Titling/registration help - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Titling/registration help (/showthread.php?tid=9383) |
Titling/registration help - Trader Den - 05-23-2011 10:21 Greetings Folks, I am in the process of trying to title and register my Blue Bird in South Dakota, however I've run in to a snag. I am in Boise Idaho and finalized the purchase last December and haven't been able to get it started since. The state of SD requires among other things a weight verification on the unit. Obviously I haven't been able to get it to a scale to fulfill this requirement and in the meantime they tell me I am allowed only 30 days from date of purchase to get it registered. After 30 days penalties and interest start accruing. It was suggested that I get verification of weight from the factory. I explained the fact that they're out of business and NADA does not list the weights in their guides. Does anyone have a suggestion on how I can supply SD with an arms-length opinion, on a weight they can use? TIA Dennis Gloe 1985 PT40 Titling/registration help - freewill2008 - 05-23-2011 10:36 Take the GVW off the plate that shows axle ratings, etc. Its up over the windshield in FCs, probably the same place on a PT. The actual weight should not be more than 85% to 90% of GVW. Bob Griesel '84 FC31 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Trader Den" > > Greetings Folks, > I am in the process of trying to title and register my Blue Bird in South Dakota, however I've run in to a snag. I am in Boise Idaho and finalized the purchase last December and haven't been able to get it started since. The state of SD requires among other things a weight verification on the unit. Obviously I haven't been able to get it to a scale to fulfill this requirement and in the meantime they tell me I am allowed only 30 days from date of purchase to get it registered. After 30 days penalties and interest start accruing. It was suggested that I get verification of weight from the factory. I explained the fact that they're out of business and NADA does not list the weights in their guides. Does anyone have a suggestion on how I can supply SD with an arms-length opinion, on a weight they can use? > > TIA > > Dennis Gloe > 1985 PT40 > Titling/registration help - George Burke - 05-23-2011 10:37 I don't know where they are on the PT's Dennis, but my FC31 has Tags from the factory showing the gross Vehicle wgt,etc. up near the front of the bus. You should be able to find tags somewhere on your PT that identify the vehicle as to what it is, date of mfg., etc. There are tags that tell you the axle wgt. as well. Seems that you could take pictures of these to them. Some buses also had blue boxes that had the original paper work and a whole slew of info. on what the bus came with. Good Luck. Hope this info. helps you. George Burke 1977 FC31 Charlotte On Mon, May 23, 2011 at 6:21 PM, Trader Den <"nfun2@yahoo.com"> wrote:
Titling/registration help - David Heibult - 05-23-2011 10:47 Dennis; I live in SD and have a PT all you need is a certified scale weightfrom a truck stop or grain elevator and give that to the lic people and that should do it David Heibult 91WLWB To: WanderlodgeForum@yahoogroups.com From: gnburke@... Date: Mon, 23 May 2011 18:37:11 -0400 Subject: Re: [WanderlodgeForum] Titling/registration help
Titling/registration help - Trader Den - 05-23-2011 10:58 Thanks but I can't get it started to drive to scales. --- In WanderlodgeForum@yahoogroups.com, David Heibult > > > > Dennis; I live in SD and have a PT all you need is a certified scale weight from > > a truck stop or grain elevator and give that to the lic people and that should do it David Heibult 91WLWB > > > To: WanderlodgeForum@yahoogroups.com > From: gnburke@... > Date: Mon, 23 May 2011 18:37:11 -0400 > Subject: Re: [WanderlodgeForum] Titling/registration help > > > > > > > I don't know where they are on the PT's Dennis, but my FC31 has Tags from the factory showing the gross Vehicle wgt,etc. up near the front of the bus. You should be able to find tags somewhere on your PT that identify the vehicle as to what it is, date of mfg., etc. There are tags that tell you the axle wgt. as well. Seems that you could take pictures of these to them. Some buses also had blue boxes that had the original paper work and a whole slew of info. on what the bus came with. Good Luck. Hope this info. helps you. George Burke 1977 FC31 Charlotte > > > On Mon, May 23, 2011 at 6:21 PM, Trader Den > > > > > > > Greetings Folks, > I am in the process of trying to title and register my Blue Bird in South Dakota, however I've run in to a snag. I am in Boise Idaho and finalized the purchase last December and haven't been able to get it started since. The state of SD requires among other things a weight verification on the unit. Obviously I haven't been able to get it to a scale to fulfill this requirement and in the meantime they tell me I am allowed only 30 days from date of purchase to get it registered. After 30 days penalties and interest start accruing. It was suggested that I get verification of weight from the factory. I explained the fact that they're out of business and NADA does not list the weights in their guides. Does anyone have a suggestion on how I can supply SD with an arms-length opinion, on a weight they can use? > > TIA > > Dennis Gloe > 1985 PT40 > Titling/registration help - Ernie Ekberg - 05-23-2011 11:37
Titling/registration help - MARGARET M ZAKOWSKI - 05-23-2011 12:55 my book on a 1984 1/2 says it weigh about 40,000 pound Joe 1984/85 pt 40 ____________________________________________________________ Groupon™ Official Site 1 ridiculously huge coupon a day. Get 50-90% off your city's best! http://thirdpartyoffers.juno.com/TGL3141/4ddb023b91af622f83m00vuc Titling/registration help - MARGARET M ZAKOWSKI - 05-23-2011 13:07 my book says 40,000 lbs Joe 1984 1/2 PT 40 for sale ____________________________________________________________ Penny Stock Soaring 3000% Sign up for Free to find out what the next 3000% Stock Winner is! http://thirdpartyoffers.juno.com/TGL3141/4ddb0554eeeb722faem00vuc Titling/registration help - Bruce Morris - 05-23-2011 14:40 Dennis, I have attached the GVWR info for the 1985 PT-40owner's manual which should help you.
Regards, Bruce Morris in Raleigh, NC (919)872-7635 Webmaster Wanderlodge Owners Online 1983 WL FC35RB FMCA# F7142s; ARS: KI4ME; Vietnam Vet From: Trader Den To: WanderlodgeForum@yahoogroups.com Sent: Mon, May 23, 2011 6:21:46 PM Subject: [WanderlodgeForum] Titling/registration help Greetings Folks, I am in the process of trying to title and register my Blue Bird in South Dakota, however I've run in to a snag. I am in Boise Idaho and finalized the purchase last December and haven't been able to get it started since. The state of SD requires among other things a weight verification on the unit. Obviously I haven't been able to get it to a scale to fulfill this requirement and in the meantime they tell me I am allowed only 30 days from date of purchase to get it registered. After 30 days penalties and interest start accruing. It was suggested that I get verification of weight from the factory. I explained the fact that they're out of business and NADA does not list the weights in their guides. Does anyone have a suggestion on how I can supply SD with an arms-length opinion, on a weight they can use? TIA Dennis Gloe 1985 PT40 |
