1982 Generator Comp Slide - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 1982 Generator Comp Slide (/showthread.php?tid=9376) |
1982 Generator Comp Slide - papaskettle - 05-14-2011 14:02 Had the old bird painted while in the shop they forced the Gen out with out using the air switch. Now I can't the Gen in or out found a blown fuse and replaced it but still no luck. Anyone have an idea where to start. Any help Jim Sturm 1982 Generator Comp Slide - Ralph L. Fullenwider - 05-14-2011 15:37 Jim: Check the lock to see that it is in the open position. There should be a micro switch giving the indication at the dash area that the lock is not locked for transport. Also check for a relay in the change over compartment where the air switch is located, be sure it is not partially out of the socket. Safe travels, Ralph and Charolette Fullenwider "84FC35 "Ruff Diamond" Duncan, Oklahoma At 02:02 AM 5/15/2011 +0000, you wrote: >Had the old bird painted while in the shop they forced the Gen out with >out using the air switch. Now I can't the Gen in or out found a blown >fuse and replaced it but still no luck. Anyone have an idea where to start. > >Any help >Jim Sturm > > > |
