:39 I don't think there is a good way to tighten the belts without swinging the rad. Keep a good check on you belts as if you have any trouble on the road it can cost you a lot more than in your driveway or local shop. Don't ask me how I know that/////  Four bolts in the bumper & two in the rad. It is not bad to swing the rad. I do mine at least once a year. If you want give me your phone number & I'll give you a call.     Don                     On Sun, Oct 17, 2010 at 10:40 AM, williamcharrison <"williamcharrison@yahoo.com"> wrote:
