1990 W-B40 CHARGING SYSTEM - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1990 W-B40 CHARGING SYSTEM (/showthread.php?tid=9295) |
1990 W-B40 CHARGING SYSTEM - jamiejbrandt - 02-15-2011 11:56 HELLO ALL QUICK QUESTION DOSE ANYONE KNOW ANYTHING ABOUT THE BATTERY CHARGING FROM THE INVERTER THERE IS TWO WIRES THAT GO FROM THE STARTER SOLENOID BOTH HAVE DIODES IN THEM DOSE ANYONE KNOW WHAT THEY DO?? AND IF ANYONE HAS A PICTURE OF THIS PLEASE EMAIL THEM TO ME JAMIEJBRANDT@... I REMOVED ONE WIRE NOT KNOWING THE DIODE WAS THERE AND I REDID THE WIRE AND IM NOT SURE WHICH WAY THE DIODE GOES THE WIRES WERE DRY AND BRITAL IT SEEMS LIKE IM NOT GETTING A CHARGE FROM THE BATTERY CHARGER JAMIE BRANDT 1990 WB-40 FLORIDA 1990 W-B40 CHARGING SYSTEM - wl89spman - 02-17-2011 14:42 Jamie, need more info to help you... which bay do you need picts. of.. I had charging problems for 2 years with my PD9155's(2). long story short the chargers were bad. Replaced them with a 9280(1). No more charging prob.. Ed Gardels 89SP Arlington Tx --- In WanderlodgeForum@yahoogroups.com, "jamiejbrandt" wrote: > > HELLO ALL > QUICK QUESTION DOSE ANYONE KNOW ANYTHING ABOUT THE BATTERY CHARGING FROM THE INVERTER THERE IS TWO WIRES THAT GO FROM THE STARTER SOLENOID BOTH HAVE DIODES IN THEM DOSE ANYONE KNOW WHAT THEY DO?? AND IF ANYONE HAS A PICTURE OF THIS PLEASE EMAIL THEM TO ME JAMIEJBRANDT@... > I REMOVED ONE WIRE NOT KNOWING THE DIODE WAS THERE AND I REDID THE WIRE AND IM NOT SURE WHICH WAY THE DIODE GOES > THE WIRES WERE DRY AND BRITAL > IT SEEMS LIKE IM NOT GETTING A CHARGE FROM THE BATTERY CHARGER > JAMIE BRANDT > 1990 WB-40 > FLORIDA > 1990 W-B40 CHARGING SYSTEM - Chuck Wheeler - 02-18-2011 05:13 Ed, I have “overhauled” all three - - From: Jamie, need more info to help you... which bay do you need picts. of.. I had charging problems for 2 years with my PD9155's(2). long story short the chargers were bad. Replaced them with a 9280(1). No more charging prob.. --- In "WanderlodgeForum%40yahoogroups.com", "jamiejbrandt" > > HELLO ALL > QUICK QUESTION DOSE ANYONE KNOW ANYTHING ABOUT THE BATTERY CHARGING FROM THE INVERTER THERE IS TWO WIRES THAT GO FROM THE STARTER SOLENOID BOTH HAVE DIODES IN THEM DOSE ANYONE KNOW WHAT THEY DO?? AND IF ANYONE HAS A PICTURE OF THIS PLEASE EMAIL THEM TO ME JAMIEJBRANDT@... > I REMOVED ONE WIRE NOT KNOWING THE DIODE WAS THERE AND I REDID THE WIRE AND IM NOT SURE WHICH WAY THE DIODE GOES > THE WIRES WERE DRY AND BRITAL > IT SEEMS LIKE IM NOT GETTING A CHARGE FROM THE CHARGER > JAMIE BRANDT > 1990 WB-40 > > 1990 W-B40 CHARGING SYSTEM - GARY MINKER - 02-18-2011 15:40
1990 W-B40 CHARGING SYSTEM - jamiejbrandt - 02-20-2011 01:53 CHARGING SYSTEM FOR MOTOR IS WHERE I SEE THE PROBLEM IT WORK FINE WHEN RUNNING JAMIE BRANDT 1990 WB40 --- In WanderlodgeForum@yahoogroups.com, "wl89spman" > > > Jamie, need more info to help you... which bay do you need picts. of.. I had charging problems for 2 years with my PD9155's(2). long story short the chargers were bad. Replaced them with a 9280(1). No more charging prob.. > > Ed Gardels 89SP > Arlington Tx > > --- In WanderlodgeForum@yahoogroups.com, "jamiejbrandt" > > > > HELLO ALL > > QUICK QUESTION DOSE ANYONE KNOW ANYTHING ABOUT THE BATTERY CHARGING FROM THE INVERTER THERE IS TWO WIRES THAT GO FROM THE STARTER SOLENOID BOTH HAVE DIODES IN THEM DOSE ANYONE KNOW WHAT THEY DO?? AND IF ANYONE HAS A PICTURE OF THIS PLEASE EMAIL THEM TO ME JAMIEJBRANDT@ > > I REMOVED ONE WIRE NOT KNOWING THE DIODE WAS THERE AND I REDID THE WIRE AND IM NOT SURE WHICH WAY THE DIODE GOES > > THE WIRES WERE DRY AND BRITAL > > IT SEEMS LIKE IM NOT GETTING A CHARGE FROM THE BATTERY CHARGER > > JAMIE BRANDT > > 1990 WB-40 > > FLORIDA > > > |
